Help with hbcurl
Help with hbcurl
I want to use hbcurl to POST/GET to/from web especially https.
Can you please tell me what are the libraries required to be statically linked and working in HMG?
Re: Help with hbcurl
As of now, I am using hbtip successfully to send and receive data from https secured websites.
But in the Harbour distribution there is a warning which states like the one below. So, I want to switch over to others like hbcurl or MSXML2.ServerXMLHTTP
I have tried both. Both of them I am getting so many errors.
WARNING for HBTIP users
Due to the excessive amount of problem reports and long known (and unfixed)
problems and due to the non-trivial nature of internet protocols, this document
_strongly recommends to avoid_ using this library in anything production or
in fact anything more serious than simple test code for educational purposes.
Please notice that even if something happens to work in some specific
scenario, it's highly likely it's not a stable solution, nor is it a secure
solution.
The only reason hbtip hasn't been deleted altogether is compatibility
with 3.0, xHarbour and existing projects, plus the fact there are still some
low-level functions that do work fine (tip_MimeType()) or have no better
replacement yet (tip_MailAssemble()).
For internet protocol related tasks, the recommended and supported library
is _hbcurl_, which is a thin wrapper over libcurl's 'easy' API. libcurl is
a highly ubiquitious, very stable, actively and professionally developed,
secure communications library
solution.
I have done communication with RESTAPI on the server with TLS 1.2 and I use both: cURL and "MSXML2.ServerXMLHTTP".
With "MSXML2.ServerXMLHTTP" I use json data exchange between my application and RESTAPI, while cURL for uploading image files ("MSXML2.ServerXMLHTTP" doesn't send form-data boundary correctly, at least I couldn't make him do it
Necessary are libraries that support TLS1.2 (those that were previously published on the forum did not work with TLS 1.2, I am attaching new ones - I do not know if they will work with TLS 1.3 also
My configuration:
HBP:
HBC:
HMG 3.4.4
Code snippets:
HBP:
Myapi.prg
hbziparc.hbc
hbcurl.hbcCode: Select all
inc=yes
head=native
libs=hbmxml mxml libeay32 ssleay32 libwinpthread-1 libcurl zlib1 libidn-11
Code snippets:
//Init
BEGIN SEQUENCE WITH {|o| break(o)}
oApi := Win_OleCreateObject( "MSXML2.ServerXMLHTTP" )
oApi:setTimeouts(nTimeout * 1000 /* nResolve */ , nTimeout * 1000 /* nConnect*/ , nTimeout * 1000 /* nSend */, nTimeout * 1000 /* nReceive */ )
RECOVER
MsgStop( "Microsoft XML Core Services (MSXML) 6.0 is not installed."+CRLF+;
"Download and install MSXML 6.0 from http://msdn.microsoft.com/xml"+CRLF+;
"before continuing.")
oApi:=""
END SEQUENCE
IF EMPTY(oApi)
MsgStop('Error while initialization')
RETURN Nil
cResp := SendApi( cUrl, hb_jsonEncode( hData , .F. ), oApi )
Msgdebug ( cResp )
cResp := GetApi( cUrl, oApi )
Msgdebug ( cResp )
Function SendApi( cUrl, cBody, oApi, cMethod )
Local cReturn, cAPIKey :="blablabla"
Default cMethod := "POST"
oApi:Open( cMethod, cUrl, .F. )
oApi:setRequestHeader("Content-Type", "application/json;charset=utf-8")
oApi:setRequestHeader("client-secret", cAPIKey)
oApi:Send( cBody )
IF oApi:Status <> 200
BREAK "HTTPS status: " + hb_NToS(oApi:status) + " " +oApi:statusText
cReturn := oApi:ResponseBody()
RECOVER USING oErr
cReturn := "!ERROR!" + CRLF + IF (ValType(oErr) = 'O', oErr:Description, oErr )
END SEQUENCE
RETURN cReturn
Function GetApi( cUrl, oApi)
Local cReturn, cAPIKey := "blablabla"
oApi:Open( "GET", cUrl, .F. )
oApi:Send()
oApi:WaitForResponse()
RECOVER USING oErr
cReturn := "!ERORR!" + CRLF + IF (ValType(oErr) = 'O', oErr:Description, oErr )
END SEQUENCE
RETURN cReturn
* cURL
//Init
curlHandle := curl_easy_init()
IF EMPTY(curlHandle)
RETURN Nil
//upload pictures
cResp := SendCurlPictApi( curlHandle, cUrl, cImageFile, hb_HGetDef( hPrd [i0], "id", 0) /* ProductId */ , Str(nIdZdjecia) /* id */, hb_HGetDef( hPrd [i0], "name", "") + " [" + Left( hb_HGetDef( hPrd [i0], "code", ""), 5 ) + "]" /* desc */ )
Msgdebug ( cResp )
curl_global_cleanup( curlHandle )
Function SendCurlPictApi( curlHandle, cUrl, cImage, idProd, idZdjecia, cOpis )
Local cPlikPict:=hb_FNameNameExt ( cImage )
Local boundary:='------' + hb_StrToHex ( hb_TtoC( hb_DateTime(), 'YYYYMMDDhhmmssfff' ) )
Local cFormBody:='--' + boundary + CRLF
Local aHeaders, curlErr
Default cOpis:=""
Do Events
cFormBody+='Content-Disposition: form-data; name="id"' + CRLF + CRLF
cFormBody+=Alltrim(idZdjecia) + CRLF
cFormBody+='--' + boundary + CRLF
cFormBody+='Content-Disposition: form-data; name="productId"' + CRLF + CRLF
cFormBody+=Alltrim(Str(idProd)) + CRLF
cFormBody+='Content-Disposition: form-data; name="version"' + CRLF + CRLF
cFormBody+='1' + CRLF
cFormBody+='Content-Disposition: form-data; name="description"' + CRLF + CRLF
cFormBody+=Alltrim (cOpis) + CRLF
cFormBody+='Content-Disposition: form-data; name="file"; filename="' + cPlikPict + '"' + CRLF
SWITCH Upper(hb_FNameExt ( cImage ))
CASE "JPG"
cContentType:='image/jpeg'
EXIT
CASE "JPEG"
EXIT
CASE "BMP"
cContentType:='image/bmp'
EXIT
CASE "PNG"
cContentType:='image/png'
EXIT
OTHERWISE
END SWITCH
cFormBody+='Content-Type: ' + cContentType + CRLF + CRLF
cFormBody+=FILESTR( cImage ) + CRLF
cFormBody+='--' + boundary + '--' + CRLF
DO EVENTS
curl_easy_reset( curlHandle )
aHeaders := {"client-secret: " + cAPIKey, ;
"Content-Length: " + Str(Len(cFormBody)) , ;
"Content-Type: " + "multipart/form-data; boundary=" + Boundary }
/* Specify the Header data */
curl_easy_setopt( curlHandle, HB_CURLOPT_HTTPHEADER, aHeaders)
curl_easy_setopt( curlHandle, HB_CURLOPT_URL, cUrl )
curl_easy_setopt( curlHandle, HB_CURLOPT_FOLLOWLOCATION, .T. )
curl_easy_setopt( curlHandle, HB_CURLOPT_SSL_VERIFYPEER, .F. )
curl_easy_setopt( curlHandle, HB_CURLOPT_DOWNLOAD )
curl_easy_setopt( curlHandle, HB_CURLOPT_DL_BUFF_SETUP )
curl_easy_setopt( curlHandle, HB_CURLOPT_POST, .T. )
curl_easy_setopt( curlHandle, HB_CURLOPT_POSTFIELDSIZE, LEN( cFormBody ) )
curl_easy_setopt( curlHandle, HB_CURLOPT_POSTFIELDS, cFormBody )
curlErr := curl_easy_perform( curlHandle ) /* Do everything */
IF !EMPTY( curlErr ) /* Report any errors */
cReturn := "!ERROR!" + CRLF + curl_easy_strerror(curlErr)
cReturn := curl_easy_dl_buff_get( curlHandle )
RETURN cReturn
OMG! You are a true saviour man!
Let me revert back with my experience. Thanks a lot.
I am getting the following errors.
Can you give me the .a library files also?
d:/hmg.3.5/mingw/bin/../lib/gcc/i686-w64-mingw32/9.3.0/../../../../i686-w64-mingw32/bin/ld.exe: cannot find -llibwinpthread-1
d:/hmg.3.5/mingw/bin/../lib/gcc/i686-w64-mingw32/9.3.0/../../../../i686-w64-mingw32/bin/ld.exe: cannot find -llibcurl
d:/hmg.3.5/mingw/bin/../lib/gcc/i686-w64-mingw32/9.3.0/../../../../i686-w64-mingw32/bin/ld.exe: cannot find -lzlib1
d:/hmg.3.5/mingw/bin/../lib/gcc/i686-w64-mingw32/9.3.0/../../../../i686-w64-mingw32/bin/ld.exe: cannot find -llibidn-11
Unfortunately, I don't have these files. They are not needed if you are compiling with build.bat. I don't compile with the IDE.
Ok. Let me try with build.bat then.
- vagblad
- DBs Used: MySQL,DBF
i am going to hijack Rathi's thread here (sorry Rathi) .
I am trying to communicate with a Wordpress/Woocommerce website. Now WooCommerce has a fully functional rest api which you can use to communicate.
So my next thought was curl. I used Edward's example and knowledge(thank you once more Edward) and i am starting the communication like this:
i am trying to get the list of all the products in the WooCommerce installation.Woocommerce API documentation says you need to send a GET request at your website's URL + "/wp-json/wc/v3/products" and you will receive a response in json format.
Now, curlErr returns 0 which means everything went ok. cReturn returns "". Anyone has any idea where can i capture the response in json?Ive been trying to figure it out but to no avail.
In php is easy as $curlErr = curl_exec($curlHandle);
aHeaders := { "Content-Type: application/json", "Accept: application/json"}
curl_easy_setopt( curlHandle, HB_CURLOPT_SSL_VERIFYPEER, .F. ) //because i am currently running a non-SSl test server
curl_easy_setopt( curlHandle, HB_CURLOPT_USERPWD, cAPIKey + ":" + cAPIKey2) //the woocommerce consumer_key and consumer_secret
curl_easy_setopt( curlHandle, HB_CURLOPT_URL, cUrl ) //The url i mentioned above
curl_easy_setopt( curlHandle, HB_CURLOPT_HTTPGET, .T. )
cReturn := curl_easy_strerror(curlErr)
ENDIFIn php is easy as $curlErr = curl_exec($curlHandle);
Vagelis Prodromidis
Try something like this (not tested):vagblad wrote: ↑Wed Jul 28, 2021 10:35 am i am going to hijack Rathi's thread here (sorry Rathi) .
Now, curlErr returns 0 which means everything went ok. cReturn returns "". Anyone has any idea where can i capture the response in json?Ive been trying to figure it out but to no avail.Code: Select all
curlHandle := curl_easy_init() aHeaders := { "Content-Type: application/json", "Accept: application/json"} curl_easy_setopt( curlHandle, HB_CURLOPT_HTTPHEADER, aHeaders) curl_easy_setopt( curlHandle, HB_CURLOPT_SSL_VERIFYPEER, .F. ) //because i am currently running a non-SSl test server curl_easy_setopt( curlHandle, HB_CURLOPT_USERPWD, cAPIKey + ":" + cAPIKey2) //the woocommerce consumer_key and consumer_secret curl_easy_setopt( curlHandle, HB_CURLOPT_URL, cUrl ) //The url i mentioned above curl_easy_setopt( curlHandle, HB_CURLOPT_HTTPGET, .T. ) curlErr := curl_easy_perform( curlHandle ) IF !EMPTY( curlErr ) /* Report any errors */ cReturn := curl_easy_strerror(curlErr) ELSE cReturn := curl_easy_dl_buff_get( curlHandle ) ENDIF
Local aHeaders := { "Content-Type: application/json", "Accept: application/json"}
Local cContent := "", cMethod := "GET"
Local nResult, cResultCode, nResultCode, nCodeHTTP := 0
Local cUrl := "https://your_url" + "/wp-json/wc/v3/products"
Local cAPIKey := "your consumer_key"
Local cAPIKey2 := "your consumer_secret"
curl_easy_setopt( curlHandle, HB_CURLOPT_SSL_VERIFYPEER, 0 ) //because i am currently running a non-SSl test server
/* Setup response data */
DO CASE
CASE cMethod = "POST"
/* Specify the POST method & data */
curl_easy_setopt(curlHandle, HB_CURLOPT_POST, 1)
IF !EMPTY( cContent )
curl_easy_setopt(curlHandle, HB_CURLOPT_POSTFIELDS, cContent)
CASE cMethod = "GET"
/* Specify the GET method */
curl_easy_setopt(curlHandle, HB_CURLOPT_HTTPGET, 1)
CASE cMethod = "PUT"
/* Specify the PUT method & data */
curl_easy_setopt(curlHandle, HB_CURLOPT_CUSTOMREQUEST, "PUT")
ENDCASE
nResult := curl_easy_perform( curlHandle )
cResultCode := curl_easy_strerror( nResult )
nCodeHTTP := curl_easy_getinfo( curlHandle, HB_CURLINFO_RESPONSE_CODE, @nResultCode )
IF nResult <> HB_CURLE_OK .OR. nCodeHTTP <> 200
ShowWarning ( "Getting products", "Error while getting products.", nResult, cResultCode, nCodeHTTP )
cResponse := curl_easy_dl_buff_get( curlHandle )
msgdebug ( cResponse )
FUNCTION ShowWarning ( cMessage, cTitle, nResult, cResultCode, nCodeHTTP )
Local nTimeOut := 5000 //5 sekund
MessageBoxTimeout ( cMessage + CRLF + CRLF + "Something went wrong: " + ;
cResultCode + " (" + AllTrim( Str ( nResult ) ) + ;
") HTTP code: " + AllTrim( Str ( nCodeHTTP ) ), cTitle, ;
MB_OK + MB_ICONERROR + MB_SYSTEMMODAL , nTimeOut )
- vagblad
Thank you Edward.
The problem was that i was missing those 2 options:
Now i am getting the json response just fine. Thanks once more time!
curl_easy_setopt( curlHandle, HB_CURLOPT_DL_BUFF_SETUP )Vagelis Prodromidis
