grid performance
carlazza
grid performance
Post by carlazza »
hi all,
this is my first post, so i apologize in advance if i write something wrong.
I detect a strong slowdown when loading a grid.
Is there any way to understand where and why the executable is slowing down in performance?
Thanks Carlo
Re: grid performance
are you using DBF or Array ?
Network or LOCAL ?
i guess DBF so next Question : do you use "FILTER" ?
in Network, working on same DBF, will slow down
when using Image in Grid it will slow down
so please more Information
carlazza
Post by carlazza »
I'm using array in local. no images.
I've included the grid loading in a function. At the first access, the grid works fine.
In following ones, the grid loads very slowly
In the load function, firstly I check if grid exists, delete and define, else only define
Please see the attachment.
When you want to browse arrays, use VIRTUAL GRID, it's really speedy.
carlazza
Post by carlazza »
can you explain it better please?
when you're defining GRID control, you can use VIRTUAL as .T.
You must define OnQueryData procedure which distributes data to GRID control to display it.
See examples in hmg344\samples\controls\grid
carlazza
Post by carlazza »
I thank you but it is too difficult for my knowledge
hi
it is realy easy to use VIRTUAL with GRID
lets talk about Sample \SAMPLES\Controls\Grid\GRID_02\demo.prg
		VIRTUAL ;
		ITEMCOUNT 100000000 ;
		ON QUERYDATA QueryTest()
VIRTUAL -> enable Virtual ( LVN_GETDISPINFO )
ITEMCOUNT -> max. Lenght -> LEN(Array)
ON QUERYDATA -> Procedure to "show" Data
Procedure QueryTest()
	This.QueryData := Str ( This.QueryRowIndex ) + ',' + Str ( This.QueryColIndex )
have a look in Help File for GRID and look for "This"
Properties Available For OnQueryData Procedure:
- This.QueryData
- This.QueryRowIndex
- This.QueryColIndex
This.QueryData -> "Result" Data of Cell in a GRID
come from right side
This.QueryRowIndex -> ROW of Data
This.QueryColIndex -> COL of Data
so Procedure QueryTest() use "Information" of "This" to display Data of GRID
! Note :
while that Part of Code are need for every Cell do not put too much Code into QueryTest() if you want to "manipulate" Data
carlazza
Post by carlazza »
Thanks
I will try asap
carlazza
Post by carlazza »
done. now it's faster than before
but, if I use the Virtual command, the checkbox disappears. Why?
  	DEFINE GRID GRD1
	        PARENT CDL1
			ROW 145
			COL  20
			WIDTH 830
			HEIGHT 800
			HEADERS { 'MATRICOLA', 'COGNOME', 'NOME', 'DATA NASCITA', 'CATEGORIA', 'NREC'}
			FONTSIZE 11
			FONTBOLD .t.
			WIDTHS { 120, 200, 200,135,153,0}
			ITEMS  AISCRITTI
                        BACKCOLOR {03, 119, 127}
			FONTCOLOR WHITE
			ALLOWSORT  .T.
			VALUE posrec
			CHECKBOXES .T.
			VIRTUAL .t.
                        ON CHANGE LoadData(This.Item(this.value))
			ON DBLCLICK ENABLEFIELD()
			ON QueryData QueryTest()
	END GRID
function QueryTest()
   local x := this.queryrowindex
   local y := this.querycolindex
   this.querydata := aiscritti[ x, y ]
return nil
