Redirect F1 key and define maximized window
Hi guys!
I'm wonder if is the way t o redirect F1 key in whole application to another function tha windows help procedure.
I know I can use SET KEY F1.... but it must be used separately for every defined window.
And second question.
How to define maximized window to whole screen?
We can maximize it after definition, but it causes flickering
edk
Re: Redirect F1 key and define maximized window
Post by edk »
Hi Marek.
mol wrote: Fri Oct 15, 2021 12:38 pm Hi guys!
Without change in sources, I think there's probably no other way.
mol wrote: Fri Oct 15, 2021 12:38 pm And second question.
I do this in that way:
#define SM_CXFRAME	32
#define SM_CYFRAME	33
Local nXSizeFrame := GetSystemMetrics( SM_CXFRAME )
Local nYSizeFrame := GetSystemMetrics( SM_CYFRAME )
Public nMaximizedWindowCol    := 0 - nXSizeFrame
Public nMaximizedWindowRow    := 0 - nYSizeFrame
Public nMaximizedWindowWidth  := GetDesktopRealWidth()  + nXSizeFrame * 2
Public nMaximizedWindowHeight := GetDesktopRealHeight() + nYSizeFrame * 2
		AT nMaximizedWindowRow, nMaximizedWindowCol ;
		WIDTH nMaximizedWindowWidth ;
		HEIGHT nMaximizedWindowHeight ;
		TITLE 'Demo' ;
edk
Post by edk »
edk wrote: Fri Oct 15, 2021 7:52 pm
But I was wrong, we can do it by using a trick with Create Event :mrgreen: :idea:
Local nEventIdx
		TITLE 'Window1' ;
		ON KEY F2 ACTION MsgInfo("F2 key pressed")
		@  2,10 LABEL Label_1 ;
			WIDTH 100 HEIGHT 20 ;
			VALUE 'Press F1' ;
			ACTION HMG_PressKey ( VK_F1 )
		@  2,120 LABEL Label_2 ;
			VALUE 'Press F2' ;
			ACTION HMG_PressKey ( VK_F2 )
		@ 30,10 BUTTON Button_1 ;
			CAPTION 'Window 2' ;
			ACTION Window2() ;
			TOOLTIP 'WINDOW 2'
		@ 70,10 BUTTON Button_2 ;
			CAPTION 'Release' ;
			ACTION ThisWindow.Release
	CREATE EVENT PROCNAME F1_KEY_TRAP() STOREINDEX nEventIdx
Procedure WINDOW2()
	IF isWindowDefined( Form_2 )
		DoMethod('Form_2','SetFocus')
		DoMethod('Form_2','Restore')
	DEFINE WINDOW Form_2 ;
		TITLE 'Window2'
			VALUE 'Press F1' ;
			CAPTION 'Release' ;
	ACTIVATE WINDOW Form_2
FUNCTION F1_KEY_TRAP()
LOCAL  nHWnd := EventHWND ()
LOCAL  nMsg := EventMSG ()
//LOCAL  nWParam := EventWPARAM ()
//LOCAL  nLParam := EventLPARAM ()
LOCAL  cFormName
#define WM_ACTIVATE    6
IF nMsg = WM_ACTIVATE
	cFormName := GetFormNameByIndex(GetFormIndexByHandle( nHWnd ))
	ON KEY F1 OF &(cFormName) ACTION MsgInfo("FormName: " + ThisWindow.Name + CRLF + ;
						 "Form Title: " + ThisWindow.Title + CRLF + ;
						 "width :=" + AllTrim( hb_ValToStr(ThisWindow.Width) ) + CRLF + ;
						 "height:=" + AllTrim( hb_ValToStr(ThisWindow.Height) ) + CRLF + ;
						 "row   :=" + AllTrim( hb_ValToStr(ThisWindow.Row) ) + CRLF + ;
						 "col   :=" + AllTrim( hb_ValToStr(ThisWindow.Col) ) )
EndIF
edk
Post by edk »
Marek, try this simple trick: define the window as NOSHOW and ON INIT define the "Maximize" and "Show" methods, example:
		AT 50, 50 ;
		WIDTH 400 ;
		HEIGHT 300 ;
		TITLE 'Demo Maximized' ;
		MAIN ;
		NOSHOW ;
		ON INIT ( ThisWindow.Maximize, ThisWindow.Show )
