falta libreria hbmysql
Re: falta libreria hbmysql
Hi to all,
Lot's of thanks to jayadevu for providing the info on the SQLMIX Rdd interface.
I didn't look into it yet but it sounds promising to solve parts of my problem. I hope that the same C functions to query mySQL are available like from the current libmysql.dll - otherwise I'd have to change the code of my current database interface.
The PERFECT SOLUTION to the problems discussed in this thread would be a new 64 bit only release of HMG which works with mySQL 8.0.23 by default ...
64 bit is the future. There's no way around it ... like there was no way around moving from 16 to 32 bit a while ago.
mySQL is the future. There are many reasons why it is used as the database of choice for web applications all over the internet.
Joerg
Joerg
- salamandra
- DBs Used: DBF, MySQL, SQL
Hi joerg ,
I agree too
Salamandra, Brazil
joerg wrote: ↑Wed Mar 31, 2021 8:26 am Hi to all,
Joerg
I agree too
Salamandra, Brazil
- Ismach
Si bien internamente se parecen, hay algunas diferencias,
personalmente creo que hay que agregar codigo y generar la libmariadb.a
- Libmysql_vs_Libmariadb.png (59.66 KiB) Viewed 3040 times
para generar libmariadb.a es necesario estas herramientas : impdef.exe de Borland ( c:\borland\xxx\bin)
desde la linea de comandos tipear
con Dlltool de MinGW crearemos la libreria.a de mariadb
nos generará la lista de nombre de las funciones de exportacionC:\Program Files (x86)\MariaDB\MariaDB Connector C\lib>impdef libmariadb.def libmariadb.dll
LIBRARY LIBMARIADB.DLL
EXPORTS
ma_pvio_register_callback @1 ; ma_pvio_register_callback
mariadb_cancel @2 ; mariadb_cancel
mariadb_connection @3 ; mariadb_connection
mariadb_convert_string @4 ; mariadb_convert_string
mariadb_deinitialize_ssl @5 ; mariadb_deinitialize_ssl
mariadb_dyncol_check @6 ; mariadb_dyncol_check
mariadb_dyncol_column_cmp_named @7 ; mariadb_dyncol_column_cmp_named
mariadb_dyncol_column_count @8 ; mariadb_dyncol_column_count
mariadb_dyncol_create_many_named @9 ; mariadb_dyncol_create_many_named
mariadb_dyncol_create_many_num @10 ; mariadb_dyncol_create_many_num
mariadb_dyncol_exists_named @11 ; mariadb_dyncol_exists_named
mariadb_dyncol_exists_num @12 ; mariadb_dyncol_exists_num
mariadb_dyncol_free @13 ; mariadb_dyncol_free
mariadb_dyncol_get_named @14 ; mariadb_dyncol_get_named
mariadb_dyncol_get_num @15 ; mariadb_dyncol_get_num
mariadb_dyncol_has_names @16 ; mariadb_dyncol_has_names
mariadb_dyncol_json @17 ; mariadb_dyncol_json
mariadb_dyncol_list_named @18 ; mariadb_dyncol_list_named
mariadb_dyncol_list_num @19 ; mariadb_dyncol_list_num
mariadb_dyncol_unpack @20 ; mariadb_dyncol_unpack
mariadb_dyncol_update_many_named @21 ; mariadb_dyncol_update_many_named
mariadb_dyncol_update_many_num @22 ; mariadb_dyncol_update_many_num
mariadb_dyncol_val_double @23 ; mariadb_dyncol_val_double
mariadb_dyncol_val_long @24 ; mariadb_dyncol_val_long
mariadb_dyncol_val_str @25 ; mariadb_dyncol_val_str
mariadb_field_attr @26 ; mariadb_field_attr
mariadb_free_rpl_event @27 ; mariadb_free_rpl_event
mariadb_get_charset_by_name @28 ; mariadb_get_charset_by_name
mariadb_get_charset_by_nr @29 ; mariadb_get_charset_by_nr
mariadb_get_info @30 ; mariadb_get_info
mariadb_get_infov @31 ; mariadb_get_infov
mariadb_reconnect @32 ; mariadb_reconnect
mariadb_rpl_close @33 ; mariadb_rpl_close
mariadb_rpl_fetch @34 ; mariadb_rpl_fetch
mariadb_rpl_get_optionsv @35 ; mariadb_rpl_get_optionsv
mariadb_rpl_open @36 ; mariadb_rpl_open
mariadb_rpl_optionsv @37 ; mariadb_rpl_optionsv
mariadb_stmt_execute_direct @38 ; mariadb_stmt_execute_direct
mariadb_stmt_fetch_fields @39 ; mariadb_stmt_fetch_fields
mysql_affected_rows @40 ; mysql_affected_rows
mysql_autocommit @41 ; mysql_autocommit
mysql_autocommit_cont @42 ; mysql_autocommit_cont
mysql_autocommit_start @43 ; mysql_autocommit_start
mysql_change_user @44 ; mysql_change_user
mysql_change_user_cont @45 ; mysql_change_user_cont
mysql_change_user_start @46 ; mysql_change_user_start
mysql_character_set_name @47 ; mysql_character_set_name
mysql_client_find_plugin @48 ; mysql_client_find_plugin
mysql_client_register_plugin @49 ; mysql_client_register_plugin
mysql_close @50 ; mysql_close
mysql_close_cont @51 ; mysql_close_cont
mysql_close_start @52 ; mysql_close_start
mysql_commit @53 ; mysql_commit
mysql_commit_cont @54 ; mysql_commit_cont
mysql_commit_start @55 ; mysql_commit_start
mysql_data_seek @56 ; mysql_data_seek
mysql_debug @57 ; mysql_debug
mysql_dump_debug_info @58 ; mysql_dump_debug_info
mysql_dump_debug_info_cont @59 ; mysql_dump_debug_info_cont
mysql_dump_debug_info_start @60 ; mysql_dump_debug_info_start
mysql_embedded @61 ; mysql_embedded
mysql_eof @62 ; mysql_eof
mysql_errno @63 ; mysql_errno
mysql_error @64 ; mysql_error
mysql_escape_string @65 ; mysql_escape_string
mysql_fetch_field @66 ; mysql_fetch_field
mysql_fetch_field_direct @67 ; mysql_fetch_field_direct
mysql_fetch_fields @68 ; mysql_fetch_fields
mysql_fetch_lengths @69 ; mysql_fetch_lengths
mysql_fetch_row @70 ; mysql_fetch_row
mysql_fetch_row_cont @71 ; mysql_fetch_row_cont
mysql_fetch_row_start @72 ; mysql_fetch_row_start
mysql_field_count @73 ; mysql_field_count
mysql_field_seek @74 ; mysql_field_seek
mysql_field_tell @75 ; mysql_field_tell
mysql_free_result @76 ; mysql_free_result
mysql_free_result_cont @77 ; mysql_free_result_cont
mysql_free_result_start @78 ; mysql_free_result_start
mysql_get_character_set_info @79 ; mysql_get_character_set_info
mysql_get_charset_by_name @80 ; mysql_get_charset_by_name
mysql_get_charset_by_nr @81 ; mysql_get_charset_by_nr
mysql_get_client_info @82 ; mysql_get_client_info
mysql_get_client_version @83 ; mysql_get_client_version
mysql_get_host_info @84 ; mysql_get_host_info
mysql_get_option @85 ; mysql_get_option
mysql_get_optionv @86 ; mysql_get_optionv
mysql_get_parameters @87 ; mysql_get_parameters
mysql_get_proto_info @88 ; mysql_get_proto_info
mysql_get_server_info @89 ; mysql_get_server_info
mysql_get_server_name @90 ; mysql_get_server_name
mysql_get_server_version @91 ; mysql_get_server_version
mysql_get_socket @92 ; mysql_get_socket
mysql_get_ssl_cipher @93 ; mysql_get_ssl_cipher
mysql_get_timeout_value @94 ; mysql_get_timeout_value
mysql_get_timeout_value_ms @95 ; mysql_get_timeout_value_ms
mysql_hex_string @96 ; mysql_hex_string
mysql_info @97 ; mysql_info
mysql_init @98 ; mysql_init
mysql_insert_id @99 ; mysql_insert_id
mysql_kill @100 ; mysql_kill
mysql_kill_cont @101 ; mysql_kill_cont
mysql_kill_start @102 ; mysql_kill_start
mysql_list_dbs @103 ; mysql_list_dbs
mysql_list_fields @104 ; mysql_list_fields
mysql_list_fields_cont @105 ; mysql_list_fields_cont
mysql_list_fields_start @106 ; mysql_list_fields_start
mysql_list_processes @107 ; mysql_list_processes
mysql_list_tables @108 ; mysql_list_tables
mysql_load_plugin @109 ; mysql_load_plugin
mysql_load_plugin_v @110 ; mysql_load_plugin_v
mysql_more_results @111 ; mysql_more_results
mysql_net_field_length @112 ; mysql_net_field_length
mysql_net_read_packet @113 ; mysql_net_read_packet
mysql_next_result @114 ; mysql_next_result
mysql_next_result_cont @115 ; mysql_next_result_cont
mysql_next_result_start @116 ; mysql_next_result_start
mysql_num_fields @117 ; mysql_num_fields
mysql_num_rows @118 ; mysql_num_rows
mysql_options @120 ; mysql_options
mysql_options4 @119 ; mysql_options4
mysql_optionsv @121 ; mysql_optionsv
mysql_ping @122 ; mysql_ping
mysql_ping_cont @123 ; mysql_ping_cont
mysql_ping_start @124 ; mysql_ping_start
mysql_ps_fetch_functions @125 ; mysql_ps_fetch_functions
mysql_query @126 ; mysql_query
mysql_query_cont @127 ; mysql_query_cont
mysql_query_start @128 ; mysql_query_start
mysql_read_query_result @129 ; mysql_read_query_result
mysql_read_query_result_cont @130 ; mysql_read_query_result_cont
mysql_read_query_result_start @131 ; mysql_read_query_result_start
mysql_real_connect @132 ; mysql_real_connect
mysql_real_connect_cont @133 ; mysql_real_connect_cont
mysql_real_connect_start @134 ; mysql_real_connect_start
mysql_real_escape_string @135 ; mysql_real_escape_string
mysql_real_query @136 ; mysql_real_query
mysql_real_query_cont @137 ; mysql_real_query_cont
mysql_real_query_start @138 ; mysql_real_query_start
mysql_refresh @139 ; mysql_refresh
mysql_refresh_cont @140 ; mysql_refresh_cont
mysql_refresh_start @141 ; mysql_refresh_start
mysql_reset_connection @142 ; mysql_reset_connection
mysql_reset_connection_cont @143 ; mysql_reset_connection_cont
mysql_reset_connection_start @144 ; mysql_reset_connection_start
mysql_rollback @145 ; mysql_rollback
mysql_rollback_cont @146 ; mysql_rollback_cont
mysql_rollback_start @147 ; mysql_rollback_start
mysql_row_seek @148 ; mysql_row_seek
mysql_row_tell @149 ; mysql_row_tell
mysql_select_db @150 ; mysql_select_db
mysql_select_db_cont @151 ; mysql_select_db_cont
mysql_select_db_start @152 ; mysql_select_db_start
mysql_send_query @153 ; mysql_send_query
mysql_send_query_cont @154 ; mysql_send_query_cont
mysql_send_query_start @155 ; mysql_send_query_start
mysql_server_end @156 ; mysql_server_end
mysql_server_init @157 ; mysql_server_init
mysql_session_track_get_first @158 ; mysql_session_track_get_first
mysql_session_track_get_next @159 ; mysql_session_track_get_next
mysql_set_character_set @160 ; mysql_set_character_set
mysql_set_character_set_cont @161 ; mysql_set_character_set_cont
mysql_set_character_set_start @162 ; mysql_set_character_set_start
mysql_set_local_infile_default @163 ; mysql_set_local_infile_default
mysql_set_local_infile_handler @164 ; mysql_set_local_infile_handler
mysql_set_server_option @165 ; mysql_set_server_option
mysql_set_server_option_cont @166 ; mysql_set_server_option_cont
mysql_set_server_option_start @167 ; mysql_set_server_option_start
mysql_shutdown @168 ; mysql_shutdown
mysql_shutdown_cont @169 ; mysql_shutdown_cont
mysql_shutdown_start @170 ; mysql_shutdown_start
mysql_sqlstate @171 ; mysql_sqlstate
mysql_ssl_set @172 ; mysql_ssl_set
mysql_stat @173 ; mysql_stat
mysql_stat_cont @174 ; mysql_stat_cont
mysql_stat_start @175 ; mysql_stat_start
mysql_stmt_affected_rows @176 ; mysql_stmt_affected_rows
mysql_stmt_attr_get @177 ; mysql_stmt_attr_get
mysql_stmt_attr_set @178 ; mysql_stmt_attr_set
mysql_stmt_bind_param @179 ; mysql_stmt_bind_param
mysql_stmt_bind_result @180 ; mysql_stmt_bind_result
mysql_stmt_close @181 ; mysql_stmt_close
mysql_stmt_close_cont @182 ; mysql_stmt_close_cont
mysql_stmt_close_start @183 ; mysql_stmt_close_start
mysql_stmt_data_seek @184 ; mysql_stmt_data_seek
mysql_stmt_errno @185 ; mysql_stmt_errno
mysql_stmt_error @186 ; mysql_stmt_error
mysql_stmt_execute @187 ; mysql_stmt_execute
mysql_stmt_execute_cont @188 ; mysql_stmt_execute_cont
mysql_stmt_execute_start @189 ; mysql_stmt_execute_start
mysql_stmt_fetch @190 ; mysql_stmt_fetch
mysql_stmt_fetch_column @191 ; mysql_stmt_fetch_column
mysql_stmt_fetch_cont @192 ; mysql_stmt_fetch_cont
mysql_stmt_fetch_start @193 ; mysql_stmt_fetch_start
mysql_stmt_field_count @194 ; mysql_stmt_field_count
mysql_stmt_free_result @195 ; mysql_stmt_free_result
mysql_stmt_free_result_cont @196 ; mysql_stmt_free_result_cont
mysql_stmt_free_result_start @197 ; mysql_stmt_free_result_start
mysql_stmt_init @198 ; mysql_stmt_init
mysql_stmt_insert_id @199 ; mysql_stmt_insert_id
mysql_stmt_more_results @200 ; mysql_stmt_more_results
mysql_stmt_next_result @201 ; mysql_stmt_next_result
mysql_stmt_next_result_cont @202 ; mysql_stmt_next_result_cont
mysql_stmt_next_result_start @203 ; mysql_stmt_next_result_start
mysql_stmt_num_rows @204 ; mysql_stmt_num_rows
mysql_stmt_param_count @205 ; mysql_stmt_param_count
mysql_stmt_param_metadata @206 ; mysql_stmt_param_metadata
mysql_stmt_prepare @207 ; mysql_stmt_prepare
mysql_stmt_prepare_cont @208 ; mysql_stmt_prepare_cont
mysql_stmt_prepare_start @209 ; mysql_stmt_prepare_start
mysql_stmt_reset @210 ; mysql_stmt_reset
mysql_stmt_reset_cont @211 ; mysql_stmt_reset_cont
mysql_stmt_reset_start @212 ; mysql_stmt_reset_start
mysql_stmt_result_metadata @213 ; mysql_stmt_result_metadata
mysql_stmt_row_seek @214 ; mysql_stmt_row_seek
mysql_stmt_row_tell @215 ; mysql_stmt_row_tell
mysql_stmt_send_long_data @216 ; mysql_stmt_send_long_data
mysql_stmt_send_long_data_cont @217 ; mysql_stmt_send_long_data_cont
mysql_stmt_send_long_data_start @218 ; mysql_stmt_send_long_data_start
mysql_stmt_sqlstate @219 ; mysql_stmt_sqlstate
mysql_stmt_store_result @220 ; mysql_stmt_store_result
mysql_stmt_store_result_cont @221 ; mysql_stmt_store_result_cont
mysql_stmt_store_result_start @222 ; mysql_stmt_store_result_start
mysql_stmt_warning_count @223 ; mysql_stmt_warning_count
mysql_store_result @224 ; mysql_store_result
mysql_store_result_cont @225 ; mysql_store_result_cont
mysql_store_result_start @226 ; mysql_store_result_start
mysql_thread_end @227 ; mysql_thread_end
mysql_thread_id @228 ; mysql_thread_id
mysql_thread_init @229 ; mysql_thread_init
mysql_thread_safe @230 ; mysql_thread_safe
mysql_use_result @231 ; mysql_use_result
mysql_warning_count @232 ; mysql_warning_count
C:\Program Files (x86)\MariaDB\MariaDB Connector C\lib>dlltool --dllname libmariadb.dll --def libmariadb.def --output-lib libmariadb.a
- AUGE_OHR
hi
i have not follow hole Thread but nobody is talking about LIB2A
https://code.google.com/archive/p/lib2a/
I already talked about Lib2a a while ago, it is a frontend, if you look closely there is no source code in its repository in Google Code.AUGE_OHR wrote: ↑Fri Apr 09, 2021 4:55 am hi
i have not follow hole Thread but nobody is talking about LIB2A![]()
I think it's done in VB
- Ismach
Yo ya hice eso, he generado la libmariadb.a y he usado ambas herramientas pero a la hora de testearla no funciona, porque en 64bits es distinto, y hasta cambian los nombres de las funciones internas.
- Ismach
Hay una herramienta que se llama mysqlcc.exe y si bien fue creada con QT, esta usa una linmysql.dll de la version 4.0 y funciona para Mariadb(64bits) version 10.3.9(64bits), como hace? ni idea, ahora si estoy mas confundido que antes.
