Row BackColor in inactive BROWSE control
Hi guys!
We have function CellNavigationColor which can set colors of GRID control.
But, anybody knows the way to change active row colors in BROWSE, especially when focus is out of this control (in this situation active row is backlighted by default window backgroud color, default light grey)?
Red2
Re: Row BackColor in inactive BROWSE control
Post by Red2 »
Hi Mol,
Might this example from my BROWSE be helpful?
// In my Main.PRG:
public bkItemType := ;
	{ || iif( alltrim( Items->Type_Item ) == "Short" ;
			, {255,215,215} ;
	,	 iif( alltrim( Items->Type_Item ) == "Medium" ;
			, {230,225,130} ;
	,	 iif( alltrim( Items->Type_Item ) == "Long" ;
			, {180,220,235} ;
// In my Browse's DynamicBackColor:
{ bkItemType, bkItemType, bkItemType, bkItemType, bkItemType, bkItemType, bkItemType }
Kind regards,
Red2
I don't want to use DynamicBackColor.
I want to change row highlight color when Browse is not active - in this situation selected row background is grey - on almost LCD monitors it's hard to see the difference between white
franco
Post by franco »
Hi Mol
You can change the backcolor and current row is normal. I can not figure how to change current row.
DEFINE BROWSE brwItems
BACKCOLOR {200,200,200} // { 255, 255, 255}
FONTCOLOR { 0, 0, 0 }
All The Best,
Franco
Canada
I want to change color in the state when browse is inactive
edk
Post by edk »
Marku, nie jestem biegły w C i nie pomogę w zmianie koloru wybranego wiersza, ale aby zrobić go bardziej czytelnym, może spróbuj w inną mańkę, np. zmienić kolor tła Browse przy utracie fokusa i przywrócić kolor tła przy uzyskaniu fokusa:
ON GOTFOCUS ( This.BackColor := {255,255,255} );
ON LOSTFOCUS ( This.BackColor := {215,215,215} );
I found solution, but it's written in basic.
I don't know how to adapt it to BROWSE control.
Maybe someone is able to do it?
https://www.vbforums.com/showthread.php ... ost5438543
and some code from this page:
Private Function ListViewStayBlue_Proc(ByVal hWnd As Long, ByVal uMsg As Long, ByVal wParam As Long, ByVal lParam As Long, ByVal uIdSubclass As Long, ByVal dwRefData As Long) As Long
    If uMsg = WM_DESTROY Then
        UnSubclassSomeWindow hWnd, AddressOf_ListViewStayBlue_Proc, uIdSubclass
        ListViewStayBlue_Proc = NextSubclassProcOnChain(hWnd, uMsg, wParam, lParam)
        Exit Function
    End If
    If IdeStopButtonClicked Then ' Protect the IDE.  Don't execute any specific stuff if we're stopping.  We may run into COM objects or other variables that no longer exist.
        Exit Function
    End If
    Dim LVI As LVITEM
    Const GWL_STYLE             As Long = &HFFFFFFF0
    Const WM_SETFOCUS           As Long = &H7&
    Const WM_KILLFOCUS          As Long = &H8&
    Const LVS_SHOWSELALWAYS     As Long = &H8&
    Const LVM_FIRST             As Long = &H1000&
    Const LVM_GETNEXTITEM       As Long = (LVM_FIRST + 12&)
    Const LVM_SETITEMSTATE      As Long = (LVM_FIRST + 43&)
    Const LVIS_FOCUSED          As Long = &H1&
    Const LVNI_FOCUSED          As Long = &H1&
    Const LVNI_SELECTED         As Long = &H2&
    Select Case uMsg
    Case WM_KILLFOCUS
        If GetWindowLongW(hWnd, GWL_STYLE) And LVS_SHOWSELALWAYS Then                                   ' If Not ListView.HideSelection Then...
            Set m_ListView1_SelectedItem = ListView1.SelectedItem                                       ' Set a reference to the currently selected item before SelectedItem is set to Nothing
            dwRefData = SendMessageW(hWnd, LVM_GETNEXTITEM, -1&, ByVal LVNI_FOCUSED Or LVNI_SELECTED)   ' Get ListView.SelectedItem.Index, if any.
            SubclassSomeWindow hWnd, AddressOf_ListViewStayBlue_Proc, dwRefData                         ' Update dwRefData/Index
           'SubclassSomeWindow is moved out of the following If block to fix an unrelated bug
            If dwRefData <> LV_INVALID_INDEX Then                                                       ' If Not ListView.SelectedItem Is Nothing Then...
                LVI.StateMask = LVIS_FOCUSED                                                            ' Bit flag already 0, so no need to do anything; LVI.State = LVI.State And Not LVIS_FOCUSED
                SendMessageW hWnd, LVM_SETITEMSTATE, dwRefData, LVI                                     ' Remove the focus rectangle from the currently focused item.
            End If
            Exit Function        ' Consume the message so that the ListView doesn't remove the highlight from the selected item(s).
        End If
    Case WM_SETFOCUS
            LVI.State = LVIS_FOCUSED
            SendMessageW hWnd, LVM_SETITEMSTATE, dwRefData, LVI                                         ' Reinstate the focus rectangle.
        End If
    End Select
    ' Give control to other procs, if they exist.
    ' Notice that we don't get to here if uMsg = WM_KILLFOCUS.
End Function
Public Sub SubclassToKeepListViewBlue(lsv As ListView, bLeaveFocusRect As Boolean)
    ' This one just makes the ListView work a bit more like the ListBox.
    ' When ListView doesn't have the focus, the selected item goes gray, which is hard to see.
    ' This just makes it stay blue (like the ListBox).
    ' NOTICE:   If bLeaveFocusRect=FALSE then lsv___.SelectedItem... can NOT be used as it gets deselected.  We must use bLeaveFocusRect=TRUE if we wish to use lsv___.SelectedItem...
    '           We use the sign bit of dwRefData to track this.
    SubclassSomeWindow lsv.hWnd, AddressOf ListViewStayBlue_Proc, &H7FFFFFFF Or (&H80000000 And CLng(bLeaveFocusRect)) ' LV_INVALID_INDEX = -1, but we use the sign bit for tracking bLeaveFocusRect.
End Sub
        Exit Function
    End If
        Exit Function
    End If
    Dim LVI                     As LVITEM
    Dim iLeaveFocusRect         As Long                     ' Just the sign bit is used.
    Dim iSelIndex               As Long                     ' Sign bit is masked off, even when it's LV_INVALID_INDEX.  That's why we use LV_INVALID_INDEX_ALT.
    Const LV_INVALID_INDEX_ALT  As Long = &H7FFFFFFF        ' LV_INVALID_INDEX = -1, but we use the sign bit for tracking bLeaveFocusRect.
    Select Case uMsg
    Case WM_KILLFOCUS
            iSelIndex = SendMessageW(hWnd, LVM_GETNEXTITEM, -1&, ByVal LVNI_FOCUSED Or LVNI_SELECTED)   ' Get ListView.SelectedItem.Index, if any.
            iSelIndex = iSelIndex And LV_INVALID_INDEX_ALT                                              ' Mask off the sign bit.
            iLeaveFocusRect = dwRefData And &H80000000                                                  ' Get our bLeaveFocusRect (but not as true boolean).
            If iSelIndex <> LV_INVALID_INDEX_ALT Then                                                   ' If Not ListView.SelectedItem Is Nothing Then...
                SubclassSomeWindow hWnd, AddressOf_ListViewStayBlue_Proc, iSelIndex Or iLeaveFocusRect  ' Update dwRefData.
                If iLeaveFocusRect Then LVI.State = LVIS_FOCUSED                                        ' Keep the focus rectangle if so directed.
                SendMessageW hWnd, LVM_SETITEMSTATE, iSelIndex, LVI                                     ' Remove the focus rectangle from the currently focused item (if that's what we want).
            End If
        End If
    Case WM_SETFOCUS
        iSelIndex = dwRefData And LV_INVALID_INDEX_ALT
            SendMessageW hWnd, LVM_SETITEMSTATE, iSelIndex, LVI                                         ' Reinstate the focus rectangle.
        End If
    End Select
End Function
Private Function AddressOf_ListViewStayBlue_Proc() As Long
    AddressOf_ListViewStayBlue_Proc = ProcedureAddress(AddressOf ListViewStayBlue_Proc)
End Function
En el GRID funciona esto.
Tal vez estudiandolo y entendiendolo, funcione para el BROWSE.
In the GRID this works.
Maybe studying and understanding it will work for the BROWSE.
	CellNavigationColor( _SELECTEDCELL_FORECOLOR, YELLOW )	// CAMBIA COLOR DE CELDA-COLUMNA
	CellNavigationColor( _SELECTEDCELL_BACKCOLOR, GREEN )		// CAMBIA COLOR DE CELDA-COLUMNA
	CellNavigationColor( _SELECTEDCELL_DISPLAYCOLOR, .T. )
	CellNavigationColor( _SELECTEDROW_FORECOLOR, WHITE )		// CAMBIA COLOR DEL RENGLON
	CellNavigationColor( _SELECTEDROW_BACKCOLOR, BLUE )		// CAMBIA COLOR DEL RENGLON
	CellNavigationColor( _SELECTEDROW_DISPLAYCOLOR, .T. )
***  i_grid.ch
// CONSTANTS --> GridCellNavigationColor (nIndex) // only for cell navigation = .T.
#define _SELECTEDROW_DISPLAYCOLOR   1
#define _SELECTEDCELL_DISPLAYCOLOR  2
#define _SELECTEDROW_FORECOLOR      348
#define _SELECTEDROW_BACKCOLOR      349
#define _SELECTEDCELL_FORECOLOR     350
#define _SELECTEDCELL_BACKCOLOR     351
***  h_GridEx.prg
FUNCTION CellNavigationColor (nIndex, xData)
MEMVAR _HMG_GRID_SELECTEDROW_DISPLAYCOLOR
MEMVAR _HMG_GRID_SELECTEDCELL_DISPLAYCOLOR
LOCAL  aRGB_old, aRGB
   IF nIndex == _SELECTEDROW_DISPLAYCOLOR .AND. ValType (xData) == "L"
      _HMG_GRID_SELECTEDROW_DISPLAYCOLOR := xData
   IF nIndex == _SELECTEDCELL_DISPLAYCOLOR .AND. ValType (xData) == "L"
      _HMG_GRID_SELECTEDCELL_DISPLAYCOLOR := xData
   IF nIndex >= 348 .AND. nIndex <= 351
      aRGB := xData
      aRGB_old := _HMG_SYSDATA [ nIndex ]
      IF ValType (aRGB) == "A" .AND. HMG_LEN (aRGB) == 3
         _HMG_SYSDATA [ nIndex ] := aRGB
      ELSEIF ValType (aRGB) <> "U"
         MsgHMGError ("Grid Cell Navigation Color: Invalid parameter aRGB color. Program Terminated")
      MsgHMGError ("Grid Cell Navigation Color: Invalid parameters. Program Terminated")
RETURN aRGB_old
