Windows 11
Windows 11
Hello,
Anybody knows if by HMG generated executables will run on the new Windows 11 OS?
Red2
Re: Windows 11
Post by Red2 »
Hi Serge
Last month I installed the generally available pre-release copy of Windows 11 on a spare drive. My Intel CPU is short of the minimum 8th generation that the release OS will require. (Mine is 7th generation).
To your specific question, I ran one HMG utility program that I had compiled under Windows 10. It ran fine under this Windows 11 OS.
I also loaded HMG 3.5 onto this drive. I was then able to work on, compile, and run my project without any apparent issues.
My limited experience with this “early” Windows 11 suggests that HMG and Windows 11 may be generally compatible. Note: My testing was in no way exhaustive. Hope this is helpful.
Kind regards,
Red2
Re: Windows 11
Thanks Red2, hope to hear some more experiences!
PeteWG
Re: Windows 11
Post by PeteWG »
serge_girard wrote: Mon Oct 04, 2021 10:59 am Anybody knows if by HMG generated executables will run on the new Windows 11 OS?
Hi Serge,
Very reasonable your question, however, before this, we have to answer another more basic question:
Can windows 11 run on our PCs?
for the history: a not so aged Dell tablet (intel i5 with 8GB RAM, 256GB SSD and windows 10,
running flawlessly and everything), is not regarded as much a good candidate to run this marvellous OS.
After running the (so called) `Health Check` (!), Ms, very seriously, opined that this poor thing is "incapable
to run new windows and if I still want to enter the brave new world of 11's, I must go buy a new machine."
``Oh, really?``
(by the way, I didn't even try to check my old xeon workstation. I was sure the comment by the `Health Check`
would be much more... insulting, and then i would have to reply in the same way... :))
regards,
Pete
Re: Windows 11
Many people believe that one of the main problems is the requirement that the hardware must have a TPM chip, which is not present in many of the PC that are currently in use.
Re: Windows 11
when 1st Windows 11 was present in Windows Insider DEV Channel i have ask for 32 Bit OS ... but it was Cancel :(
my "Mini-PC" does not have TPM ... which also can be used for "Secure Pay" e.g in M$-Store.
you can install Windows 11 "without" TPM / Secure Boot but i guess those "Hacks" will not work when you want to "Secure Pay" from your PC in Future.
using TPM you can "identify" PC for "Online-Banking" so it will be a "must have"
when i got 1st Windows 11 "leak" i was surprise ... not hear about it before. :o
but some Days later M$ "Official" spread it in DEV Channel and talk about "Release" ... :roll:
as i have used all Windows 10 Build from DEV Channel (each Week 3 GB)
it seem me a "early Bird" to "Release" Windows 11 now ... just after 3 x Upgrades in DEV Channel.
OK, most BUGs i found have be (Quick) fixed by M$ but i have not test it in Network with Server 2021 yet.
now "all" can "test" Windows 11 "Release", when Hardware is "ready", and there Apps and Games
IMHO it will take some Time until M$ fix all those BUGs of Windows 11 ...
as Developer i have bought a new Ryzen 4650G to "test-drive" Windows 11 ... before Customer switch to 11 and ask me "how" ...
Re: Windows 11
Thanks all for sharing opinions and experiences !
I will wait for a stable solution....
gfilatov
Re: Windows 11
Post by gfilatov »
srvet_claudio wrote: Wed Oct 06, 2021 1:57 am Hi,
Hi Claudio,
Yes, it is a main problem.
BTW I've installed Windows 11 on my unsupported notebook which have the following configuration according to Minigui SysInfo utility:
System Information version 1.10
Computer: ADMIN () - Administrator
Processor: Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz [~2400 MHz]
Bios: DELL - 1072009 (07/14/15)
Motherboard:
RAM: 8103 MB (8297472 KB)
Hard disks: 952982.33 MB (free 881640.12 MB - 92%)
C: 153115.33 MB (free 85387.67 MB - 55%)
D: 799867.00 MB (free 796252.45 MB - 99%)
Removed disks:
CD-ROM: E:
Video card:
Sound card: Audio Intel(R) for displays
Network card: WAN Miniport (Network Monitor)
KeyBoard: Standard PS/2 Keyboard
Mouse: PS/2 Compatible Mouse
Monitor: Generic PnP Monitor, 1366x768x32 bits
Modem:
Printers: OneNote for Windows 10 Microsoft XPS Document Writer Microsoft Print to PDF Fax
OneNote for Windows 10 (network printer)
Microsoft XPS Document Writer (network printer)
Microsoft Print to PDF (network printer)
Fax (network printer)
IP address: 192.168.3.110
OS: Microsoft Windows 11 Home Single Language 21H2 (Build 22000.282)
Notes:
Saturday, 23.10.2021 21:44
and I had a positive impression from Win 11 look and feel. 8-)
Re: Windows 11
Thanks Grigory for the info, I have not tried Win 11 yet.
Re: Windows 11
Did you install w 11 over w 10 or new installation on clean drive?
