DWM ( Desktop Windows Manager ) Sample Code
i saw that Code Sample from this Thread is not available any more
https://groups.google.com/g/harbour-users/c/sjeytL6zUPs
so i upload Code from Kenny here
HB_DWM.ZIP
(3.22 KiB) Downloaded 95 times
! Note : Sample MUST run with
..\..\build dwmkreis.hbp
..\..\build dwmBlur.hbp
while when load into IDE it will not work with
-ldwmapi
which is in *.HBP
btw. i have try to include it into *.HBC
Libs=dwmapi
but it seems not to work this Way
to made it "Full-Transparent" like in this Thread
http://www.hmgforum.com/viewtopic.php?f=5&t=7194
you have to use
BACKCOLOR { 1, 1, 1 }
in every Control (not possible with BUTTON, COMBOBOX while have no BACKCOLOR )
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Re: DWM ( Desktop Windows Manager ) Sample Code
Post by Claudio Ricardo »
Hello... Instead of button control you can use image control with a transparent .png icon, I do like this.
AUGE_OHR wrote: Wed Mar 16, 2022 10:42 pm hi,
-ldwmapi
which is in *.HBP
Libs=dwmapi
Hola Jimmy, xomo no tengo el codigo fuente completo para probar IPTV con El Administrador de ventanas de escritorio (DWM)
puede usar esa misma libreria de Mingw64 desde esta ruta :
copiarla a c:\hmg.3.6\include desde "C:\hmg.3.6\mingw64\x86_64-w64-mingw32\include\dwmapi.h"
a c:\hmg3.6\lib64 desde "C:\hmg.3.6\mingw64\x86_64-w64-mingw32\lib\libdwmapi.a"
o en el archivo .hbc
libpaths=C:\hmg.3.6\mingw64\x86_64-w64-mingw32\lib
incpaths=C:\hmg.3.6\mingw64\x86_64-w64-mingw32\include
libs=dwmapi
FUNCTION Main()
DEFINE WINDOW Win_1 ;
AT 0, 0 WIDTH 600 HEIGHT 400 ;
TITLE "Prueba DWM en HMG" ;
// Obtenemos el Handle (HWND) de la ventana HMG
LOCAL hWnd := GetFormHandle("Win_1")
// Ejemplo: Activar modo oscuro en la barra de título (Windows 10/11)
// DWMWA_USE_IMMERSIVE_DARK_MODE = 20
DwmSetWindowAttributeInt( hWnd, 20, 1 )
CENTER WINDOW Win_1
ACTIVATE WINDOW Win_1
// C-WRAPPERS PARA DWM
#pragma BEGINDUMP
#ifndef WINVER
#define WINVER 0x0600
#endif
#include <windows.h>
#include <dwmapi.h>
#include "hbapi.h"
* Permite cambiar atributos del DWM pasando un entero (ej: Modo Oscuro, Esquinas redondas)
* Sintaxis Harbour: DwmSetWindowAttributeInt( hWnd, nAttribute, nValue )
HB_FUNC( DWMSETWINDOWATTRIBUTEINT )
HWND hwnd = (HWND) hb_parptr( 1 );
DWORD dwAttribute = (DWORD) hb_parni( 2 );
int nValue = hb_parni( 3 );
HRESULT hr = DwmSetWindowAttribute( hwnd, dwAttribute, &nValue, sizeof(nValue) );
hb_retnl( (LONG) hr );
* Extender el marco de la ventana hacia el área de cliente (Efecto Glass/Blur)
* Sintaxis Harbour: DwmExtendFrameIntoClientArea( hWnd, nLeft, nTop, nRight, nBottom )
HB_FUNC( DWMEXTENDFRAMEINTOCLIENTAREA )
MARGINS margins;
margins.cxLeftWidth = hb_parni( 2 );
margins.cxRightWidth = hb_parni( 3 );
margins.cyTopHeight = hb_parni( 4 );
margins.cyBottomHeight = hb_parni( 5 );
HRESULT hr = DwmExtendFrameIntoClientArea( hwnd, &margins );
#pragma ENDDUMP
hi
danielmaximiliano wrote: Thu Jul 30, 2026 7:00 pm
-ldwmapi
which is in *.HBP
Libs=dwmapi
check i you have C:\BCC7\LIB\psdk\DWMAPI.a
i use VLC ActiveX to Show IPTV (using *.M3U Files, include in ZIP File)
         DEFINE ACTIVEX oxVLC
            PARENT Form_1
            ROW 0
            COL 0
            WIDTH aSize[ 1 ]
            HEIGHT aSize[ 2 ]
            PROGID "VideoLAN.VLCPlugin.2"
            TOOLTIP "right-click Mouse Menu"
         END ACTIVEX
IPTV.ZIP
(238.29 KiB) Downloaded 31 times
hi
Note : Not every Version of VLC seemes to work using IPTV !
This Version work : 3.0.18 Vetinari
AUGE_OHR wrote: Fri Jul 31, 2026 10:07 am hi
Look : https://hmgforum.com/viewtopic.php?t=7766
danielmaximiliano wrote: Fri Jul 31, 2026 6:43 pm Look : https://hmgforum.com/viewtopic.php?t=7766
i mean just IPTV will not work Correct with some VLC Version. Video will work using all VLC Version.
