Problemas en UCI
luisvasquezcl
Problemas en UCI
Post by luisvasquezcl »
Estimado,
me arroja un error con la propiedad widths; el contenido del archivo browseado.uci es el siguiente:
BROWSEADO.UCI
[Properties]
Name
Row
Col
Width
Height
Headers
Fields
Readonlyfields
Recordset
Lock
Position
Valid
ValidMessages
NoVScrollBar
Widths
[Events]
On Change
ERROR
Error BASE/1003 No existe la variable: BrowseAdo_1Widths
Called from __MVGET(0)
Called from UPDATECONTROLPROPERTIES(28229)
Called from SELECTCONTROL(4568)
Called from (b)_OPEN(14938)
Called from _DOCONTROLEVENTPROCEDURE(4735)
Called from EVENTS(1374)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4423)
Called from DOMETHOD(7224)
Called from _OPEN(25747)
Called from EDITFILE(29644)
Called from (b)MAIN(1197)
Called from EVENTS(1553)
Called from _ACTIVATEWINDOW(4377)
Called from MAIN(1305)
Saludos cordiales,
Luis Vasquez
Re: Problemas en UCI
luisvasquezcl wrote:Estimado,
BROWSEADO.UCI
[Properties]
Name
Row
Col
Width
Height
Headers
Fields
Readonlyfields
Recordset
Lock
Position
Valid
ValidMessages
NoVScrollBar
Widths
[Events]
On Change
ERROR
Saludos cordiales,
Luis Vasquez
Verified.
I'll check it ASAP.
Thanks for reporting.
Roberto.
I've fixed.
I'll publish a new IDE release containing the fix ASAP.
