Registry CLASS from Thomas Braun for harbour / HMG
i had Problem with HMG / Extended Version to get a "valuelist" of Registry when have only "Standard"
so i try my "old" Xbase++ Code from Thomas Braun and re-wrote it to Unicode to use it with HMG
include Sample to get Location of Outlook.PST File when PST File was move to "other" Location than default.
Registry CLASS from Thomas Braun was made for Xbase++
that´s why i need to include
libs=hbxpp.hbc      // C:\hmg.3.4.4\HARBOUR\contrib\hbxpp\hbxpp.hbc
REGCLASS.ZIP
(35.71 KiB) Downloaded 132 times
have a look at REGCLASS.ZIP\Note\test.prg which show how to "move" in Registry to navigate "up/down"
! Note : it include some Xbase++ Code so delete that Part of Code to run it under harbour / HMG
Re: Registry CLASS from Thomas Braun for harbour / HMG
Hi Jimmy!
I need to enumerate serial ports in system.
I'm trying to use your code, but I can't compile it.
Can you write to me, how to do it?
Marek
hi Mol,
mol wrote: Wed Oct 06, 2021 7:32 pm I'm trying to use your code, but I can't compile it.
does Demo "not compile" our your modify Code ?
i need to "see" Registry to understand what you need.
RegClass from Thomas Braun can "navigate" in Registry
RegClass have Method MoveUp, MoveDown and KeyList
KeyList give you Array of all Item in "Sub-Dir"
in REGCLASS.ZIP you will find \Note\reghelp.prg which have some Function like
Function EnumKey(cKey, Index)
Function EnumValueKey(cKey, Index)
Function EnumValue(cKey, Index)
also have a look into \Note\Article.doc
if you need more help i need "SnapShot" of Registry where you want to "start"
mol wrote: Thu Oct 07, 2021 2:03 pm I need to get list of COM ports installed in system
Mol ya viste esto ?
Mol, did you see this?
https://www.hmgforum.com/viewtopic.php? ... ezl#p34899
http://www.hmgforum.com/download/file.php?id=4263
now i understand your Question about "Serial Port"
my Problem : i have no "active" PC with "Serial Port" so no Entry in Registry
also my WMI "Generator" fail while Hardware does not exist
for WMI you can use "WMI Code Creator v1.0"
https://www.microsoft.com/en-us/downloa ... px?id=8572
it can create Code (not xBase ) where you can "see" all available Property
than you can "translate" it easy to xBase World
