Password en SQLITE
jorge.posadas
Password en SQLITE
Post by jorge.posadas »
Grupo,
¿Alguien sabe CÓOMO poner un password en una base de datos SQLIT? es decir quiero que por programa ponerle un password y cuando se vaya a usar la base de datos, entonces quitarle el password para que la puedan usar.
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
Re: Password en SQLITE
Whether you want to encrypt the sqlite database with a password or you want to store the password in the database?
jorge.posadas
I want to store the password in the database And if you have an example of how to use it in PRG I would really appreciate it
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Morelia, Mich.
M é x i c o .
If you want to store password in databases, there are so many hash functions available.
You can use hb_sha256( cPassword ) -> Hashed Text
Let me give you a small sample to save the password using HMGSQLITE library.
IF AllTrim(pass.newpassword.value) == AllTrim(pass.confpassword.value)
   IF msgyesno("Are you sure to save this password?","Confirm Password Change")
      lOk := miscsql( oCtlDB, "update usermast u set u.userpw = " + c2sql( hb_sha256( AllTrim( pass.newpassword.value ) ) ) + " where u.usercode = "+ c2sql(cUserCode))
      if lOk
         msginfo("Password is changed successfully!")
         pass.release
         msgstop( 'Database Error' )
