GraphPlus
emzampi
Re: GraphPlus
Post by emzampi »
sorry Rathinagiri, but I didn't find the h_graphbitmap.prg file to replace in hmg 3.5, you can't tell me the path
Re: GraphPlus
It is available in \hmg.3.5\SOURCE
emzampi
Re: GraphPlus
Post by emzampi »
thanks for the reply .... rebuil gave these errors
Re: GraphPlus
Which batch file you have used to compile?
Re: GraphPlus
Update to GraphPlus:
- New TreeMap chart (used to represent Hierarchical data like Sun Burst Chart in rectangular shape)
Thanks for the algorithm: http://www.cs.umd.edu/hcil/treemaps
GraphPlus_2021_06_27.zip
(22.8 KiB) Downloaded 404 times
gfilatov
Re: GraphPlus
Post by gfilatov »
Rathinagiri wrote: Sun Jun 27, 2021 7:18 pm Update to GraphPlus:
Hi Rathi,
Thank you very much for your contribution :!:
Please take a look for the unreacheable code since the line #1900 in the source GraphPlus.Prg.
Thanks in advance.
Re: GraphPlus
gfilatov wrote: Wed Jun 30, 2021 9:41 am
Hi Rathi,
Thanks in advance.
Thank you for pointing out! That has to be just deleted. Forgotten to delete. :)
PeteWG
Re: GraphPlus
Post by PeteWG »
Well, I think you forgot to update the name!
It should be GraphPlusPlus !! :)
(under the fear though, to be correlated with other notorious `plusplus` things like f.e. <c plus-plus>)
[Seriously,] many thanks for this nice add-on!
regards,
Pete
Re: GraphPlus
Thank you Pete. :)
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Re: GraphPlus
Post by Claudio Ricardo »
Hi, I have an issue with pie graph, only happen in 2 of 14 months loaded in db.
all others look good:
what i do wrong ? because surely the error is mine.
