Sudip,sudip wrote:Hello Grigory,
Thanks a lot. It runs fine with HMG
Again, as a learner of both versions I want to know what's the difference between previous and current code![]()
There is the following change in the HMG Extended Edition introduced in the build 40:
The aboved change simplify a code or else it will be reguired to use the logical variable lInit for disable 'On Change' action at the form's creation* Changed: The ON CHANGE control event is disabled at the form's definition.
