DBF Create Code
swapan
Re: DBF Create Code
Post by swapan »
sudip wrote:Hello,
I just created a small utility, which generates code for creating dbf files.
Xcellent work Sudip! And Thanks a lot for sharing the source with us.
I can suggest a feature which may be added to this utility.
During our coding for entry program (with modify/delete options) with the fields of a dbf we do the following things:
1) Declaration of field variables
1) Initilization of Field Variables
2) Storing record's value to Variables: Seek the value of the key field and assign the field values to the field variables.
3) Data Replacement :values from field variables to fields.
These sections can be automated and help a lot during writing an entry program.
Regrds,
Swapan
Thanks & Regards,
Swapan Das
http://www.swapandas.com/
sudip
Re: DBF Create Code
Post by sudip »
Hi Swapan,
Thanks for your kind words and suggestions. Can you please tell details about your suggestion? Only single table entry, or Master-Detail entry? It will be an excellent app!!! :) :D :o
(For time being, I am searching for a good project, which I can do with HMG ;) )
A very good app about your suggestion is already there by Mustafa.
Please go through following link viewtopic.php?f=9&t=628
Regards.
swapan
Re: DBF Create Code
Post by swapan »
sudip wrote: (For time being, I am searching for a good project, which I can do with HMG ;) )
BTW looking for a Paid or Free job (the HMG project)?!
If its free I can help! :D
Yes a real poject can help us a lot................................................................
Its good that you are ready for that..........
Rgds,
Swapan
Thanks & Regards,
Swapan Das
sudip
Re: DBF Create Code
Post by sudip »
Hello,
I found problem using my code in real life. There was a bug. I corrected it.
Please download the source code and compile.
DBFCreate.rar
(2.1 KiB) Downloaded 830 times
With best regards.
Ismach
Re: DBF Create Code
Post by Ismach »
Estimado Sudip y colegas
me tomado el atrevimiento de modificar y agrandar tu codigo, aun queda mucho por hacer pero me he quedado sin tiempo, lo subo igual para no perderlo para que lo usen o lo sigan modifcando y/o haciendo nuevas versiones, pero me resulto muy divertido. Si en algun momento tengo tiempo libre lo seguire
Ismach
DbfCreate.zip
(2.07 MiB) Downloaded 233 times
hansmarc
Re: DBF Create Code
Post by hansmarc »
Hello,
did you already give a look at Otis.
see Otis, update V1.21 06/05/2021
A free utility where in you will find a structure editor, table inspector and a tool to create a prg or a csv for the opened table and index files.
Hans
RPC
Re: DBF Create Code
Post by RPC »
Ismach wrote: Sat May 08, 2021 2:03 am Estimado Sudip y colegas
Ismach
Hi Ismach
I tried compiling your program in MiniGUI but got following error
hbmk2: Processing environment options: -comp=bcc
hbmk2: Compiling resources...
Borland Resource Compiler Version 5.40
Copyright (c) 1990, 1999 Inprise Corporation. All rights reserved.
Error dbfcreate.rc 18 47: Invalid bitmap format
hbmk2[DBFCreate]: Error: Running resource compiler. 20018
brcc32.exe -Ic:\borland\bcc58\Include -Ic:\borland\bcc58\Include\dinkumware -Ic:\minigui\harbour\include -Ic:\minigui\include -IC:\USERS\RPCCH\DOWNLO~1\DBFCRE~1\DBFCRE~1 -IC:\Users\rpcch\Downloads\DbfCreate2\DbfCreate C:\USERS\RPCCH\DOWNLO~1\DBFCRE~1\DBFCRE~1\dbfcreate.rc -foOBJ\dbfcreate.res
Failure!
Can you please help resolve it
thank you
Ismach
Re: DBF Create Code
Post by Ismach »
Hola
deberias editar el .rc y anular la 2 ultimas lineas asi:
// ZSERVER
// ZPREFERENCES
y compilar nuevamente
RPC
Re: DBF Create Code
Post by RPC »
Ismach wrote: Tue May 11, 2021 7:38 pm Hola
// ZSERVER
// ZPREFERENCES
Hi Ismach
I have commented the two lines in .rc file but I am still getting the following mistake
Error _temp.rc 6 14: Cannot open file: C:\hmg.3.4.4\\RESOURCES
brcc32.exe -Ic:\borland\bcc58\Include -Ic:\borland\bcc58\Include\dinkumware -Ic:\minigui\harbour\include -Ic:\minigui\include -IC:\USERS\RPCCH\DOWNLO~1\DBFCRE~1\DBFCRE~1 -IC:\Users\rpcch\Downloads\DbfCreate2\DbfCreate C:\USERS\RPCCH\DOWNLO~1\DBFCRE~1\DBFCRE~1\_temp.rc -foOBJ\_temp.res
Failure!
I have installed hmg.3.4.4 and path c:\hmg.3.4.4\RESOURCES exists
I am using IDE to compile.
Pls help
Thanks
Claudio Ricardo
DBs Used: DBF, MySQL, MariaDB
Re: DBF Create Code
Post by Claudio Ricardo »
Hi... HMG 3.4.4 use MinGw not Bcc58 (MiniGui use this), IMHO you have a issue in path... Change #include <minigui.ch> to #include <hmg.ch>
in "dbfcreate.prg" and try using F5 or Run button from HMG IDE.
