GraphPlus
Re: GraphPlus
Thank you again!
Now I am working on
- Stacked Column and Bar charts.
Then will be working on Area chart.
I think it will be better if we work on some version control system. If GITHUB is Ok, we can do that.
Now I am working on
Re: GraphPlus
WOW ! so much features graph possibilities !!
Thank you Rathinagiri Sir.
Re: GraphPlus
Thank you Anand for your interest.
Here are some new features:
- Added Stacked Column Graph
- Added Stacked Bar Graph
- Fixed bugs
- Revamped Sample to enable switch row/columns for all possible graph types (Play with it)
Stacked Column
Stacked Bar
- Fixed bugs
Stacked Column
Stacked Bar
Re: GraphPlus
I was looking for it (stacked graphs) for a long-long time!
Brilliant implementation!
Thank you so much, Rathinagiri, for this new gem!
regards,
Pete
Re: GraphPlus
Thank you for your interest and appreciation Pete. Please give any suggestions for improvement also.
Why can't we scroll by mouse inside the panel window?
Updated with the following:
- Added new graph type: Area
- Fixed bugs
- Modified demo with a dashboard. Now all the charts are responsive with Grids, Labels, Categories, Legends, Legend Positions etc. Click on the thumbnail to go to the respective chart. Click on the checkbuttons and see the impact.
Area Chart HMG Dashboard!
- Fixed bugs
Re: GraphPlus
Hi Rathi,Rathinagiri wrote: ↑Sat Jun 05, 2021 3:53 pm
- Fixed bugs
Thanks a lot!
Please be so kind to update the main.prg for a correct work of the button 'Switch Rows and Columns'.
I've attached the fixed module with a small modification.
- Main-fix.zip
- (2.86 KiB) Downloaded 433 times
Re: GraphPlus
Sure! Thank you Grigory.
Re: GraphPlus
Updated GraphPlus with the following features:
- Added new Graph Type ScatterXY ( a long time dream! )
- Fixed bugs
- VDivisions and HDivisions (HDivisions applicable only for ScatterXY)
ScatterXY Graph (For the equation y = x^2)
- Fixed bugs
Re: GraphPlus
Not sure, but I suspect it has to do with focus loss, perhaps?
Interestingly, if you right click on the panel, then then mouse wheel is working, (i.e.: the panel starts scrolling).
regards,
Pete
Re: GraphPlus
Now I have made it to work Pete. Thank you!
