IP Publica
Mario Mansilla
IP Publica
Hola Amigos :
necesito implementar con HMG una aplicacion que me vizualize la IP publica de la pc donde estoy conectado .
Tiene Harbour funciones que me permitan realizar esto ? .
De lo contario alguien conoce una aplicacion externa que me permita obtener esta informacion .
Saludos cordiales
Mario Mansilla
Hello friends :
I need to implement with HMG an application that will visualize the public IP of the pc where I am connected.
Does Harbor have functions that allow me to do this? .
Otherwise someone knows an external application that allows me to obtain this information.
Best regards
Mario Mansilla
Saludos cordiales
Mario Mansilla
Hello friends :
Best regards
Mario Mansilla
Re: IP Publica
Hola Mario
Quizá esto te de una pista de como hacerlo con HMG
Hello Mario
Maybe this gives you a clue on how to do it with HMG
viewtopic.php?f=24&t=3488&p=32282&hilit ... ezl#p32282
Hello Mario
Re: IP Publica
Hi Mario,
There are different ways to get the Public IP:
You can use the following code:
function main
local cInternetIP := Ip_Externo()
cInternetIP := iif("Site" $ upper(cInterNetIP),cInterNetIP,;
"Internet IP is: "+cInterNetIP)
if file("init.cld")
REQUEST HB_GT_WIN_DEFAULT
DEFINE WINDOW Win_1 ;
WIDTH 300 ;
HEIGHT 170 ;
TITLE 'Internet IP Address' ;
MAIN ;
NOSIZE ;
NOMAXIMIZE ;
TOPMOST
@ 30,25 LABEL label_1 of Win_1 VALUE cInternetIP ;
WIDTH 250 ;
BORDER ;
BOLD ;
font "Arial" SIZE 11 ;
CENTERALIGN ;
CLIENTEDGE ;
TOOLTIP "Your internet IP"
@ 80,90 BUTTON button_1 of Win_1 CAPTION "Ok " ACTION Win_1.Release ;
TOOLTIP "Click OK to exit"
Win_1.Center
ACTIVATE WINDOW Win_1
return NIL
FUNCTION IP_EXTERNO()
local url, html, vRet := " ",oError
url := "http://checkip.dyndns.org/" //'http://meuip.datahouse.com.br/ automation.whatismyip.com/n09230945.asp'
TRY
html:= ReadPage_ler( url )
memowrit(GetMyDocumentsFolder()+"\InterNetIPInfo.html",dtoc(date())+" "+time()+" ["+html+"]")
vRet := PegaIP_ex(html) //vRET:= html //
CATCH oError
MsgBox(oError:Description,"Error:")
vRet := "Error In Connecting."
END
RETURN iif(empty(vRET),"Site Not Reachable!",vRet)
FUNCTION PegaIP_ex(cHtml)
LOCAL Pos, PosF
Pos := At(':', Upper(cHtml) )
IF Pos < 1
RETURN 0
* Pos += Len('IP?')
cHtml := subst( cHtml, Pos+1 )
PosF := At('<',Upper(cHtml)) - 1
cHtml := Subst(cHtml,1,PosF)
RETURN alltrim(cHtml)
FUNCTION ReadPage_ler( cUrl )
LOCAL oUrl, oCli, cRes := ''
BEGIN SEQUENCE
oUrl = TUrl():New( cUrl )
IF EMPTY( oUrl )
BREAK
oCli = TIpClientHttp():New( oUrl )
IF EMPTY( oCli )
BREAK
oCli:nConnTimeout = 20000
IF !oCli:Open( oUrl )
BREAK
cRes := oCli:Read()
oCli:Close()
END SEQUENCE
RETURN cRes
HTH,
Warm regards,
Jayadev
function main
if file("init.cld")
WIDTH 300 ;
HEIGHT 170 ;
MAIN ;
NOSIZE ;
NOMAXIMIZE ;
TOPMOST
WIDTH 250 ;
BORDER ;
BOLD ;
CENTERALIGN ;
CLIENTEDGE ;
Win_1.Center
return NIL
TRY
CATCH oError
END
LOCAL Pos, PosF
IF Pos < 1
RETURN 0
* Pos += Len('IP?')
BEGIN SEQUENCE
IF EMPTY( oUrl )
BREAK
IF EMPTY( oCli )
BREAK
BREAK
cRes := oCli:Read()
oCli:Close()
END SEQUENCE
RETURN cRes
HTH,
Warm regards,
Jayadev
Re: IP Publica
This was some code I had found on the net, which I have modified to suit my purpose. Credit is due to the Author of the code.
Warm regards,
Jayadev
Warm regards,
Jayadev
Mario Mansilla
Re: IP Publica
Hola Jayadev :
muchas gracias por tu repuesta , no puedo hacer funcionar tu codigo .
Te envio mi proyecto hecho con el IDE de HMG 3.4.4.
No se que error estoy cometiendo
Mario Mansilla
Mario Mansilla
- IP.rar
- (8.99 KiB) Downloaded 290 times
Re: IP Publica
Bueno, despues de todo no fué tan dificil...
Well, after all it was not so difficult ...
LOCAL cURL := "https://api.ipify.org/?format=json"
DEFINE WINDOW Main AT 138 , 235 WIDTH 550 HEIGHT 350
@ 070,160 LABEL Label_1 OF Main VALUE "" WIDTH 200 HEIGHT 25 FONT "Consolas" SIZE 14 ;
FONTCOLOR { 70, 130, 180 } BACKCOLOR { 210, 233, 255 } BORDER CENTERALIGN
Main.Label_1.Value := SaveURL( cURL )
Main.CENTER
Main.ACTIVATE
Return nil
Function SaveURL( cUrl )
LOCAL cTmpFile := "x.htm", cHtml
IF URLDownloadToFile( cUrl, cTmpFile)
cHtml := HB_MemoRead( cTmpFile )
cHtml := STRTRAN( cHtml, "{", "" )
cHtml := STRTRAN( cHtml, "}", "" )
cHtml := STRTRAN( cHtml, '"', "" )
Return cHtml
#pragma BEGINDUMP
#include "HMG_UNICODE.h"
#include <Windows.h>
#include <urlmon.h>
#include "hbapi.h"
HB_FUNC( URLDOWNLOADTOFILE )
HRESULT hr = URLDownloadToFile(NULL, HMG_parc(1), HMG_parc(2), 0, NULL);
hb_retl(hr == S_OK);
#pragma ENDDUMP
Re: IP Publica
//bpd2000
Function Main()
msginfo( ExternalIP(),"External IP Address"+space(10))
Function ExternalIP()
Local cApiUrl := "http://checkip.dyndns.com/"
LOCAL nStart, nLen
oGoogle := Win_OleCreateObject( "MSXML2.ServerXMLHTTP" )
BEGIN SEQUENCE WITH {|o| break(o)}
oGoogle:Open( "GET", cApiUrl, .F. )
oGoogle:SEND()
cGoogleResp := oGoogle:ResponseBody()
Ext_IP := HB_AtX( "[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+", cGoogleResp, .F., @nStart, @nLen )
IF oGoogle:Status != 200
BREAK
RECOVER
MsgStop("ERROR! ")
RETURN nil
END SEQUENCE
oGoogle:Abort()
RETURN Ext_IPBPD
Mario Mansilla
Re: IP Publica
Hola Amigos :
ahora ya tengo varias opciones .
Muchas gracias a todos
Saludos cordiales
Mario Mansilla
Hello friends :
Now I have several options.
Thank you very much to all
Best regards
Mario Mansilla
Saludos cordiales
Mario Mansilla
Hello friends :
Best regards
Mario Mansilla
- AUGE_OHR
Re: IP Publica
but i don´t understand Error as HB_FUNC is include and it have "A" and "W" of "URLDownloadToFile"
https://docs.microsoft.com/en-us/previo ... dfrom=MSDN
what do i make wrong
i have try Sample but i got Errprandyglezl wrote: ↑Tue Jul 03, 2018 5:07 amCode: Select all
HB_FUNC( URLDOWNLOADTOFILE ) { HRESULT hr = URLDownloadToFile(NULL, HMG_parc(1), HMG_parc(2), 0, NULL);
! Note i use Unicode Versionundefined reference to `URLDownloadToFileW'
Re: IP Publica
AUGE_OHR wrote: ↑Fri Nov 12, 2021 3:01 am hi,i have try Sample but i got Errprandyglezl wrote: ↑Tue Jul 03, 2018 5:07 amCode: Select all
HB_FUNC( URLDOWNLOADTOFILE ) { HRESULT hr = URLDownloadToFile(NULL, HMG_parc(1), HMG_parc(2), 0, NULL);! Note i use Unicode Versionundefined reference to `URLDownloadToFileW'
what do i make wrong![]()
Incluiste el archivo MainIPPub.hbp ?
Hace rato lo probé y funcionó.
Did you include the MainIPPub.hbp file?
I tried it a while ago and it worked.
