How to include specific items like a record or line number, in your error handler
HGAutomator
Post by HGAutomator »
For an error handler for one specific function, I'd like to provide some environmental information at the time of the error.
For example, I'm using the HB_FUse() functions to loop through a text file. If there's an error processing one of the lines, I'd like to send hb_FRecNo() into the error log.
Is there a way to do that?
Re: How to include specific items like a record or line number, in your error handler
you can use a own Error-Handler and "RECOVER USING" to log Error ( or react on it )
   nHandle := FCreate(cOutDir + "ErrLog.TXT")
   FOR i := 1 TO iMax
      bError := ERRORBLOCK( { | object | BREAK( object ) } )
      BEGIN SEQUENCE
         // Action -> Error
      RECOVER USING oError
         cError := "ERROR: " + oError:description + ;
                    IIF( EMPTY( oError:operation ), "", ;
                    HB_OSNEWLINE() + oError:operation ) + ;
                    HB_OSNEWLINE()
         cError += oError:subsystem + "/" + ALLTRIM( STR( oError:subcode ) ) + ;
                    " (generic code " + ALLTRIM( STR( oError:genCode ) ) + ;
                    ", os code " + ALLTRIM( STR( oError:osCode ) ) + ")" + ;
                    HB_OSNEWLINE()
         ERRORBLOCK( bSaveError )
         FWrite( nHandle, cError + CRLF )
      END SEQUENCE
   FClose( nHandle )
HGAutomator
So it's that easy?
Thanks Auge, I thought this was going to involve some cargo property, now I'm really glad I asked on the forum first.
Much appreciated,
HGAutomator
I was just looking at it more closely, and there doesn't seem to be anything unique about the snippet.
Sorry, I don't see how we would send the error block anything outside of the error object and its properties.
Whether we send it to a log or just display it on the screen with a simple Try Catch, I'm just looking for a way to include external information.
For example, the line number of the text file that was in use. Or the nth field that we're extracting from the text file before the error occurred.
In other words, not just the properties in the Error object, but other variables that were in place at the time of the error, which could make the reason for the error more explicit to the end user.
What I do is following:
// xDEFAULT is DRIVE+PATH+...
ZX_ERR_MEMORY = xDEFAULT + '\ERROR.MEM'
SAVE ALL TO &ZX_ERR_MEMORY
memhandle := FOPEN( ZX_ERR_MEMORY, pOPEN_READWRITE )
memlength := FSEEK( memhandle, 0, pSEEK_EOF )
FSEEK( memhandle, 0 )
count := 1
bytes := 0
vars	:= 0
atemp	:={}
? '<table border="1">'
? '<tr><th bgcolor="#00ff00">#</th><th bgcolor="#00ff00">Bytes</th><th bgcolor="#00ff00">Var Name</th><th bgcolor="#00ff00">Type</th><th bgcolor="#00ff00">Value</th></tr>'
tel = 0
DO WHILE FSEEK( memhandle, 0, pSEEK_CURRENT ) + 1 < memlength
	memwidth := SPACE(18)
	FREAD( memhandle, @memwidth, 18)
	vname := LEFT(memwidth, AT( CHR(0), memwidth) -1 )
	vtype := SUBSTR(memwidth, 12, 1)
	vrec  := BIN2W(RIGHT(memwidth,2))
	IF ( vtype $ CHR(195) + CHR(204), memcount := 14 + vrec, memcount := 22 )
	FSEEK( memhandle, memcount, pSEEK_CURRENT )
	IF LEFT( vname, 1) # "_"
		tel++
		ttemp1 := vname	//LEFT( vname + SPACE(10), 10)
		ttemp2 := TYPE(vname)
		ttemp3 := IF(TYPE(vname) = pCHARACTER, "[" + &vname. + "]", strvalue( &vname.) )
		DO CASE
		CASE TYPE(vname) = pCHARACTER
			bytes += ( atemp := LEN( &vname. ) )
		CASE TYPE(vname) = pNUMERIC
			bytes += ( atemp := 9 )
		CASE TYPE(vname) = pLOGICAL
			bytes += ( atemp := 2 )
		CASE TYPE(vname) = pDATE
		OTHERWISE
			bytes += ( atemp := 0 )
		ENDCASE
		/* SUPPRESS DB AND FTP INFORMATION : don't want to mention secret password etc.... '*/
		IF AT('PW',   UPPER(ttemp1)) > 0 .OR. ;
		   AT('USER', UPPER(ttemp1)) > 0 .OR. ;
		   AT('SITE', UPPER(ttemp1)) > 0 .OR. ;
		   AT('HOST', UPPER(ttemp1)) > 0 .OR. ;
		   AT('PASW', UPPER(ttemp1)) > 0 .OR. ;
		   AT('DB',   UPPER(ttemp1)) > 0
			? '<tr>'
			? '<td style="text-align:right;">' + TRANSFORM( tel, "999") + '</td><td style="text-align:right;">' + TRANSFORM( atemp, "9999999") + '</td><td>' + ttemp1 + '</td><td>' + ttemp2 + '</td><td>' + substr(ttemp3,1,100) + '</td>'
			? '</tr>'
ENDDO
? '<tr><td bgcolor="#00ff00" colspan=2 style="text-align:right;">' + TRANSFORM( bytes, "9,999,999") + '</td><td  bgcolor="#00ff00" colspan=3>Totaal</td></tr>'
? "</table>"
FCLOSE( memhandle )
This will surely help you a bit....
HGAutomator wrote: Fri Oct 08, 2021 2:52 am For example, the line number of the text file that was in use. Or the nth field that we're extracting from the text file before the error occurred.
Ok, got it
i wanted to show a general Way to "react" on Error.
i do read TEXT File with MEMOREAD and use MLCOUNT() / MEMOLINE()
FUNCTION ReadTXTfile( cFilename )
LOCAL cText     := MemoRead( cFilename )
LOCAL nMaxLines := MlCount( cText, 80 )
LOCAL aLines[ nMaxLines ], n
   FOR n:=1 TO nMaxLines
      BEGIN SEQUENCE
         cLine := Trim( MemoLine( cText, 80, n ) )
         // we are in "this" Errorblock when Code is execute
         IF .NOT. CheckIt(cLine])
           BREAK
         aLines[ n ] := cLine
         lError := .T.
      END SEQUENCE
      IF lError = .T.
         OutPut2Screec("Error Line ",STR(n),a,b,c,d ... )
      lError := .F.
RETURN aLines
so it is just a Concept to handle Error Problem
I'm also sending e-mail message to me from application when error occurs.
In this way I can quickly react and analyze error
Marek, Me too !
Happens happily very seldom!
HGAutomator
Hi mol,
Yep, I do the same thing for our VBScripts. Should start doing it for the Harbour stuff as well.
Sub udfs_SendErrorMessage( Subject_s, ErrorNumber, ErrorDescription, ErrorSource )
Dim Email_From_s
Dim Email_To_s
Dim Email_o
Dim Error_s
Error_s = Subject_s & ", Error: " & ErrorDescription & ", Error Number: " & ErrorNumber
On Error Resume Next
Set Email_o = CreateObject("CDO.Message")
Email_o.From = NOREPLY_ERRORSTATUS
Email_o.To = SUPPORT_EMAIL
Email_o.CC = PROD_SUPPORT_TEXT
Email_o.ReplyTo = NOREPLY_ERRORSTATUS
Email_o.Subject = Subject_s
Email_o.Textbody = Error_s
Email_o.Configuration.Fields.Item _
    ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
    ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = _
        SMTP_SERVER
    ("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = SMTP_SERVER_PORT
Email_o.Configuration.Fields.Update
Email_o.Send
If Err.number <> 0 Then
	ErrorNumber = Err.number
	ErrorDescription = Err.Description
	ErrorSource = Err.Source
	Err.Clear
	Call udfs_LogError( Subject_s, ErrorNumber, ErrorDescription, ErrorSource )
End If
Set Email_o = Nothing
End Sub
mol wrote: Fri Oct 08, 2021 11:10 am I'm also sending e-mail message to me from application when error occurs.
HGAutomator
Thanks Serge,
There's no problem generating the log file. I just want to include items that are normally not part of the error object. Auge answered this, and it looks doable.
serge_girard wrote: Fri Oct 08, 2021 9:04 am What I do is following:
count := 1
bytes := 0
vars	:= 0
atemp	:={}
tel = 0
		tel++
		DO CASE
		OTHERWISE
		ENDCASE
			? '<tr>'
			? '</tr>'
ENDDO
? "</table>"
FCLOSE( memhandle )
