Virtual Grids can view large text files?
HGAutomator
Post by HGAutomator »
I read in another post that Virtual Grids can look at large text files, if we apply the HB_F() functions for navigation.
Is that correct? Would it be possible to load delimited large tab files into a grid?
I have a license for Delimit http://delimitware.com/ , but can't distribute it freely. If it's possible to view and scroll a file with 3 gigabytes and about 17 million lines, with the virtual grid?
I know how to do the parsing, I wrote a utility that I'll share on the forum soon. But I just need to confirm it's possible to view large text files in a harbour environment.
Re: Virtual Grids can view large text files?
you can use VIRTUAL and GRID with every TEXT File ... when hole ROW is "one Cell" :roll:
Problem are "Delimiter" of CSV which you have to split into single Element for Column.
IMHO to "display" Data is always "slow" ... even a Progressbar (if used more that 100 x )
i do use MEMOREAD(), MLCOUNT() and MEMOLINE() and this Function
FUNCTION AtInside( cText , cMarker)
LOCAL nPos := 1
LOCAL aRet := {}
DEFAULT cMarker TO ","
   DO WHILE .T.
      nPos := AT( cMarker, cText )
      IF nPos > 0
         AADD( aRet, LTRIM( SUBSTR( cText, 1, ( nPos - 1 ) ) ) )
         cText := SUBSTR( cText, ( nPos + 1 ), LEN( cText ) - nPos )
         AADD( aRet, LTRIM( cText ) )
         EXIT
   ENDDO
RETURN aRet
it will to split Line, "delimited" with cMarker, and add Element to Array
when LEN(Array) is OK i can FIELDPUT() Element to DBF
HGAutomator
Thanks Auge,
I don't think I'd use Memoread(). Wouldn't that have problems loading huge files?
I'd prefer to use the HB functions in Readonly mode. The import utility I wrote is based on code that originally imported the entire text file into a single dbf table. That has the 2 billion record RDD limitation, so I use the HB functions to bypass that.
HGAutomator wrote: Thu Nov 18, 2021 3:26 pm I don't think I'd use Memoread(). Wouldn't that have problems loading huge files?
i had Problem with 32 Bit e.g. under Xbase++ but with 64 Bit no Problem.
HB_MEMOREAD() // not limited to 64 KB as MEMOREAD()
if i "read" with File with F-Function it work on every "Cell"
if i extract a "Line" i can call a Thread for every "Line" to extract Element and add to DBF
as HMG 64 Bit Version can use Unicode i´#m not limited any more ;)
HGAutomator
Ok, I'll play with it and see what happens, thanks A.O.
edk
Post by edk »
HGAutomator wrote: Wed Nov 17, 2021 5:32 pm Hi,
Hi.
You intrigued me with your question.
At first I thought it wouldn't be a complicated task, I wanted to use the hb_F* function to process text files, but found out that they don't quite work properly on large files.
I did a simple test which consisted of going to the desired records, going back and calculating the number of records.
Depending on the order of the actions I got different results.
This can be seen by selecting the "Test hb_F* functions" option from the "Test" menu.
So I decided to build my own class. There were performance issues, especially with large files (eg, 70,000,000 records and a size of more than 7 GB) and the jump between hundreds of thousands of records (this is the case when using the vertical slider).
So I thought it might be worth indexing the file you were browsing, but the index file was again taking up a lot of disk space.
I came up with the idea to do something like a record map in my class, which will not be a file but a matrix.
In order to reduce the size of the matrix again, I used 64-bit words to write the values ​​of record numer and file pointer (don't worry it works in the 32-bit also), which I was shrinking again.
The record map is created on the fly when navigating the file using the GoTo and Skip methods, and is completely created when the CountLines method is called.
The class is probably not without errors, but it may be helpful for you.
I used the Virtual Grid control to browse the files. To be able to read the entire file into the Grid, you need to know the number of records. The counting process may take some time with large files.
So, I did three browsing variants:
First: only the beginning of the file is loaded. The moment cell navigation is moved near the end of the list, the next part of the file is loaded - incremental loading.
Second: records are counted before browsing.
Third: counting the number of records is performed in a separate thread and is constantly updated while browsing the Grid.
While working on this task, it turned out that the Grid can be very memory-hungry, especially when we read any property in the QueryData code, be it the Grid control itself, the form window, etc.
To visualize it, just select "Virtual Grid (test memory leaking)" in the "File" menu.
Just try to move the mouse pointer over the Grid and you will see how quickly the available memory is "thinning". Uncheck all three boxes to disable properies polling in QueryData and memory will no longer be consumed at that rate.
demo.7z
(1.19 MiB) Downloaded 136 times
i have "play" with CLASS vfFileRead and found out that it can "read" file > 4 GB under 32 Bit App / OS :o
how is this possible with harbour / HMG :idea:
(HB_PUT_LE_UINT64() / HB_GET_LE_UINT64()
p.s. have change hb_parnl(1) to HMG_parnl(1) in Listview Function and use
#define COMPILE_HMG_UNICODE
#include "HMG_UNICODE.h"
where does these File I/O Function
hb_vfOpen()
hb_vfClose()
hb_vfEof()
hb_vfSize()
hb_vfRead()
hb_vfReadLen()
hb_vfSeek()
hb_vfWrite()
hb_vfErase()
hb_vfAttrGet()
hb_vfConfig()
hb_vfDirectory()
hb_vfExists()
hb_vfRename()
hb_vfOpenProcess()
come from :?:
gfilatov
Post by gfilatov »
AUGE_OHR wrote: Wed Dec 01, 2021 10:14 am hi,
come from :?:
Hi Jimmy,
Try the following command
hbmk2.exe -find hb_vf* > out.txt
and will get the result:
Harbour core (installed):
hb_vfAttrGet()
hb_vfAttrSet()
hb_vfClose()
hb_vfCommit()
hb_vfConfig()
hb_vfCopyFile()
hb_vfDirectory()
hb_vfDirBuild()
hb_vfDirExists()
hb_vfDirMake()
hb_vfDirRemove()
hb_vfDirSpace()
hb_vfDirUnbuild()
hb_vfEof()
hb_vfErase()
hb_vfExists()
hb_vfFlush()
hb_vfHandle()
hb_vfLink()
hb_vfLinkRead()
hb_vfLinkSym()
hb_vfLoad()
hb_vfLock()
hb_vfLockTest()
hb_vfMoveFile()
hb_vfNameExists()
hb_vfOpen()
hb_vfRead()
hb_vfReadAt()
hb_vfReadLen()
hb_vfRename()
hb_vfSeek()
hb_vfSize()
hb_vfTempFile()
hb_vfTimeGet()
hb_vfTimeSet()
hb_vfTrunc()
hb_vfUnlock()
hb_vfWrite()
hb_vfWriteAt()
hbpipeio.hbc (installed):
hb_vfFromPipes()
hb_vfOpenProcess()
hbtcpio.hbc (installed):
hb_vfFromSocket()
edk
Post by edk »
AUGE_OHR wrote: Wed Dec 01, 2021 7:12 am hi,
They come from HARBOUR\include\hbdefs.h :
#define HB_GET_LE_UINT64( p )    ( ( UINT64 ) \
                                      ( ( ( UINT64 ) (( BYTE * )( p ))[0] ) | \
                                        ( ( UINT64 ) (( BYTE * )( p ))[1] <<  8 ) | \
                                        ( ( UINT64 ) (( BYTE * )( p ))[2] << 16 ) | \
                                        ( ( UINT64 ) (( BYTE * )( p ))[3] << 24 ) | \
                                        ( ( UINT64 ) (( BYTE * )( p ))[4] << 32 ) | \
                                        ( ( UINT64 ) (( BYTE * )( p ))[5] << 40 ) | \
                                        ( ( UINT64 ) (( BYTE * )( p ))[6] << 48 ) | \
                                        ( ( UINT64 ) (( BYTE * )( p ))[7] << 56 ) ) )
   #define HB_PUT_LE_UINT64( p, w )    do { \
                                         (( BYTE * )( p ))[0] = ( BYTE )( w ); \
                                         (( BYTE * )( p ))[1] = ( BYTE )( (w) >>  8 ); \
                                         (( BYTE * )( p ))[2] = ( BYTE )( (w) >> 16 ); \
                                         (( BYTE * )( p ))[3] = ( BYTE )( (w) >> 24 ); \
                                         (( BYTE * )( p ))[4] = ( BYTE )( (w) >> 32 ); \
                                         (( BYTE * )( p ))[5] = ( BYTE )( (w) >> 40 ); \
                                         (( BYTE * )( p ))[6] = ( BYTE )( (w) >> 48 ); \
                                         (( BYTE * )( p ))[7] = ( BYTE )( (w) >> 56 ); \
                                       } while ( 0 )
AUGE_OHR wrote: Wed Dec 01, 2021 7:12 am p.s. have change hb_parnl(1) to HMG_parnl(1) in Listview Function and use
You can remove these Listview function completely, I left them by mistake because I was checking the cause of the memory leak.
Below is the current version of the class, with improved handling of zero byte files.
*   vfFileRead Class                                              *
#include "hbclass.ch"
#include "fileio.ch"
#define vf_DEF_READ_SIZE  	4096
#define vf_DELIMITER		hb_eol()
#define vf_REC_MAP_STEP		100000
CREATE CLASS vfFileRead
   VAR cFile
   VAR pHandle
   VAR nError
   VAR cDelim
   VAR nReadSize
   VAR lEOF
   VAR lBOF
   VAR nCurrLine
   VAR nLastLine
   VAR exGauge
   VAR aRecordsMap INIT {} PROTECTED
   VAR nRecordsMapStep PROTECTED
   METHOD New( cFile, nSize, cDelimiter, nRecMapStep )		// Create a new object (file name, buffer size , delimiter, map record indexed step)
   METHOD Open( nMode )								// Open the file ( nMode )
   METHOD Close()									// Close the file
   METHOD ReadLine()								// Read line of current record (when opened, current record is first)
   METHOD GoTop()									// Go to first record
   METHOD GoBottom()								// Go to last record
   METHOD GoTo( nLine )								// Go to <nLine> record
   METHOD Skip( nSkip )								// Skip by <nSkip> records
   METHOD IsEOF()									// Returns .T. if the current record is the last
   METHOD IsBOF()									// Returns .T. if the current record is the first
   METHOD Error()									// Returns .T. an error occurred
   METHOD ErrorNo()									// Returns the error number
   METHOD GetPointer()								// Reads the current position of the file pointer
   METHOD SetPointer( nPointer )						// Sets the file pointer to the indicated position
   METHOD GetLastLinePointer()						// Reads the file pointer position for the last record
   METHOD CurrentLine()								// Reads the current record
   METHOD CountLines( xGauge )						// Calculates the number of lines (records), as a parameter you can pass a block of code executed during the counting operation
   METHOD GetRecordsMap()							// Gets a map of records
   METHOD PutRecordsMap( aMap )						// Puts a map of records
END CLASS
METHOD New( cFile, nSize, cDelimiter, nRecMapStep ) CLASS vfFileRead
Default nRecMapStep := vf_REC_MAP_STEP
nRecMapStep := Max ( nRecMapStep, 10000 )
IF nSize == NIL .OR. nSize < 1
	nSize := vf_DEF_READ_SIZE
::cFile     := cFile
::pHandle   := NIL
::nError    := 0
::nReadSize := nSize
::cDelim    := cDelimiter
::lEOF	  := .F.
::lBOF	  := .F.
::nCurrLine := 0
::nLastLine := NIL
::aRecordsMap:={}
::nRecordsMapStep := nRecMapStep
RETURN Self
METHOD Open( nMode ) CLASS vfFileRead
Local cLine
IF ::pHandle == NIL
	IF nMode == NIL
		nMode := FO_READ + FO_SHARED   // Default to shared read-only mode
	::pHandle := hb_vfOpen( ::cFile, nMode )
	::aRecordsMap:={}
	IF ::pHandle == NIL
		::nError    := FError()
		::lBOF      := .F.
		::nCurrLine := 0
		::nError    := 0
		::lBOF      := .T.
		::nCurrLine := 1
		//delimiter detection
		IF ::cDelim == NIL
			::cDelim := vf_DELIMITER
			cLine := hb_vfReadLen( ::pHandle, 64*1024 /* ::nReadSize */ )
			::GoTop()
			DO CASE
				CASE hb_AT( CHR (13) + CRLF, cLine ) > 0		//CRCRLF
					::cDelim := CHR (13) + CRLF
				CASE hb_AT( CRLF, cLine ) > 0					//CRLF
					::cDelim := CRLF
				CASE hb_AT( CHR (13), cLine ) > 0				//CR
				CASE hb_AT( CHR (10), cLine ) > 0				//LF
					::cDelim := CHR (10)
			ENDCASE
      // The file is already open, so rewind to the beginning.
	IF !::GoTop()
      	::lBOF      := .F.
      	::nCurrLine := 0
		::lBOF      := .T.
		::nCurrLine := 1
RETURN Self
METHOD Close() CLASS vfFileRead
IF .NOT. ::pHandle == NIL
	hb_vfClose( ::pHandle )
	::pHandle := NIL           // The file is no longer open
::lEOF      := .F.
::lBOF      := .F.
::nCurrLine := 0
::nLastLine := NIL
RETURN Self
METHOD ReadLine() CLASS vfFileRead
Local cLine       := ""
Local nCurrentPos := ::GetPointer()
DO WHILE !hb_vfEof( ::pHandle )
	cLine += hb_vfReadLen( ::pHandle, ::nReadSize )
	IF hb_AT( ::cDelim, cLine ) > 0
		cLine := Left ( cLine, hb_AT( ::cDelim, cLine ) - 1 )
		EXIT
ENDDO
::SetPointer ( nCurrentPos )
RETURN cLine
METHOD GoTop() CLASS vfFileRead
::lEOF      := .F.
::lBOT      := .T.
::nCurrLine := 1
RETURN hb_vfSeek( ::pHandle, 0, 0 ) == 0
METHOD GoBottom() CLASS vfFileRead
hb_vfSeek( ::pHandle, 0, 2 )
::Skip( -1 )
::lEOF      := .T.
::lBOT      := .F.
::nCurrLine := ::nLastLine
RETURN FError() == 0
METHOD GoTo( nLine ) CLASS vfFileRead
Local nToSkip ,nIntStep, nPos
DEFAULT nLine := ::nCurrLine
IF !hb_isNumeric (nLine)
	RETURN Self
IF ABS ( nLine - ::nCurrLine ) >= ::nRecordsMapStep		//only if we skip by indexed steps
	nIntStep := ( INT( nLine / ::nRecordsMapStep ) + IF ( nLine % ::nRecordsMapStep < (::nRecordsMapStep / 2), 0, 1 ) ) * ::nRecordsMapStep
	DO WHILE nIntStep >= 0
		nPos := hb_AScan( ::aRecordsMap, { |x|  Bin2ULL ( ULLUnShrink ( x [ 1 ] ) ) == nIntStep } )
		IF nPos > 0
			::nCurrLine := Bin2ULL ( ULLUnShrink ( ::aRecordsMap [ nPos ] [ 1 ] ) )
			::SetPointer( Bin2ULL ( ULLUnShrink ( ::aRecordsMap [ nPos ] [ 2 ] ) ) )
			EXIT
		//Try with previous indexed step
		nIntStep -= ::nRecordsMapStep
	ENDDO
nToSkip := nLine - ::nCurrLine
DO CASE
	CASE hb_isNil( ::nCurrLine )			//We do not know the current line number, so start at the beginning of the file
		::GoTop()
		::Skip ( nLine - 1 )
	CASE nLine <= 1					//Line number less than 1, so start at the beginning of the file
		::GoTop()
	CASE hb_isNumeric( ::nLastLine ) .AND. nLine >= ::nLastLine		//Go beyond the known last line number, so go to the end.
		::GoBottom()
	CASE hb_isNumeric( ::nLastLine ) .AND. ::nLastLine - nLine < ABS ( nToSkip ) 	//We know the number of the last record, the nToSkip is greater than the difference between the last and the target record - so skip backward from the end (less skips)
		::GoBottom()
		::Skip( 0 - (::nLastLine - nLine ) )
	CASE nLine < 0 - nToSkip				//The target line is closer to the start than the nToSkip, so start at the beginning of the file.
		::GoTop()
	OTHER
		::Skip ( nToSkip )
ENDCASE
RETURN Self
METHOD Skip ( nSkip ) CLASS vfFileRead
Local cLine     := ""
Local lRun      := .T.
Local nSkips    := 0
Local nBuffSize := 64 * 1024	//::nReadSize  //A larger buffer speeds up the process
Local nLenDelim := Len (::cDelim)
Local nStart, nEnd, nBackOf, nPos, nPointer
Default nSkip   := 1
IF nSkip == 0
	RETURN Self
::lEOF := .F.
::lBOF := .F.
DO WHILE lRun
	IF nSkip > 0
		IF hb_vfEof( ::pHandle )
			::Skip ( -1 )
			::nLastLine := ::nCurrLine
			::lEOF      := .T.
			EXIT
		nStart   := 1
		nPointer := ::GetPointer()
		cLine    := hb_vfReadLen( ::pHandle, nBuffSize )
		DO WHILE Right (cLine, 1) $ ::cDelim .AND. !hb_vfEof( ::pHandle )		//Avoid splitting of end-of-line marks in the buffer.
			cLine += hb_vfReadLen( ::pHandle, nLenDelim )
		ENDDO
		DO WHILE ( nPos := hb_AT( ::cDelim, cLine, nStart ) ) > 0
			nSkips ++
			IF hb_isNumeric( ::nCurrLine )
				::nCurrLine ++
				IF ::nCurrLine % ::nRecordsMapStep == 0 .AND. hb_AScan( ::aRecordsMap, { |x|  Bin2ULL ( ULLUnShrink ( x [ 1 ] ) ) == ::nCurrLine } ) == 0
					AADD( ::aRecordsMap, { ULLShrink( ULL2Bin( ::nCurrLine ) ), ULLShrink( ULL2Bin( nPointer + nPos  + nLenDelim - 1 ) ) } )
			nStart := nPos + nLenDelim
			IF nSkips == nSkip
				hb_vfSeek( ::pHandle, 0 - ( Len ( cLine ) - nStart + 1), 1 )
				lRun := .F.
					::Skip ( -1 )
					::lEOF      := .T.
				EXIT
		ENDDO
	ELSE			// -skip
		IF ::GetPointer() == 0		//top of file
			::lBOF      := .T.
			::nCurrLine := 1
			EXIT
		cLine := ""
		DO WHILE ( nPos := hb_AT( ::cDelim, cLine ) ) == 0 .AND. hb_vfSeek( ::pHandle, 0, 1 ) <> 0		//Avoid splitting of end-of-line marks in the buffer.
			nBackOf  := Min( nBuffSize, ::GetPointer() )
			hb_vfSeek( ::pHandle, 0 - nBackOf, 1 )
			cLine    := hb_vfReadLen( ::pHandle, nBackOf ) + cLine
		ENDDO
		IF nPos == 0
			nPos := 1
		nStart := nPos
		cLine  := SubStr ( cLine, nStart )
		hb_vfSeek( ::pHandle, nStart - 1, 1 )
		nEnd     := Len( cLine )
		IF Right( cLine, nLenDelim) == ::cDelim
			nEnd -= nLenDelim
		DO WHILE (nPos := hb_RAT( ::cDelim, cLine, 1, nEnd ) ) > 0
			nSkips --
				::nCurrLine --
					AADD( ::aRecordsMap, { ULLShrink( ULL2Bin( ::nCurrLine ) ), ULLShrink( ULL2Bin( nPointer + nPos + nLenDelim -1 ) ) } )
			nEnd := nPos - 1		//nLenDelim
			IF nSkips == nSkip
				hb_vfSeek( ::pHandle, 0 + nPos + nLenDelim - 1 , 1 )
				lRun := .F.
				EXIT
		ENDDO
ENDDO
cLine := ''
RETURN Self
METHOD IsEOF() CLASS vfFileRead
IF !::lEOF .AND. hb_IsNumeric ( ::nCurrLine ) .AND. hb_IsNumeric ( ::nLastLine ) .AND. ::nCurrLine == ::nLastLine
	::lEOF := .T.
IF !::lEOF .AND. ::GetPointer() == ::GetLastLinePointer()
	::lEOF := .T.
RETURN hb_vfEof( ::pHandle ) .OR. ::lEOF
METHOD IsBOF() CLASS vfFileRead
RETURN ::GetPointer() == 0 .OR. ::lBOF
METHOD Error() CLASS vfFileRead
RETURN FError() != 0
METHOD ErrorNo() CLASS vfFileRead
RETURN ::nError
METHOD GetPointer() CLASS vfFileRead
RETURN hb_vfSeek( ::pHandle, 0, 1 )
METHOD SetPointer( nPointer ) CLASS vfFileRead
hb_vfSeek( ::pHandle, nPointer, 0 )
RETURN ::nError == 0
METHOD GetLastLinePointer() CLASS vfFileRead
Local nCurrentPointer := ::GetPointer()
Local nCurrentLine    := ::nCurrLine
Local lCurrentEOF     := ::lEOF
Local nLastLinePointer
::GoBottom()
nLastLinePointer := ::GetPointer()
::SetPointer ( nCurrentPointer )	//roll back pointer
::nCurrLine := nCurrentLine			//roll back ::nCurrLine
::lEOF := lCurrentEOF				//roll back ::lEOF
RETURN nLastLinePointer
METHOD CurrentLine() CLASS vfFileRead
RETURN ::nCurrLine
METHOD CountLines( xGauge ) CLASS vfFileRead
Local cLine       := ""
Local nLastPos    := hb_vfSeek( ::pHandle, 0, 2 )
Local nSkips      := 0
Local nlDelim     := Len ( ::cDelim )
Local nPrevPos    := 0
Local exCurrentGauge := ::exGauge
Local nPointer    := 0
Local nStart, nPos
IF HB_ISEVALITEM( xGauge )
	::exGauge := xGauge
::aRecordsMap := {}
::GoTop()
	nStart   := 1
		cLine += hb_vfReadLen( ::pHandle, nlDelim )
	ENDDO
	DO WHILE (nPos := hb_AT( ::cDelim, cLine, nStart )) > 0
		nSkips ++
		IF nSkips % ::nRecordsMapStep == 0
			AADD( ::aRecordsMap, { ULLShrink( ULL2Bin( nSkips ) ), ULLShrink( ULL2Bin( nPointer + nPrevPos - 1 /* pointer starts from 0 not from 1 like AT( ) */ ) ) } )
			IF HB_ISEVALITEM( ::exGauge )
				Eval( ::exGauge, nPointer + nPrevPos - 1, nLastPos, nSkips , 'Processing', Self )
		nStart   := nPos + nlDelim
		nPrevPos := nStart
	ENDDO
ENDDO
IF .NOT. Right( cLine, nlDelim ) == ::cDelim .AND. nLastPos > 0		//The last line does not end with a delimiter. Make it the last record.
	nSkips ++
	Eval( ::exGauge, nPointer + nPrevPos - 1, nLastPos, nSkips , 'Done', Self )
::nLastLine := nSkips
::exGauge   := exCurrentGauge
cLine := ""
RETURN nSkips
METHOD GetRecordsMap() CLASS vfFileRead
RETURN ::aRecordsMap
METHOD PutRecordsMap( aMap ) CLASS vfFileRead
IF aMap == NIL .OR. !hb_isArray( aMap )
	RETURN Self
::aRecordsMap := aMap
RETURN Self
Function ULLShrink( cBin )
RETURN REMRIGHT( cBin, CHR(0) )
Function ULLUnShrink( cBin )
RETURN PADRIGHT( cBin, 8, CHR(0) )
//Support Unsigned Long Long
#pragma BEGINDUMP
#include "hbapi.h"
#include "hbapiitm.h"
HB_FUNC( BIN2ULL )
   PHB_ITEM pItem    = hb_param( 1, HB_IT_STRING );
   HB_U64   uiResult = 0;
   if( pItem )
      HB_SIZE nLen = hb_itemGetCLen( pItem );
      if( nLen )
         const char * pszString = hb_itemGetCPtr( pItem );
         uiResult = HB_GET_LE_UINT64( pszString );
   hb_retnint( uiResult );
HB_FUNC( ULL2BIN )
   char   szResult[ 8 ];
   HB_U64 uiValue = ( HB_U64 ) hb_parnint( 1 );
   HB_PUT_LE_UINT64( szResult, uiValue );
   hb_retclen( szResult, 8 );
#pragma ENDDUMP
************************ THE END *********************
