how XML extract tags, keys
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
I have XML files, see structure but how (easy) extract some tags, keys or other data
examle data in attcahment
efaktura.zip
(290.95 KiB) Downloaded 336 times
edk
Re: how XML extract tags, keys
Post by edk »
dragancesu wrote: Tue Dec 21, 2021 11:19 am I have XML files, see structure but how (easy) extract some tags, keys or other data
Take a look at this sample, it might be useful to you.
4dragancesu.7z
(218.73 KiB) Downloaded 209 times
dragancesu
@edk Thank you, nice
this is for eInvoice goverment project, xml download from site and task is load into invoice data structure
Is posible something like in attachment
1. step xml_vadi
2. step xml_fnc
and result is DBF with data from XML
efaktura2.zip
(5.7 KiB) Downloaded 180 times
edk
Post by edk »
dragancesu wrote: Wed Dec 22, 2021 8:22 am @edk Thank you, nice
1. step xml_vadi
2. step xml_fnc
It seems to me that a better solution will be to directly process the xml file and save the read values directly to the target databases. Here is an example:
#require "hbmxml.hbc"
#define cTab 	Chr ( 9 )
Local cXmlString, cXmlFile, aXML, i, cPath, cKey, xValue, hAttrib, lShowMessage
//To Make DO CASE ... sequence only
Local aPath, Attrib_Key
cXmlFile := GetFile( {{'XML File', '*.xml'}}, 'Select XML', hb_CWD(), .F. , .T. )
IF EMPTY( cXmlFile )
	RETURN Nil
lShowMessage := MsgYesNo( "Show processed data?" )
cXmlString := FileStr( cXmlFile )
aXML := hb_XmlToArray( cXmlString, .T. /* .F. = encode root node also */  )
	aPath :={}
	STRFILE ("****** DO CASE for the " + hb_FNameNameExt ( cXmlFile ) + " file structure ********" + CRLF + "DO CASE" + CRLF, "Do_case.prg", .F. )
FOR i := 1 TO Len ( aXML )
	cPath   := aXML [ i ] [ 1 ]
	cKey    := aXML [ i ] [ 2 ]
	xValue  := aXML [ i ] [ 3 ]
	hAttrib := aXML [ i ] [ 4 ]
	// <----   here is xml data processing, e.g. writing to databases according to tags and possibly attributes
	IF lShowMessage
		/* In this example, I'm displaying the read values, the key and the path to the key along with any attributes */
		MsgInfo ('Key Path: "' + cPath + '"' + CRLF + CRLF + ;
			    'Key: "' + cKey + '"' + CRLF + CRLF + ;
			    "Value: " + Left ( xValue, 100 ) /* first 100 chars for test only */ + CRLF + CRLF +;
			    IF( Len( hAttrib ) > 0 , "Attribute(s): " + hb_JsonEncode ( hAttrib ), "" ), "Processing data from an XML file." )
	/* Below I used the read XML file structure to generate a DO CASE ... sequence that I can use to process data from the XML file, e.g. to write values to the appropriate database fields. */
	//Make DO CASE ... sequence
		IF hb_AScan ( aPath, cPath + "/" + cKey, , , .T. ) = 0
			AAdd( aPath, cPath + "/" + cKey)
			STRFILE ( cTab + 'CASE cKey == "' + cKey + '" .AND. cPath == "' + cPath + '"' + CRLF + cTab + cTab + CRLF , "Do_case.prg", .T. )
			IF LEN( hAttrib ) > 0
				FOR EACH Attrib_Key IN hb_HKeys ( hAttrib )
					STRFILE ( cTab + cTab + 'IF hb_HHasKey( hAttrib, "' + Attrib_Key + '" )' + CRLF + ;
							cTab + cTab + cTab + 'xAttribValue := hb_HGet ( hAttrib, "' + Attrib_Key + '" )' + CRLF + CRLF + ;
							cTab + cTab + 'ENDIF' + CRLF + CRLF , "Do_case.prg", .T. )
	//End Make DO CASE ... sequence
NEXT i
STRFILE ("END CASE", "Do_case.prg", .T. )
MsgInfo ('The file "Do_case.prg" has been created with the DO CASE sequence for the "' + hb_FNameNameExt ( cXmlFile ) + '" file structure.' )
STATIC FUNCTION hb_XMLtoArray( cXML, lOmitHeader )
LOCAL pXML
Private __aXML := {}
hb_default( @lOmitHeader, .T. )
pXML := mxmlLoadString( NIL, hb_utf8ToStr( cXML ), MXML_OPAQUE_CALLBACK )
IF !Empty( pXML )
	IF lOmitHeader
		hb_ArrayXML_getnodes( mxmlGetFirstChild( pXML ))
		hb_ArrayXML_getnodes( pXML )
mxmlDelete( pXML )
RETURN __aXML
STATIC FUNCTION hb_ArrayXML_getnodes( pNode )
LOCAL cKey, pChild, xResult, xValue, cPrevKey, hAttrib, pParrentNode, cPath
DO WHILE !Empty( pNode )
	IF mxmlGetType( pNode ) == MXML_ELEMENT
		cKey   := mxmlGetElement( pNode )
		pChild := mxmlGetFirstChild( pNode )
		xValue := hb_ArrayXML_getnodes( pChild )
		IF xValue == NIL
			xValue := mxmlGetOpaque( pNode )
			IF !( xValue == CRLF )
				cPath := ""
				pParrentNode := mxmlGetParent( pNode )
				DO WHILE !EMPTY ( pParrentNode )
					cPrevkey := mxmlGetElement( pParrentNode )
					IF Left ( cPrevkey, 4 ) <> "?xml"
						cPath := cPrevkey + IF( !Empty( cPath ), "/", "") + cPath
					pParrentNode := mxmlGetParent( pParrentNode )
				ENDDO
				hAttrib      := hb_mxmlGetAttrs( pNode )
				AADD( __aXML, { cPath, cKey, xValue, hAttrib } )
				xResult := __aXML
	pNode := mxmlGetNextSibling( pNode )
ENDDO
RETURN xResult
The xml file is converted to an array, where the first element of the array is the path to the key, the second element is the key, the third element is the key value, and the fourth element is the optional key attributes.
In my example, the read paths, keys, values and attributes were used to generate a DO CASE sequence that I can use in .prg to process the read data from the XML file.
I think that this procedure can be used with any structure of XML files, but you need to pay attention to use an xml file when creating a DO CASE sequence, in which all possible keys described in the schema are contained in the structure, including the optional ones.
dragancesu
Thank you
edk
Post by edk »
Added CDATA support:
Local cXmlString, cXmlFile, aXML, i, cPath, cKey, xValue, hAttrib, lShowMessage := .T.
	RETURN Nil
	aPath :={}
	IF lShowMessage
NEXT i
LOCAL pXML
IF !Empty( pXML )
	IF lOmitHeader
mxmlDelete( pXML )
RETURN __aXML
		IF xValue == NIL
			IF !(xValue == CRLF)
				cPath := ""
				IF Left ( cKey, 8 ) == "![CDATA["
					xValue := hb_StrShrink ( mxmlGetCDATA( pNode ), 2 )
					cKey   := mxmlGetElement( mxmlGetParent( pNode ) )
					pParrentNode := mxmlGetParent( mxmlGetParent( pNode ) )
				ENDDO
				xResult := __aXML
ENDDO
RETURN xResult
brunellopulix
Post by brunellopulix »
Hi
if you find it useful here a procedure that converts xml to Ini
FUNCTION _Xml_To_Ini3(cXml,cIni)
LOCAL aRay := {}
LOCAL aTemp := {}
LOCAL cString := hb_MemoRead(cXml)
LOCAL i
Local nhandle
cString := StrTran(cString,'<',CHR(10)+'<')
cString := StrTran(cString,'>','>'+CHR(10))
cString := StrTran(cString,CHR(13),'')
aTemp := hb_ATokens(cString,CHR(10))
nHandle := FCreate(cIni)
FOR i := 1 TO Len(aTemp)
IF Empty(aTemp)
If !Empty(aRay) .and. Left(aRay[1],2) != '</'
aRay[1] := StrTran(aRay[1],'<','[')
aRay[1] := StrTran(aRay[1],'>',']')
FWrite(nHandle,CRLF)
FWrite(nHandle,aRay[1]+CRLF)
Endif
aRay := {}
aadd(aRay,AllTrim(aTemp))
If Len(aRay) == 3
aRay[1] := StrTran(aRay[1],'<','')
aRay[1] := StrTran(aRay[1],'>','')
FWrite(nHandle,aRay[1]+'='+aRay[2]+CRLF)
aRay := {}
Endif
Endif
Next
FClose(nHandle)
execute file cIni
Brunello Pulix
Hola EDK
Muchas gracias por tu aporte, le veo mucha utilidad.
He estado haciendo pruebas pero ya me perdí, y "necesito una una pequeña ayuda de mis amigos". :)
Los datos que están en Amarillo si los puedo obtener pero los que están en Azul no logro hacerlo.
Trate de hacerlo con el DO_CASE que genera tu ejemplo pero tampoco resultó.
Alguna idea ?
Hi EDK
Thank you very much for your contribution, I see it very useful.
I've been doing tests but I'm lost, and "I need a little help from my friends." :)
I can get the data that are in Yellow but the ones that are in Blue I can't.
I tried to do it with the DO_CASE that your example generates but it didn't work either.
Any ideas ?
Pueden agrandar la imagen abriéndola en otra pestaña.
The image can be enlarged by opening it in another tab.
XMLDemo.zip
(5.63 KiB) Downloaded 150 times
edk
Post by edk »
At first glance it looks like some nodes have Nil values but have attributes and child node. Those with Nil values are ignored, so we will have to treat them as if they had empty values. I'll try to prepare something tomorrow.
brunellopulix
This is the attachment
Brunello Pulix
