IDE 3.0 UPDATE
IDE 3.0 UPDATE
This new update features automatic formatting for 'Copy target to' configuration setting and read capability for report builder (only reports generated from this version can be read by the builder).
Enjoy!
ide_30_test_11e.rar
(814.73 KiB) Downloaded 493 times
Vanguarda
Re: IDE 3.0 UPDATE
Post by Vanguarda »
Thanks Master for this new release.
Wtih best regards,
Re: IDE 3.0 UPDATE
Thanks a lot Maestro :)
Best regards
sudip
Re: IDE 3.0 UPDATE
Post by sudip »
Hello Master Roberto,
I tested it. It works fine. Thanks a lot :)
I have some points. Please check those points in your off time :)
1) Add Form in Project menu.
2) Report editor for array. If there is any option to choose code editor for editing .rmg file, that will solve the purpose also.
With best regards.
Re: IDE 3.0 UPDATE
sudip wrote: 2) Report editor for array. If there is any option to choose code editor for editing .rmg file, that will solve the purpose also.
I'm thinking about that from some time ago.
The problem is that such feature will impede preview, since IDE will be not able to reproduce the state of your applications variables. I'm thinking in an 'elegant' way to handle it :)
sudip
Re: IDE 3.0 UPDATE
Post by sudip »
Can you please add "Recent Projects" sub-menu in "File" menu of IDE :) It will be great helpful for the programmers who are using more than one projects at the same time (like myself ;) )
With best regards.
Re: IDE 3.0 UPDATE
Working with reports I found that I can use dbf only from main folder of project. Meanwhile, I places my dbf files in subfolders to maintain order.
Now, I must copy my dbf file to main folder, then define report...
Re: IDE 3.0 UPDATE
Sudip, Marek,
I'm working now on give full functionality to report builder, when finish with that, I´ll consider other additions.
Both are interesting suggestions.
sudip
Re: IDE 3.0 UPDATE
Post by sudip »
I hope we are going to have final version of HMG 3.0.0 very soon :)
(But, please take your time and do your magical work as you like :) )
With best regards.
Re: IDE 3.0 UPDATE
sudip wrote:Hello Master Roberto,
With best regards.
We do not have an HMG 3.0 final release until a Harbour 2.0 Harbour release be published :)
