There is a small program in the attachment, it makes many pages of the report, but how to calculate how many pages there will be, I would like to show on each page
Page current_page / last_page
How did you do ?
report, how compute last page
- dragancesu
- paging.zip
- (30.85 KiB) Downloaded 118 times
Re: report, how compute last page
Dragan,
What I do is simple: perform all loops without printing and count pages. Then GO TOP and restart looping....
If your report details can fit in a single line or equal to the same exactly for each record, then you can estimate the number of pages by finding the lines per page and total count of lines.
However, if the lines per record is different for each record, then I think Serge's idea may be the only solution.
- dragancesu
thanks for advices
I usually use PREVIEV and that is my problem, it shows and I don't need it the first time
I had to "find" the command ABORT PRINTDOC to break the first loop
- REP_1.zip
- (1.83 KiB) Downloaded 90 times
412 PAGES
Perhaps you can skip a lot of variables in the counting and in hdr_8560....
* This program is generated by HMGCASE
* developed by Dragan Cizmarevic < dragancesu(at)gmail.com >
* created at 03.06.2021 13:29:17
Procedure MAIN // for test, usually Report_1
SET BROWSESYNC ON
SET NAVIGATION EXTENDED
SET DATE GERMAN // for test
SET CENTURY ON // for test
SET procedure to open_dbf // for test
SET procedure to open_ntx // for test
SET procedure to use_dbf // for test
open_dbf() // for test
open_ntx() // for test
DEFINE WINDOW Rep_1 ;
AT 0, 0 ;
WIDTH 400 ;
HEIGHT 400 ;
TITLE "INVDET" ;
MAIN // for test, usually MODAL ;
ON KEY ESCAPE ACTION Rep_1.Release
@ 150, 150 BUTTON PRINT_8558 ;
CAPTION " Create report " ;
ACTION rep_create_8558() ;
WIDTH 100
Rep_1.CENTER
ACTIVATE WINDOW Rep_1
PROCEDURE rep_create_8558
PRIVATE mPrinter, nCurLine:=300, nCurPage:=0, nPageSize:=280, /* := 180 */ nVMargin:=10, nHMargin:=10
PRIVATE cFontName:="Verdana", nFontSize:=8, nFontHeight:=4, nCharWidth:=2
PRIVATE LastPage := 0 // 100
use_inv()
use_cust()
use_product()
USE_INVDET() // function from USE_DBF.prg
brk_01 := INV_NO
brk_on_01 := .F.
prt_01 := .T.
sum_01_05 := 0
sumr_05 := 0
mPrinter := GetPrinter()
IF Empty ( mPrinter )
MsgExclamation( "Printer not selected" )
dbcloseall()
// counting number of pages
DBGOTOP()
DO WHILE .NOT. EOF()
_inv_no = inv_no
_product = product_id
select inv
seek _inv_no
_customer = inv_cust
select invdet
sumr_05 := sumr_05 + TOTAL
IF brk_01 <> INV_NO
brk_on_01 := .T.
prt_01 := .T.
IF brk_01 <> INV_NO .OR. brk_on_01
nCurLine += nFontHeight
nCurCol = nHMargin + 10
nCurCol = nHMargin + 150
nCurCol2 = nCurCol + 30
nCurCol = nHMargin + 180
brk_01 := INV_NO
brk_on_01 := .F.
sum_01_05 := 0
nCurLine := 300
sum_01_05 := sum_01_05 + TOTAL
IF nCurLine > nPageSize
hdr_8560()
select product
seek _product
_product_name = name
select invdet
nCurCol = nHMargin + 120
DBSKIP()
ENDDO
LastPage := nCurPage
nCurPage := 0
// now real printing
SELECT PRINTER mPrinter ;
ORIENTATION PRINTER_ORIENT_PORTRAIT ; // PRINTER_ORIENT_LANDSCAPE ;
PAPERSIZE PRINTER_PAPER_A4 ;
PREVIEW
START PRINTDOC NAME "report"
select invdet
DBGOTOP()
_inv_no = inv_no
select inv
seek _inv_no
select invdet
IF brk_01 <> INV_NO
brk_on_01 := .T.
prt_01 := .T.
@ nCurLine, nCurCol PRINT replicate("*", 6) FONT cFontName SIZE nFontSize
@ nCurLine+2, nCurCol PRINT LINE TO nCurLine+2, nCurCol2 PENWIDTH .1
@ nCurLine, nCurCol PRINT "sum" FONT cFontName SIZE nFontSize
@ nCurLine, nCurCol PRINT TRANSFORM ( sum_01_05, "99999.99") FONT cFontName SIZE nFontSize RIGHT
brk_01 := INV_NO
brk_on_01 := .F.
sum_01_05 := 0
nCurLine:=300
hdr_8558()
select product
seek _product
select invdet
*IF prt_01
* nCurCol = nHMargin + 1 * nCharWidth + 6 * nCharWidth
* @ nCurLine, nCurCol PRINT TRANSFORM ( INV_NO, "999") FONT cFontName SIZE nFontSize RIGHT
* prt_01 := .F.
*ENDIF
@ nCurLine, nCurCol PRINT TRANSFORM ( PRODUCT_ID, "999") FONT cFontName SIZE nFontSize RIGHT
@ nCurLine, nCurCol PRINT _product_name FONT cFontName SIZE nFontSize
@ nCurLine, nCurCol PRINT TRANSFORM ( PRICE, "999.99") FONT cFontName SIZE nFontSize RIGHT
@ nCurLine, nCurCol PRINT TRANSFORM ( QUANTITY, "999") FONT cFontName SIZE nFontSize RIGHT
@ nCurLine, nCurCol PRINT TRANSFORM ( TOTAL, "999,999.99") FONT cFontName SIZE nFontSize RIGHT
DBSKIP()
ENDDO
@ nCurLine, nCurCol PRINT TRANSFORM ( sum_01_05, "999,999.99") FONT cFontName SIZE nFontSize RIGHT
@ nCurLine+2, nCurCol PRINT LINE TO nCurLine+2, nCurCol2 PENWIDTH .5
@ nCurLine, nCurCol PRINT TRANSFORM ( sumr_05, "999,999.99") FONT cFontName SIZE nFontSize BOLD RIGHT
END PRINTPAGE
END PRINTDOC
DBCLOSEALL()
Rep_1.RELEASE
RETURN 0
FUNCTION hdr_8558
nCurPage++
nCurLine := nVMargin
IF nCurPage > 1
END PRINTPAGE
START PRINTPAGE
* @ nCurLine, 10 PRINT "Date : " + DTOC(date()) FONT cFontName SIZE nFontSize // BOLD
@ nCurLine, 180 PRINT "Page : " + alltrim(STR(nCurPage))+'/'+alltrim(str(LastPage)) FONT cFontName SIZE nFontSize // BOLD
@ nCurLine, 100 PRINT "Invoice no " + alltrim(str(inv_no)) FONT cFontName SIZE nFontSize+2 CENTER BOLD
select cust
seek _customer
@ nCurLine, 100 PRINT name FONT cFontName SIZE nFontSize BOLD
@ nCurLine, 100 PRINT address FONT cFontName SIZE nFontSize
@ nCurLine, 100 PRINT alltrim(zipcode) + ' ' + city FONT cFontName SIZE nFontSize
@ nCurLine, 100 PRINT country FONT cFontName SIZE nFontSize
select invdet
@ nCurLine, nCurCol PRINT "PRODUCT" FONT cFontName SIZE nFontSize RIGHT BOLD
@ nCurLine, nCurCol PRINT "NAME" FONT cFontName SIZE nFontSize BOLD
@ nCurLine, nCurCol PRINT "PRICE" FONT cFontName SIZE nFontSize RIGHT BOLD
@ nCurLine, nCurCol PRINT "QUANTITY" FONT cFontName SIZE nFontSize RIGHT BOLD
@ nCurLine, nCurCol PRINT "TOTAL" FONT cFontName SIZE nFontSize RIGHT BOLD
nCurCol2 = nCurCol + 180
prt_01 := .T.
RETURN 0
FUNCTION hdr_8560
nCurPage++
select cust
seek _customer
select invdet
prt_01 := .T.
RETURN 0
