HI
I completely rewrote the procedure adding new options and correcting any inaccuracies I found.
I tested the procedure daily for a few months until I reached an optimal level of efficiency.
If you are using a previous version, I recommend that you use this version.
Brunello
HMG_MYSYNC (New Version)
brunellopulix
- Img01.jpg (203.69 KiB) Viewed 6217 times
- HMG_MYSYNC.zip
- (324.52 KiB) Downloaded 201 times
Re: HMG_MYSYNC (New Version)
Hi Brunello,
Thanks for this new version
I saw that it's based upon the MiniGUI Ex now
brunellopulix
Hello
I'm sorry minor adjustments:
Procedure Main
FV3_Label('Leto Origin',70)
change to:
FV3_Label('Origin',70)
Procedure Start
before:
If aPaths[i,6] == 2
Zippy(cOrigin,cTarget)
change to:
FV3_SetProperty('ORIGIN','Value',cOrigin)
If aPaths[i,6] == 2
Brunello
Procedure Main
change to:
Procedure Start
before:
If aPaths[i,6] == 2
change to:
If aPaths[i,6] == 2
Brunello
- fouednoomen
Many thanks for your contribution , could you please sharing executable file .
brunellopulix
- fouednoomen
Hi Brunello ,
Many thanks for you sharing files
Could you please explain to me step by step what I must change
in GFC.INI and. MYIP.TXT, can not understand you readme file
I work with Letodbf on a public ip adresse
Best regards
Foued Noomen
Best regards
Foued Noomen
brunellopulix
CFG.INI:
-you need to update your IP (not important)
MYIP.TXT:
-you must enter the LETO server data in each line at the end enter the server port and then the end note with / *
example:
//192.168.1.100:2812/ /* My PC
or:
//192.168.1.101:2812/ /* PC1-HOME
//192.168.1.102:2813/ /* PC2-HOME
//192.168.1.103:2814/ /* PC3-HOME
IPs can be public
remember:
your leto server needs them for Minigui Ext
MYIP.TXT:
example:
or:
IPs can be public
remember:
