Making libraries in current version
Source code related resources
kcarmody
Post by kcarmody »
I've downloaded the current version of HMG from Github https://github.com/HMG-Official/HMG . I tried to run two batch files in the root directory, BuildLib32.bat and BuildAllLib32.bat.
Both of these batch files say they cannot find hbmk2. This is the Harbour make utility, which is in HARBOUR\bin\ in 3.4.4 and in HARBOUR\bin\win\mingw\ in the new version. The batch files are unchanged from 3.4.4 and have not been updated to reflect the new location of the Harbour executables. I'm therefore unable to make HMG libraries or executables with this new version in its current configuration.
In addition, Mingw and the lib folder have been omitted from the new version. I think that every new version should include Mingw and compiled libraries in the lib folder, and it should be properly tested before release, including building the libraries and some demos.
I don't think it's a good idea to change the location of hbmk2 and other Harbour and Mingw components. Critical folder locations should not be changed unless necessary, as it may break users' batch files.
Re: Making libraries in current version
kcarmody wrote: Sun Nov 01, 2020 6:51 pm I've downloaded the current version of HMG from Github https://github.com/HMG-Official/HMG . I tried to run two batch files in the root directory, BuildLib32.bat and BuildAllLib32.bat.
try to run in CMD BOX
BUILD.BAT "only" before BuildLib32.bat / BuildAllLib32.bat.
kcarmody
Post by kcarmody »
AUGE_OHR wrote: Sun Nov 01, 2020 8:00 pm
OK, I opened a command box at the HMG root directory. I typed build and got this:
| was unexpected at this time.
Then I typed buildlib32 and pressed Enter when it asked me to select an option. I got this:
 Build Library:         UNICODE
'hbmk2' is not recognized as an internal or external command,
operable program or batch file.
Press any key to continue . . .
Is this what you meant? build.bat is meant to be followed by a source file name, and buildlib32 needs to be able to find hbmk2, but the path that is within buildlib32.bat is not where hbmk2 actually is.
I could make buildlib32.bat work by moving the Harbour executables around and copying Mingw from 3.4.4. My point is that these steps should not be necessary. The HMG master on Github should be set up so that these batch files work. And more than that, it should not necessary to compile the libraries -- they should be in the HMG master, ready for everyone to build applications.
hi
Ok, i understand : Environment is missing :!:
like under Cl*pper i recommend to set Path, INCLUDE and LIB
run this
rundll32.exe sysdm.cpl,EditEnvironmentVariables
add Path, INCLUDE and LIB (here 64 Bit Version)
INCLUDE=c:\hmg.3.4.4\HARBOUR-64\include\;c:\hmg.3.4.4\INCLUDE\;
LIB=c:\hmg.3.4.4\HARBOUR-64\lib\;c:\hmg.3.4.4\LIB-64\;
PATH=c:\hmg.3.4.4\HARBOUR-64\bin\;
last line will point to hbmk2
re-Login to get new Environment
C:\hmg.3.4.4\build64.bat have some more "SET" which is need before BuildLib work correct
kcarmody
Post by kcarmody »
AUGE_OHR wrote: Mon Nov 02, 2020 12:24 amlike under Cl*pper i recommend to set Path, INCLUDE and LIB
Yes, I can do that or something like that, but I was not asking how to fix it for myself. I was telling everyone who maintains the Github master that nothing like this should be necessary. In the past, HMG worked without such modifications, and it should continue to do so. HMG is broken and should be fixed. The maintainers of the HMG master broke it, and they should fix it.
Look at the first few lines of BuildAllLib32.bat. It adjusts the user's path so that it can find hbmk2 and other executables it needs. The user does not have to do this -- the batch file does it. The problem is that, in the master, these executables have been moved, but these lines were not changed. So this batch file no longer works. The maintainers of the HMG master should fix everything that they broke.
yes you are absolute right.
i had that Problem with Environment as Newbie when i want to include change to Debugger.
i have compare *.BAT files with my from 2016 and they are same :?:
so it must have change before 2016.
can you upload "old" files please.
Carlos Britos
Post by Carlos Britos »
Hi
If you want to compile the source in hmg official or in your fork use this script.
To compile your fork you must replace HMG-Official with kcarmody
This will build all hmg libs and harbour binaries
hmg34offi_all_hb32_mgw930_32b_uni.yml
This will build all hmg libs and harbour binaries.
To run it open Action in github and create a new.
Actions -> new workflow -> manual workflow -> setup this workflow
Replace the text in there with this script and Start commit
This will run the script and create (if all is ok) the Artifac with the zip file.
After that, every time you commit something this will be triggered unless you disable it.
This compilation will use harbour binaries created on 2020/10/27
name: HMG official all libs 32bit MinGW 930 unicode
on:
    push:
jobs:
  build:
    runs-on: windows-latest
    if: github.actor == github.event.repository.owner.login
    steps:
    - name: Checkout HMG-Official repo
      uses: actions/checkout@v2
      with:
       repository: HMG-Official/HMG
       path: HMG-Official/HMG
    - name: Install dependencies
      run: |
        (new-object System.Net.WebClient).DownloadFile('https://bitbucket.org/lorenzodla/mod_harbour_actions_resources/downloads/mingw32.zip', 'C:\temp\mingw32.zip')
        Expand-Archive -LiteralPath C:\temp\mingw32.zip -DestinationPath C:\mingw32 -Force
        (new-object System.Net.WebClient).DownloadFile('https://github.com/asistex/HMG/raw/master/workflows/hb32_mgw930_32b_2020_10_27.zip', 'C:\temp\harbour.zip')
        Expand-Archive -LiteralPath C:\temp\harbour.zip -DestinationPath C:\harbour -Force
        gcc --version
    - name: Building lib HMG
      shell: cmd
      run: |
        cd HMG-Official\hmg
        set path=c:\mingw32\mingw32\bin;c:\harbour\bin;%path%
        BuildAllLib32.bat
    - name: Create output folders...
      shell: cmd
      run: |
        mkdir output
        robocopy HMG-Official\hmg\source output\source /E
        if %ERRORLEVEL% EQU 1 set ERRORLEVEL=0
        robocopy HMG-Official\hmg\lib output\lib /E
        robocopy HMG-Official\hmg\include output\include /E
        robocopy HMG-Official\hmg\doc output\doc /E
        robocopy HMG-Official\hmg\samples output\samples /E
        robocopy HMG-Official\hmg\hfsl output\hfsl /E
        robocopy HMG-Official\hmg\resources output\resources /E
        robocopy HMG-Official\hmg\workflows output\workflows /E
        robocopy HMG-Official\hmg\harbour output\harbour /E
        copy HMG-Official\hmg\*.* output\
    - name: Get current time
      uses: srfrnk/current-time@master
      with:
        format: YYYY_MM_DD
    - name: Create artifact
      env:
        TIME: "${{ steps.current-time.outputs.formattedTime }}"
      uses: actions/upload-artifact@v2
      with:
        name: hmg34offi_all_hb32_mgw930_uni_${{ env.TIME }}
        path: output
kcarmody
Post by kcarmody »
Carlos Britos wrote: Mon Nov 02, 2020 10:32 amIf you want to compile the source in hmg official or in your fork use this script....
Thanks, it's good to know. Have you tested this? It calls BuildAllLib32.bat, which I have already shown is broken.
Even if it does work, it still is not a solution to the problems I first reported. The Harbour binaries would still be in the wrong place, and Mingw would be missing from the distribution. All of these issues need to be fixed in the master.
It would be good if the maintainers of the HMG master would use a procedure like this on the master. Then everyone would have the binaries and would not need to compile the libraries themselves.
kcarmody
Post by kcarmody »
AUGE_OHR wrote: Mon Nov 02, 2020 8:55 ami have compare *.BAT files with my from 2016 and they are same :?:
No, the change was made after 3.4.4 (2017-03-29, batch files modified 2016-05-01). In the original distribution of 3.4.4, the Harbour executables were in HARBOUR\bin\ . In the Github distribution of 3.4.4, they were in HARBOUR\bin\win\mingw\ . They are still there in current Github distribution.
You can download version 3.4.3 at https://sourceforge.net/projects/hmg/ . I don't know where you download 3.4.4.
