Illegal characters in filename
Hello,
Sometimes I rename a DBF file with a dash like: OLD-FILE.dbf
When accessing this file it will give this runtime error: Illegal characters in alias: OLD-FILE.
How can I avoid or suppress this error?
Re: Illegal characters in filename
Hi Serge
See if it works with -> OLD_FILE.dbf ?
Greetings
Hi Mustafa,
Yes, underscores are no problem!
Problem occurs when renamed by mistake with a dash (or maybe with some other illegal character).
So, I want to suppress "runtime error: Illegal characters in alias" by skipping these. Now I check if a dash is in the filename but there maybe others illegal chars....
franco
Post by franco »
Hi Serge
Are you renaming inside a program or from (cmd or windows)
If from a program you could create a function to check for or remove illegal characters with chr() and asc() codes.
All The Best,
Franco
Canada
Renaming has happened outside a program and mostly not by me...
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Post by Claudio Ricardo »
Hi... i use this function to prevent invalid dbf field names:
// Función ValidFieldName () Comprueba si el nombre ingresado es valido para campos DBF (retorna .T.)
// Creada por Claudio Ricardo 03/2021
Function ValidFieldName (cCadena)
LOCAL cValid := .T.
LOCAL i
	If ValType (cCadena) <> "C"
		Return .F.
	EndIf
	If SubStr (cCadena,1,1) $"0123456789" .OR. Len (cCadena) > 10
		Return .F.
	EndIf
	For i = 1 To Len (cCadena)
		If ! Lower ( SubStr (cCadena,i,1)) $"abcdefghijklmnopqrstuvwxyz0123456789_"	// lista de caracteres permitidos
			cValid := .F.
		EndIf
	Next
Return cValid
With small modification it is used for table names.
serge_girard wrote: Wed Nov 17, 2021 4:24 pm How can I avoid or suppress this error?
have you try
USE OLD-FILE.dbf ALIAS "OLDFILE"
Thanks Jimmy,
That's the solution ! Because of the nature of my program the 'USE' is in a loop from a DIR function
and my USE is this construction:
IF lOpenMode
    if cNew = 'NEW'
       USE ( cDatabase ) EXCLUSIVE  NEW ALIAS cALIAS
       USE ( cDatabase ) EXCLUSIVE ALIAS cALIAS
    if cNew = 'NEW'
       USE ( cDatabase ) SHARED NEW ALIAS cALIAS
       USE ( cDatabase ) SHARED ALIAS cALIAS
IF !NETERR()
   RETURN ( TRUE )
This now works perfect! Thanks again!
same is when try to open "1234.DBF"
it will crash while ALIAS() "1234" is not valid
but it work with
   USE 1234.DBF ALIAS "ONE"
p.s. this Way i can use Chinese Name of DBF
Yes, I know! I replace cALIAS with 'xxxx'.
