marked String in TEXTBOX when using Mouse ?
when i use TAB-Key ( CHR(9) ) a String in Textbox show "marked"
when i click into TEXTBOX nothing is "marked"
i try GOTFOCUS and
   hWndEdit := GetControlHandle( ControlName, ParentForm )
   SendMessage(hWndEdit, EM_SETSEL, nStartIndex, nEndIndex)
where
   nStartIndex := 0
   nEndIndex := LEN(String)  // nEndIndex := -1 ALL
Cursor Caret Position is right at nEndIndex
but i "see" no "mark" in TEXTBOX ... :(
it does work in EDITBOX :!:
so what i´m doing wrong under HMG :idea:
Re: marked String in TEXTBOX when using Mouse ?
try to use:
SetProperty(ParentForm, ControlName, "CaretPos", nEndIndex )
Edit:
Sorry, I misunderstood your request... I can't delete my post. I don't know how to select whole text
Edit:
Try:
DoMethod(ParentForm, ControlName, "SetFocus")
after clicking mouse
sorry i have descript it wrong :
when using TAB Key it will "mark" all when get into TEXTBOX -> GOTFOCUS
when "click" into a TEXTBOX it will not show "mark" :o
also when Field was empty TEXTBOX is not "marked"
so i try to use EM_SETSEL with ONGOTFOCUS which should react when "click" into TEXTBOX
but it seems not to work "on click" :( ( except empty TEXTBOX )
DEFINE TEXTBOX Text_001+
   ONGOTFOCUS MarkText(ThisWindow.Name, This.Name )
   ONLOSTFOCUS DeHilite(ThisWindow.Name, This.Name )
PROCEDURE MarkText( ParentForm, ControlName )
LOCAL cValue, hWndEdit, nStartIndex := 0, nEndIndex := - 1
   IF _IsControlDefined( ControlName, ParentForm )
      DoMethod(ParentForm, ControlName, "SetFocus") // add try Mol
      SetProperty(ParentForm, ControlName, "CaretPos", nEndIndex ) // add try Mol
      cValue := GetProperty( ParentForm, ControlName, "Value" )
      IF EMPTY( cValue )
         SetProperty(ParentForm,ControlName,"BackColor",SP_nColor11() )
         SetProperty(ParentForm,ControlName,"FontColor",SP_nColor12() )
         IF VALTYPE(cValue) <> "C"
            cValue := hb_valToExp(cValue)
         nEndIndex := LEN(TRIM(cValue))
PROCEDURE DeHilite( ParentForm, ControlName )
      SetProperty(ParentForm,ControlName,"BackColor",SP_nColor5() )
      SetProperty(ParentForm,ControlName,"FontColor",SP_nColor6() )
When you have a selected text, the cursor is positioned at the end of the selection. When you click into the textbox, you automatically move the cursor to the place of the click and then the selection is deleted because the click makes nStartIndex = nEndIndex
srvet_claudio wrote: Wed Aug 11, 2021 2:13 am nStartIndex = nEndIndex
aaah ... that make Sense. :idea:
thx for Advice
