How to get attachment(s) from mail?
Alex Gustow
Post by Alex Gustow »
I need to create program for little automizing of our office work (chief want it at Monday - so I must do it quickly).
Process description:
Our clients (hospitals - about 150-200) will send to us (to known e-mail address) their reports (4 .XLS files attached to one mail message) EACH DAY.
We must get their mails, "save to" their attachments (to pre-defined folder)... and other program must create a summary report from their XLSs... ("other program" - is not my task, other programmer writes it).
My program (it runs by Win Sheduler every hour) must do that:
1) connect to mail-server;
2) logon (post login and password);
3) get mail's quantity (BTW how I can get number of NEW mails? or how I can separate NEW mail message from OLD one?);
4) read each mail message;
5) ask "you have attachements?" :)
6) if "yes" - get array with attachtment's filenames;
7) save (if exists) all XLSs to folder
8) goto point (4)
9) close connection.
I never tried to work with mails from HMG before. I looked to SAMPLES, looking for "*mail*.*" files. I found "\Advanced\DeleteEmail" and "\Applications\MultipleMail" samples - it helps me on start line...
Little sample (what I can do right now):
  public cServer, cUser, cPass, aMessages, nMsgs, i, j
  cServer := "82.122.253.164"
  cUser   := "gripp"
  cPass   := "1234554321"
  oSocket := TPop3():New()
  // try to connect to mail server
  if oSocket:Connect( alltrim(cServer) )
    MsgInfo( "Yes, connection to [ " + cServer + " ] exists !!!" )
    // try to login
    if oSocket:Login( alltrim(cUser), alltrim(cPass) )
      MsgInfo( "Yes, login as [ " + cUser + " ] exists !!!" )
      // do we have mails into InBox?
      aMessages := oSocket:List(.T.)         // .F.
      // .F. - array with subarrays: {cMsgID, val(cSize)}
      //                               (ID and message size)
      // .T. - array with subarrays: { cMsgID, val(cSize), cSubject }
      //                               (ID, message size, subject)
      nMsgs := Len(aMessages)
      if nMsgs > 0
        txt :=  "Yes, we have mails!!! Quantity = " + ;
                 ltrim(str( nMsgs )) + CRLF + CRLF + "ID  size  subject"
        for i:=1 to nMsgs
          txt := txt + CRLF
          txt := txt + aMessages[i,1]
          txt := txt + "   " + str(aMessages[i,2], 8)
          txt := txt + iif( len(aMessages[i])=3, ;
                            "  subject: " + trim(aMessages[i,3]), ;
        next i
        MsgInfo( txt )
        // get message text and show it
        for i:=1 to nMsgs
          txt := "Message № " + ltrim(str(i)) + CRLF + CRLF + "Message text:" + CRLF
          txt := oSocket:GetMessageText( aMessages[i,1] )
          MsgInfo( txt )
        next i
///// 1) how to know: is it NEW message?
///// 2) how to know: this message has attachments?
///// 3) how to get attachments list (with filenames)?
///// 3) how "save to" attachments?
        MsgInfo( "Oops... InBox is empty." )
      MsgStop( "Oops... I couldn't login (???)" )
    MsgStop( "Oops... I couldn't connect to mail-server [ " + cServer + " ] (???)" )
  oSocket:Close()    // after work close connection (DO IT !)
Maybe someone can help me how to solve my troubles?
Re: How to get attachment(s) from mail?
Alex Gustow wrote:I need to create program for little automizing of our office work (chief want it at Monday - so I must do it quickly).
As far as I know, Matteo Baccan socket library does not have such functonality. This is TPOP3 class:
CLASS TPOP3
   METHOD New()
   METHOD Connect( cAddress, nPort )
   METHOD Close()
   METHOD Login( cUser, cPwd )
   METHOD List( lFullInfo )
   METHOD GetMessageHeader( cMessageID )
   METHOD GetMessageText( cMessageID )
   METHOD DeleteMessage( cMessageID )
   VAR oSocket HIDDEN
ENDCLASS
But HBTIP could be helpful on that. I've attached to this message the full source code and samples from Harbour SVN.
I hope that be helpful.
hbtip.rar
(100.45 KiB) Downloaded 595 times
Alex Gustow
Thanks Roberto!
I'll try to learn it (never seen before - interesting thing for 1st view!).
Maybe I'll try to use MAPI (Simple MAPI or MAPI 1.0) functions - but it takes time to understanding.
In any case - I'll have expirience with this problem (and post results here of course).
Alex Gustow
I rewrite my program (now I use classes from TIP.LIB [it comes with HMG Ext, look at folder "MiniGUI\Harbour\Lib"] - Roberto posted it as sources of HBTIP library in this thread). And what I can (and can't) for today:
Simple sample (into "Inbox" I have 3 mails - 2 "new" and 1 "old"):
It compiles as:
 call c:\MiniGUI\Batch\Compile.bat GrippMail /l tip
 --------- start of code --------
 local oMail, cUrl, oUrl, oClient, txt
 // it's not REALLY address - for example only
 cUrl := "pop://gripptest:gripptest@26.188.255.166"
 if empty( alltrim( cUrl ) )
   MsgInfo( "Invalid (empty) URL: " + cUrl )
 oUrl := tURL():New( cUrl )
 if empty( oUrl )
   MsgInfo("oUrl -- Invalid URL : [ " + cUrl + " ]")
   MsgInfo("oUrl created!")
 oClient := TIpClientPop():new( oUrl )
 if empty( oClient )
   MsgInfo("oClient -- Invalid URL : [ " + cUrl + " ]")
   MsgInfo("oClient created!")
 oClient:nConnTimeout := 2000    //:= 20000
 oUrl:cUserid := strtran( oUrl:cUserid, "&at;", "@" )
 if oClient:Open()
   if empty( oClient:cReply )
     MsgInfo( "Connecting to " + oUrl:cProto + "://" + oUrl:cServer + CRLF + ;
                 "Connection status: <connected>" )
                "Connection status: " + oClient:cReply )
   // it returns .T.
   txt := "oClient:isOpen = " + iif( oClient:isOpen, ".T.", ".F." )
   MsgInfo( txt )
   // in my case it returns -1 and 0
   txt := "oClient:nLength = " + ltrim(str( oClient:nLength )) + CRLF + ;
          "oClient:nRead = " + ltrim(str( oClient:nRead ))
   MsgInfo( txt )
   // in my case returns string:
   // "+ОК " + (amoun of mails) + (amount of bytes)(ie summary size)
   txt := "oClient:Stat() = " + oClient:Stat()
   MsgInfo( txt )
   // it returns string (divided by CRLF):
   // into substrings: ("mail number" "mail size") (for example: "1 32452" + CRLF )
   txt := "oClient:List() = " + CRLF + oClient:List()
   MsgInfo( txt )
   // it returns value greater on 1 (not 3 but 4)
   txt := "Amount of mails into Inbox ( oClient:countMail ): " + ;
          ltrim(str( oClient:countMail ))
   MsgInfo( txt )
   // attempt to get "unique ID" (if without parameter - _all_ mails)
   // returns string (divided by CRLF - if _all_ mails)
   // (into substring -
   //   "1 MD50000000001:MSG:18386:30041174:1176554496" )
   txt := "oClient:UIDL( ) = " + CRLF + oClient:UIDL( )
   MsgInfo( txt )
   // for _one_ it returns only UIDL ( "MD5..." )
   txt := "oClient:UIDL( 1 ) = " + CRLF + oClient:UIDL( 1 )
   MsgInfo( txt )
   // METHOD Read( nLen ) CLASS tIPClientPOP
   // RETURN ::Retrieve( Val( ::oUrl:cFile ), nLen )
   txt := 'valtype( oClient:Read( 1 ) ) = "' + valtype( oClient:Read( 1 ) ) + '"'
   MsgInfo( txt )
   // attempt to get 1st mail
   txt := "oClient:Read( oClient:UIDL( 1 ) ) = " + CRLF + ;
          "--- start --" + CRLF + ;
          oClient:Read( oClient:UIDL( 1 ) ) + CRLF + ;
          "--- finish ---"
   MsgInfo( txt )
   // ? it return that most, as List() returns
   // ? how to get mail, if I know it's number into Inbox (or UIDL) ??
   // try to get mail with Retrieve (2nd mail, 100 bytes)
   txt := "oClient:Retrieve( 2, 100 ) = " + CRLF + ;
          oClient:Retrieve( 2, 100 ) + CRLF + ;
          "--- finish ---"
   MsgInfo( txt )
   // "Kaspersky Mail-Checker" runs -
   //   I.e. the letter is validly obtained
   // but... result is empty string (??) maybe it is object?..
   // try to get mail with Retrieve (2nd mail, all mail - from begin to end)
   txt := "oClient:Retrieve( 2 ) = " + CRLF + ;
          oClient:Retrieve( 2 ) + CRLF + ;
          "--- finish ---"
   MsgInfo( txt )
   // check type - what Retrieve() returns
   txt := 'valtype( oClient:Retrieve( 2 ) ) = "' + ;
          valtype( oClient:Retrieve( 2 ) ) + '"'
   MsgInfo( txt )
   // тип - "С"
   // ... to be continued (I want to eat and it is time in bed)
   // ... to do: how I can get 1st "new" (or "old") mail?
   // close session (it's necessary!)
   oClient:Quit()    // look at HBTIP\POPCLI.PRG
   oClient:Close()
   MsgInfo( "Session closed." + CRLF + "Done: " + ;
            iif( empty( oClient:cReply ), ;
                 "(no goodbye message)", ;
                 'goodbye message "' + oClient:cReply + '"' ) )
     MsgInfo( "Can't open URI " + cUrl )
     MsgInfo( "Can't open URI " + cUrl + CRLF + ;
              'oClient:Reply = "' + oClient:cReply + '"')
 MsgInfo( "That's all folks!" )
 oMail := .F.
 cUrl := .F.
 oUrl := .F.
 oClient := .F.
 ---------- finish of code -------------
It's my start step. But I don't know yet how I can:
- to get list of NEW mails (or check - is this 2nd mail "new"?);
- get (for example) 1st mail;
- check "do you have attach(es)";
- if "yes" - save attach(es) to pre-define folder;
- marked mail as "read";
Advices?
P.S. This work should be made urgently - the reports from hospitals about the patients by an influenza will be treated (and now in Russia there is epidemic - as well as all over the world, as is known)
P.P.S. My "expirience" in this part of Harbour programming may be useful for many HMG-heads (I think). "Enlarge your... HMG-power!" :)
ClaudioGalera
Post by ClaudioGalera »
Hi, Alex
You can play with the POP protocol with TELNET
Please read this, here's how to connect and how to use
http://www.yuki-onna.co.uk/email/pop.html
and http://en.wikipedia.org/wiki/Post_Office_Protocol - Google : http://www.google.com.ar/#hl=es&q=telne ... 43995f18ee
8) goto point (4)
1) I do not know as the use of the library, but you must specify the POP server name with port 110
2) send to the server the command
USER userName
send the password
PASS passW0rd
3) for the amount we list the mail that has the server via the command
LIST
and returns a message similar
+OK 3 messages
1 1205
2 305
3 344400
The first number is the Id mail and next number the size in bytes.
How to distinguish the new from the old mail? Simple, after you lose the mail to the client pc and once given the ok, you are given the order to delete on the server. The next time that you go to see, you will see only the new.
4) whit the command
RETR msg#
where msg# is the id number of the LIST
5-6-7) the attachements is encoded in the mails body as MIME data.
You will have to analyze the mail's body and view the contents. Then decoded the MIME part.
Next save the data, and if all ok delete the mail on the server
DELE msg#
8)...
9) Use
QUIT
"This deletes any messages marked for deletion, and then logs you off of the mail server. This is the last command to use. This does not disconnect you from the ISP, just the mailbox." http://techhelp.santovec.us/pop3telnet.htm
I hope that you find this helpful. I have never used at Harbor-HMG, only on VBasic investigating pop protocol.
Sorry for my english. Regards
Claudio
Alex Gustow
Hi Claudio!
Many thanks for advices - very-very interesting!
I'll play with it tomorrow (right now it's 20:30 - but I still sit in office and try to write something... oh my poor head! :( no, stop! enough! I'm coming home :) )
If I'll do some useful - I'll post about it on forum of course.
Alex Gustow
PROBLEM SOLVED !
Thanks to all, brothers, for support and help! :)
See little description here:
http://hmgforum.com/viewtopic.php?p=6751#p6751
I'll post working sample (maybe it will helps to someone) ASAP.
fchirico
Post by fchirico »
Alex Gustow wrote:PROBLEM SOLVED !
Alex,
I am interested in the topic, when you can, please post an example.
Thanks in advance.
Saludos, Fernando Chirico.
Alex Gustow
Alex,
Thanks in advance.
OK - I'll try to post short but really working example tomorrow. It will increase our common knowledge and power of HMG (I hope)!
If you, guys, want - I'll upload here Help (.CHM) from xHarbour bundle (I downloaded it - bundle - from free.xharbour.com as I wrote yesterday). It contains (except for other) good description of classes and methods from TIP.LIB (TipClient, TipClientPOP, TipMail etc.) (with short but good examples). It was very useful (for me - in this difficult & unusual work). I think it will be useful for others (even for guys who does not use xHarbour - but Harbour only). If I only knew about it week back!..
I think I'll be not a "very bad boy" or "pirate" :) (Copyright 2006-2007 xHarbour.com - xHarbour Language Reference Guide version 1.1).
fchirico
Post by fchirico »
Alex,
Thanks in advance.
Ok, slowly, no problem.
If you, guys, want - I'll upload here Help (.CHM) from xHarbour bundle .....
Yes, please!
Here in Argentina we have a saying "The abundant, no harm."
No, you are not a bad boy :evil:
