PROCEDURE DownloadFromWWW
param cURL, cLocalFileName, lSilent
LOCAL oCon, oUrl, i, cResponse
local ret := .f.
local StaraObslugaBledu
BEGIN SEQUENCE with {|| break()}
cLocalFileName := alltrim(cLocalFileName)
if lSilent = NIL
lSilent := .f.
oUrl := tURL():New( cUrl )
IF Empty( oUrl )
if !lSilent
MsgBox("Wrong url adress" + cUrl)
BREAK
IF oUrl:cProto != "http"
if !lSilent
MsgBox('Wrong http adress')
BREAK
END
oCon := TipClientHttp():New( oUrl )
oCon:nConnTimeout := 20000
if !lSilent
MsgBox("Connecting with "+ oUrl:cServer)
IF oCon:Open( cUrl )
if !lSilent
MsgBox("Connection established." +chr(10)+"Press OK to download " + oUrl:cPath +oUrl:cFile)
oCon:WriteAll(cLocalFileName)
if !lSilent
MsgBox("Downloaded and written as: "+cLocalFileName)
oCon:Close()
ret := .t.
IF oCon:SocketCon == NIL
cResponse := "Connection not initialized"
ELSEIF hb_InetErrorCode( oCon:SocketCon ) == 0
cResponse := oCon:cReply
if !lSilent
cResponse := "Error in connection: " + hb_InetErrorDesc( oCon:SocketCon )
if !lSilent
MsgBox("Connection can't be established: "+ oUrl:cServer+chr(10)+"Server answer: "+cResponse)
ret := .f.
END
RECOVER
if !lSilent
MSGSTOP("Connection failed!")
END SEQUENCE
RETURN ret
Why not Download the logo with Firefox and put in a program folder.
My one logo for desktops is called desktoplogo.jpg .... I use jpeg. I am sure you could use png.
You may need to work with it depending on size.
franco wrote: ↑Tue Mar 15, 2022 7:26 pm
Jimmy needs to fetch thumbnails from links that the user creates or import from .m3u files . These are not files permanently embedded in the program and are dynamicly changed for each selected record, therefore they must be downloaded in runtime.
