HMG Extended Edition version 21.09 is published
gfilatov
Post by gfilatov »
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended
Edition.
It is a regularly scheduled maintenance release.
Here's a breakdown of some of the modifications in the build 21.09.
For the full list, please see the changelog.
* Fixed: The GetBox control executes the WHEN procedure at the calling
of any other event. It was a postponed modification.
* Added the auxiliary command for assigning a value to the Pseudo-
Global variable.
Syntax:
ASSIGN GLOBAL <cVarName> := <cExp>
where
<cVarName> is the name of the Pseudo-Global variable to assign.
* The DATEPICKER may manage a 'Value' property as DateTime value.
* Added the useful property 'Checked' for SHOWNONE clause in the
DATEPICKER control.
* The names of the internal GLOBAL variables were prefixed with
"_HMG_" for avoiding of override their with user variables names.
* The Window CONTEXTMENU event uses the function GetCursorPos()
for a right detect of mouse position at the multi-monitors system.
* Updated header file i_pseudofunc.ch for compatibility with xHarbour.
* Updated the TSBrowse, sddmysql and sddsqlite3 contrib libraries.
* Added the new interesting samples and updated some examples.
A setup of the ANSI build 21.09 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra donationware Minigui Ex build for the freeware
Embarcadero C++ 10.2 ‘Tokyo’ compiler (which is included to the package).
Note: There are the separate versions of the MiniGUI library for ANSI
and UNICODE characters.
Best Regards,
[MiniGUI Team]
Re: HMG Extended Edition version 21.09 is published
Thanks Grigory!
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
Thanks Grigory!
quartz565
Post by quartz565 »
Thanks Grigory!
Best Regards,
Nikos.
os: Windows Server 2019 - 64
