VLC for HMG
Re: VLC for HMG
tengo VLC 64 bits instalado,, en minigui sucede el mismo error al compilar con BCC
Re: VLC for HMG
Install VLC 32 bist and Work !!
Re: VLC for HMG
danielmaximiliano wrote: Wed Apr 28, 2021 11:36 pm tengo VLC 64 bits instalado,, en minigui sucede el mismo error al compilar con BCC
i´m not sure if there is a 64 Bit axVLC.DLL ...
Minigui Sample use 32 Bit Version
PROGID "VideoLAN.VLCPlugin.2"
i got Information with COMLicenceFinder
https://www.codeproject.com/Articles/16 ... trieve-the
chrisjx2002
Re: VLC for HMG
Post by chrisjx2002 »
Thanks for the new version. The program compiles well but I have an error message when I launch it :
Error winole/1009 (see attached file)
Re: VLC for HMG
chrisjx2002 wrote: Fri Apr 30, 2021 3:43 pm Thanks for the new version. The program compiles well but I have an error message when I launch it :
Me sucedía lo mismo con la versión de VLC 64 bits, al instalar la versión VLC 32 bits compila y se ejecuta correctamente
Re: VLC for HMG
i have not found "ProgID" (CLSID) from VLC 64 Bit axvlc.dll, which "is" in c:\Program Files\VideoLAN\VLC, yet.
it might be that COMLicenceFinder.exe only show me 32 Bit ActiveX ... which Tool are working with 64 bit to show "ProgID" (CLSID) :idea:
Re: VLC for HMG
i have de-install 64 Bit VLC and installed latest vlc-3.0.13-win64.exe which have axVLC.DLL as 64 Bit Version.
i have search for "ProgID" ( CLSID) and found
9BE31822-FDAD-461B-AD51-BE1D1C159921
this is exact the same like 32 Bit Version
VLC ActiveX Plugin and IE Web Plugin v2
{9BE31822-FDAD-461B-AD51-BE1D1C159921}
so i start VLC 64 Bit Demo and it work :D
please look if you have axVLC.DLL in c:\Program Files\VideoLAN\VLC\ ... than Demo must run unter 64 Bit
use my Demo DLL6432 to "test" DLL (EXE) if it is 64 Bit
DLL6432.ZIP
(950 Bytes) Downloaded 185 times
chrisjx2002
Re: VLC for HMG
Hello,
I test vlc dll with your program. It is 64 bits. But the problem is still the same.
Re: VLC for HMG
chrisjx2002 wrote: Sat May 01, 2021 3:10 pm I test vlc dll with your program. It is 64 bits. But the problem is still the same.
please search in Registry for "axvlc.dll"
you should find it under
C:\Program Files\VideoLAN\VLC\axvlc.dll  // 64 bit
p.s. 32 Bit Version is in"x86" Folder
if you don´t have this Entry you might have
a.) not installed ActiveX & WebPlugin
b.) you have a older Version without 64 Bit ActiveX
try do de-install and install "latest" Version vlc-3.0.12-win64.exe from
https://get.videolan.org/vlc/3.0.12/win ... -win64.exe
chrisjx2002
Re: VLC for HMG
Hello,
Thanks for the answer.
I uninstall and reinstall vlc. Always the same problem. I take a look in the registry and I find :
Ordinateur\HKEY_CLASSES_ROOT\TypeLib\{DF2BBE39-40A8-433B-A279-073F48DA94B6}\1.0\0\win64
Not the same as yours.
