column to start printing
carlazza
Post by carlazza »
Hi all,
I need to print a fixed word followed by a variable field. How can I calculate the column to start printing the variable?
ex:
@030,050 PRINT 'My name is ' Font 'calibri' Size 12
@030,??? PRINT NAME Font 'calibri' SIZE 12 BOLD
I hope I was clear
Thanks
Carlo
Re: column to start printing
use
nPixelX := GetTextWidth( hDC, TRIM( cText ), hFont )
to calculate Size of Text
franco
Post by franco »
I would use
Ctxt := 'My name is '
@030,050 PRINT Ctxt Font 'calibri' Size 12
@030,050+len(Ctxt) PRINT NAME Font 'calibri' SIZE 12 BOLD
All The Best,
Franco
Canada
carlazza
Post by carlazza »
AUGE_OHR wrote: Thu Dec 09, 2021 11:45 pm hi,
use
Thanks AUGE_OHR
Could you please explain it to me better, using my example?
Carlo
carlazza
Post by carlazza »
franco wrote: Fri Dec 10, 2021 5:06 pm I would use
Thanks franco but I think that your solution doesn't work
Function "LEN" does not take into account the text's font and his size
Carlo
carlazza wrote: Fri Dec 10, 2021 9:27 pm Could you please explain it to me better, using my example?
try this
LOCAL cNAME := "Carlo"
LOCAL cFont := 'calibri'
LOCAL nSize := 12
   @030,050 PRINT 'My name is ' Font cFont Size nSize
// correction
// nCol := CalcWide(cName,cFont , nSize)
   nCol := CalcWide('My name is ',cFont , nSize)
   @030,nCol PRINT cNAME Font cFont SIZE nSize
FUNCTION CalcWidth(cName,cFont,nSize, lBold)
LOCAL hDC := GetDC(0)
// HMG_CreateFont ( [ hDC ] , cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeOut ) --> hFont
LOCAL hFont := HMG_CreateFont( hDC, cFont , nSize, IF(lBold,.T.,.F.), .F., .F., .F. )
   nPixelX := GetTextWidth( hDC, cName, hFont )
RETURN nPixelX
edk
Post by edk »
AUGE_OHR wrote: Sat Dec 11, 2021 1:09 am hi,
try this
LOCAL nSize := 12
// correction
RETURN nPixelX
Unfortunately, I can't quite agree with what you wrote.
First, there is a logical error in the placement of the second phrase in the printout. It should be
@030,050 + nCol PRINT cNAME Font cFont SIZE nSize BOLD
Secondly, your CalcWidth function returns a value expressed in pixels, and we use millimeters to define a printout.
Third, you refer to the object hDC: = GetDC (0), which is the desktop / screen and its DPI. The DPI of the screen has nothing to do with the DPI of the printer.
So, we need some additional information:
DPI of the printer, converting pixels to millimeters.
I would do it this way ;) :
cTextToPrint := 'My name is '
cName := "Carlo"
cPrintFontName := "Calibri"
nPrintFontSize := 12
nLenTextToPrint := GetTxtLen ( cTextToPrint, cPrintFontName, nPrintFontSize )
@030,050 PRINT cTextToPrint Font cPrintFontName Size nPrintFontSize
@030,050 + nLenTextToPrint PRINT cName Font cPrintFontName SIZE nPrintFontSize BOLD
FUNCTION GetTxtLen ( cText, cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeout )
RETURN HMG_GethDCTextWidthinMM (OpenPrinterGetPageDC(), cText, cPrintFont, nFontSize, lBold, lItalic, lUnderline, lStrikeout )
FUNCTION HMG_GethDCTextWidthInMM (hDC, cText, cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeout)
RETURN (HMG_GethDCTextWidthInPx (hDC, cText, cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeout) * 25.4 ) / HMG_GetPrinterResolution( hDC )[1]
FUNCTION HMG_GethDCTextWidthInPx (hDC, cText, cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeout)
Local hFont
Default cText:=""
Default cFontName := _HMG_SYSDATA [ 342 ]
Default nFontSize := _HMG_SYSDATA [ 343 ]
Default lItalic := .F.
Default lUnderline := .F.
Default lStrikeout := .F.
Default lBold := .F.
hFont := HMG_CreateFont (hDC, cFontName, nFontSize, lBold, lItalic, lUnderline, lStrikeOut )
RETURN GetTextWidth( hDC, cText, hFont )
#pragma begindump
#include "HMG_UNICODE.h"
#include <windows.h>
#include <hbapi.h>
HB_FUNC ( HMG_GETPRINTERRESOLUTION )
	hb_reta (2);
	hb_storvni ( GetDeviceCaps( (HDC) hb_parnl (1), LOGPIXELSX ),         -1, 1 );
	hb_storvni ( GetDeviceCaps( (HDC) hb_parnl (1), LOGPIXELSY ),         -1, 2 );
#pragma ENDDUMP
It seems to me that this problem has probably already been discussed on the forum, but I cannot recall the topic.
franco
Post by franco »
Is hpdfprint in pixels or millimeters ?
I am having this problem with printing memo files to hpdfprint.
One of these options could work for me, I may need help because I need to make the line length to stop at the end of a word.
Someone may have this solution already.
Thanks.
All The Best,
Franco
Canada
edk
Post by edk »
franco wrote: Sat Dec 11, 2021 4:51 pm Is hpdfprint in pixels or millimeters ?
Thanks.
Hpdfprint is in millimeters also.
Look at this topic, I think this may be helpful https://www.hmgforum.com/viewtopic.php?p=57056#p57056
franco
Post by franco »
I have been offline for a bit.
Thanks to all for advive. I now have time to check this out.
All The Best,
Franco
Canada
