NC Clone
gfilatov
Re: NC Clone
Post by gfilatov »
AUGE_OHR wrote: Fri Sep 25, 2020 5:40 am hi,
it seem there is a big BUG in HBFM since v1.17 :shock:
after delete a File HBFM does not work correct with F3/F4 and show "black" Window or "no Image" etc. :evil:
Hi Jimmy,
You are correct - there is a bug in the C-function GETICOINDEX().
Please take a look for the fixed function below:
HB_FUNC( GETICOINDEX )
   int nSize = ( HB_ISNUM( 2 ) ? hb_parni( 2 ) : 0 );
   SHFILEINFO sfi = { 0 };
   SHGetFileInfo( hb_parc( 1 ), 0, &sfi, sizeof( SHFILEINFO ), SHGFI_ICON | nSize );
   hb_retnl( ( LONG ) sfi.iIcon );
   HB_STORNL( ( LONG_PTR ) ( HICON ) sfi.hIcon, 3 );
Sample code:
         nIndex := GETICOINDEX( cFile, nSize, @hIcon )
      ListView_SetItemImageIndex( GetControlHandle( cObj, cForm ), i, 1, nIndex )
      IF Valtype( hIcon ) != "U"
         IF DestroyIcon( hIcon )
            hIcon := NIL
Hope that helps :idea:
Re: NC Clone
gfilatov wrote: Fri Sep 25, 2020 9:41 am You are correct - there is a bug in the C-function GETICOINDEX().
YES , THX :!:
i have not test to Delete Files so i have not recognize my Error, sorry :roll:
so here latest Version v1.29
32 Bit
HBFM_129.zip
(2.19 MiB) Downloaded 263 times
64 Bit
HBFM64_129.zip
(2.51 MiB) Downloaded 229 times
i will also update on GitHub.
i will add a Folder \SOURCE which include Change of HMG LIB to use Type "T" or "@" and "I"
please look into README.TXT
! Note : Files are documented by CLICK
// v.1.29 22.09.2020 BUG GETICOINDEX() sind v1.17 in FMGRID.PRG DirImageColor()
// v.1.28 21.09.2020 integrate VFP Type "I" and "@" (Timestamp)
// need change in HMG \Source\H_BROWSE.PRG amd h_controlmisc.prg
Re: NC Clone
latest Version v1.35
32 Bit
HBFM_135.zip
(2.2 MiB) Downloaded 248 times
64 Bit
HBFM64_135.zip
(2.52 MiB) Downloaded 253 times
i have change Image Viewer while i want to add
   // more FreeImage
   CASE cExt $ ".PSD.ICO.EXR.PCX.PPM.PSD.WEBP.JP2.PPM"
now i "paint" Picture using BitBlt() / StretchBlt()
if Edit Picture all is done on "temp file" and later ask to save it
! Note : rotate in Thumbs WILL change Original Picture without asking !
fixed :
BUG DestroyIcon() for HMG
new :
HB_FUNC.PRG for 32 and 64 Bit
// v.1.35 03.10.2020 BUG DestroyIcon() for HMG_*
// v.1.34 30.09.2020 HB_FUNC.PRG "64 Bit ready" using HMG_* instead of hb.*
// v.1.33 29.09.2020 FreeImage : HB_FUNC ( FREE_DRAWPICTURE ) re-size
// v.1.32 28.09.2020 FreeImage Workfile when view or rotate.
// will ask to Save Workfile which Replace Original !
// Thumbs direct Replace Original !
// v.1.31 27.09.2020 FreeImage now also use for Viewer and Picture > Screen
// v.1.30 26.09.2020 Problem when delete many Files. now BEGIN SEQUENCE
Re: NC Clone
here lates Ver v1.38
32 Bit
HBFM_138.zip
(2.2 MiB) Downloaded 290 times
64 Bit
HBFM64_138.zip
(2.52 MiB) Downloaded 271 times
after got that "Apple Email Attachment" i have change Codepage to UTF8
but i also have to change DLL Funtion from "A" to W"
FreeImage and ShFileOperation are still ANSI so i have to convert Filename to ANSI when call these Function
btw. Extended Version have ShFileOeration but also only "A" Version.
c:\MiniGUI\SOURCE\shell32\Shell32.prg
i do upload each Version to Github but only "Stable" Version in Forum.
if you find a reproducible Error please write me a Email (about -> mail to author )
fixed : DestroyIcon() 2nd fix in HB_FUNC.PRG
New : UTF8 as default Codeepage.
change DLLcall from "A" to "W"
add : runAs Adminstrator in Pop-Up Menu
// v.1.38 13.10.2020 German "umlaute" from Apple Email CHR(204)
// v.1.37 07.10.2020 enhance HMG_Calldll() "A" and "W"
// v.1.36 06.10.2020 change to Codepage UTF8
HGAutomator
Re: NC Clone
Post by HGAutomator »
Hi Auge,
I tried running both the 32 and 64 bit versions, and neither of them run.
I need a more maximized file manager than HMG's FileMan. I'd prefer text mode, but the one at https://github.com/omm/harbour-commander was never completed.
When I run 32-bit HBFM, it just returns without doing anything.
The 64-bit version says that the Application was unable to start correctly.
Do you have the most recent source, so I can try to compile it here?
Re: NC Clone
HGAutomator wrote: Wed Jan 11, 2023 9:47 pm I tried running both the 32 and 64 bit versions, and neither of them run.
please try
dir %appdata%\HMG
please delete FMSETUP.DBF / FMSETUP.fpt if found ant try start again
HGAutomator
Re: NC Clone
There's no HMG folder inside of the ../AppData/Roaming folder.
Anyway, never mind, I found your source on github
https://github.com/AugeOhr/HBFM
HGAutomator
Re: NC Clone
Ah. Beautiful. Works like a gem, thanks.
I'll donate to MiniGui this month. If you have a Paypal address, please forward so I can send you something as well.
HGAutomator
Re: NC Clone
Hi Auge_ohr,
The pre-compiled 64-bit executable is working perfectly. Thanks for taking the time to put it together.
However, I'm not able to compile from the github source.
If you have time, can you forward your environment, related to Minigui? I think the most important is probably the INCLUDE environmental variable. Possibly I should reorder the INCLUDE paths, or maybe even take one out.
Here are the errors I'm getting. This is from the Mingw Minigui version, but there are similar errors with the borland minigui.
FMCOLOR.PRG >> HBFM.LOG
i_var.ch(54) Error E0003 Duplicate variable declaration '_HMG_SYSDATA'
FMGRID.PRG(189) Error E0009 Illegal variable 'NLASTVIEW' initializer ''
FMGRID.PRG(318) Error E0030 Syntax error "syntax error at 'WINDOW'"
FMGRID.PRG(484) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(490) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(991) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(1003) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(1319) Error E0030 Syntax error "syntax error at '@'"
FMGRID.PRG(1375) Error E0030 Syntax error "syntax error at '@'"
FMGRID.PRG(2280) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(2998) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(2999) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(3751) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(4626) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(4640) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(4828) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(4850) Error E0030 Syntax error "syntax error at '.'"
FMGRID.PRG(6255) Error E0030 Syntax error "syntax error at '.'"
HBDEVICE.PRG(98) Error E0030 Syntax error "syntax error at ')'"
HBDEVICE.PRG(109) Error E0010 ENDIF does not match IF
HBDEVICE.PRG(121) Error E0030 Syntax error "syntax error at 'FUNCTION'"
HBEJECT.PRG(562) Error E0030 Syntax error "syntax error at '.'"
HBEJECT.PRG(599) Error E0030 Syntax error "syntax error at '.'"
HBEJECT.PRG(599) Error E0022 Invalid lvalue '()'
HBEJECT.PRG(624) Error E0030 Syntax error "syntax error at '.'"
HBFTP.PRG(132) Error E0003 Duplicate variable declaration '_HMG_SYSDATA'
HMGDLL.PRG(519) Error E0030 Syntax error "syntax error at '.'"
MODISTRU.PRG(112) Error E0030 Syntax error "syntax error at 'WINDOW'"
MODISTRU.PRG(161) Error E0030 Syntax error "syntax error at '.'"
PHONE2.PRG(61) Error E0003 Duplicate variable declaration '_HMG_SYSDATA'
PHONE2.PRG(271) Error E0030 Syntax error "syntax error at '.'"
PHONE2.PRG(330) Error E0030 Syntax error "syntax error at '.'"
PHONE2.PRG(405) Error E0030 Syntax error "syntax error at '.'"
PHONE2.PRG(405) Error E0022 Invalid lvalue '()'
PHONE2.PRG(519) Error E0030 Syntax error "syntax error at '.'"
PHONE2.PRG(519) Error E0022 Invalid lvalue '()'
PHONE2.PRG(571) Error E0030 Syntax error "syntax error at '.'"
THUMBS.PRG(426) Error E0030 Syntax error "syntax error at '.'"
VIEWER.PRG(85) Error E0003 Duplicate variable declaration '_HMG_SYSDATA'
Browser.PRG(1930) Error E0030 Syntax error "syntax error at 'WINDOW'"
AUGE_OHR wrote: Wed Jan 11, 2023 10:58 pm hi,
please try
dir %appdata%\HMG
Re: NC Clone
HGAutomator wrote: Fri Jan 20, 2023 5:32 pm However, I'm not able to compile from the github source.
it is made for HMG not MiniGUI :!:
i have work on a MiniGUI Version but there are too many Difference to HMG
not only *.PRG also HB_FUNC() must be enhance as Grigory show me
i have gave up MiniGUI Version of HBFM , sorry
