HMG 3.5
jorge.posadas
Re: HMG 3.5
Post by jorge.posadas »
Muchas gracias por esta nueva versión
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
apais
Re: HMG 3.5
Post by apais »
That old SSL has security issues and is not compatible with the most current curl lib.
Would be better to compile HMG with an up to date harbour as I have done in my recently published compilation made in GitHub.
Github actions is the way to go.
Angel Pais
Re: HMG 3.5
i have try to compile "lates" harbour Source but it fail with Error at hbsocket ...
gcc -I. -I../../../../../include -W -Wall -O3 -fomit-frame-pointer -march=i586 -mtune=pentiumpro -DUNICODE -DHB_HAS_PCRE -Ic:/HB/src/3rd/pcre -DPCRE_STATIC -DHB_HAS_ZLIB -Ic:/HB/src/3rd/zlib -ohbsocket.o -c ../../../hbsocket.c
In file included from ../../../hbsocket.c:223:0:
../../../hbsocket.c: In function 'hb_socketSetOsError':
../../../hbsocket.c:1109:12: error: 'ERROR_NOT_ENOUGH_MEMORY' undeclared (first use in this function)
case WSA_NOT_ENOUGH_MEMORY:
../../../hbsocket.c:1109:12: note: each undeclared identifier is reported only once for each function it appears in
../../../hbsocket.c: In function 'hb_socketGetIFaces':
../../../hbsocket.c:4093:29: error: 'ERROR_BUFFER_OVERFLOW' undeclared (first use in this function)
if( dwResult == ERROR_BUFFER_OVERFLOW )
../../../hbsocket.c:4099:29: error: 'NO_ERROR' undeclared (first use in this function)
if( dwResult == NO_ERROR )
../../../../../config/rules.mk:88: recipe for target 'hbsocket.o' failed
win-make[3]: *** [hbsocket.o] Error 1
../../config/lib.mk:68: recipe for target 'descend' failed
win-make[2]: *** [descend] Error 2
../config/dir.mk:71: recipe for target 'rtl' failed
win-make[1]: *** [rtl] Error 2
config/dir.mk:71: recipe for target 'src' failed
win-make: *** [src] Error 2
so if someone have a "Working" harbour Source please tell me where to download.
btw. harbour Version v3.0.0 can complete compile so my Environment is OK
but it is old Version and some newer HB_FUNC are missing ...
Carlos Britos
Re: HMG 3.5
Post by Carlos Britos »
AUGE_OHR wrote: Wed Nov 18, 2020 8:49 pm so if someone have a "Working" harbour Source please tell me where to download.
Take a look here
you can find 2 packages
1 with all harbour exes and lib
2 with all harbour exes and lib plus dlls and lib for dlls
https://github.com/asistex/hmg_tools_compilation
If you want to compile your self the last version of harbour , you will find the scripts
https://github.com/asistex/hmg_tools_co ... /workflows
These script run on github
Carlos
jorge.posadas
Re: HMG 3.5
I can't download HMG 5.0,
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Morelia, Mich.
M é x i c o .
Re: HMG 3.5
I have seen three people complaining about virus in the setup exe file.
Any body who could download in Win10 64?
Re: HMG 3.5
Rathinagiri wrote: Thu Nov 19, 2020 7:06 am I have seen three people complaining about virus in the setup exe file.
I am not facing problem while downloading on Win 10 64 bit
Re: HMG 3.5
Carlos,
Where to put
File contains:
ACESDK.ZIP
AES.ZIP
CUR....ZIP
HB32 (2). ZIP
OPENSSL.ZIP
Is it HMG.3.5\LIB ?
Carlos Britos
Re: HMG 3.5
serge_girard wrote: Thu Nov 19, 2020 9:28 am Carlos,
Where to put
ACESDK.ZIP
AES.ZIP
CUR....ZIP
HB32 (2). ZIP
OPENSSL.ZIP
Is it HMG.3.5\LIB ?
Hi Serge
- acesdk
- OpenSSL-Win32
- curl-7.54.0-win32-mingw
Are already used to create the harbour package
They are the same used by A.Linares in his releases.
OpenSSL-Win32 and curl-7.54.0
In my opinion are outdated
The last version of:
openssl-1.1.1h_1 win32/64 mingw
curl-7.73.0_1 win32/64 mingw
I've uploaded but not tested with harbour yet. I need help on this.
The harbour package are created by the lastest sources from harbour 32 from github. It's already on HMG 35.
Aes is an optional lib. You can add it to your projects.
author Rathinagiri.
From somewhere here in forum
Carlos Britos
Re: HMG 3.5
Anotación 2020-11-19 093222.jpg (28.39 KiB) Viewed 32556 times
