NC Clone
Re: NC Clone
Hi Jimmy
download the version HBFM from Github to see where the FTP connection error is generated but when trying to compile it does not find os.ch in
*+ Source Module => c:\hmg.3.4.4\0\HBFM\\HBEJECT.PRG
*+    Copyright(C) 1983-2020 by Auge & Ohr
*+    Functions: Procedure HBEJECT()
*+               Function EjectMedia()
*+               Static Function CreateVolHandle()
*+               Static Function LockVolume()
*+               Static Function DismountVolume()
*+               Static Function AutoEjectVolume()
*+               Static Function UnlockVolume()
*+               Static Function CloseVolume()
*+               Static Function PreventRemovalOfVolume()
*+               Static Function USB_DeviceColor()
*+               Static Function DO_DeviceImage()
*+               Static Function Do_DeviceAction()
*+               Static Function FillDeviceGrid()
*+               Static Procedure SayInfo()
*+    Reformatted by Click! 2.05.30 on Aug-28-2020 at  1:52 am
#include "HMG.ch"
#include "common.ch"
#include "os.ch"
#include "dll.ch"
#include "EJECTDLL.CH"
#include "HBFM.CH"
2020-09-09 04_02_19-Window.png (30.18 KiB) Viewed 10228 times
Re: NC Clone
danielmaximiliano wrote: Wed Sep 09, 2020 5:02 am with HBFM64 the application hangs entering 192.168.1.2:8556 without username and password or with username: anonimous, password: anoimous
I must use the windows Task Kill to kill the HBFM64 process
ooooooh ... :shock:
i must say that i have take Code from c:\MiniGUI\SAMPLES\Advanced\FtpClient\
   cUrl := cProtocol + Alltrim( cUser )+":"+ Alltrim( cPassWord ) +"@"+  alltrim( cServer)
   oUrl := tURL():New( cUrl )
   IF Empty( oUrl )
      return nil
   oClient := TIpClientFtp():new( oUrl, Sites->Log ) && PARAM .T. TO LOG
   IF Empty( oClient )
      return nil
   oClient:nConnTimeout := 20000
   oClient:bUsePasv     := .T.
   // Comprobamos si el usuario contiene una @ para forzar el userid
   IF At( "@", cUser ) > 0
      oClient:oUrl:cServer   := cServer
      oClient:oUrl:cUserID   := cUser
      oClient:oUrl:cPassword := cPassword
have to look deeper for tURL()
Re: NC Clone
danielmaximiliano wrote: Wed Sep 09, 2020 7:06 am does not find os.ch in
aaaaaaaaaaaaarrrrrrrrrg ... it is a Xbase++ Constant
LOCAL nVersion  := VAL( OS( OS_VERSION ) )
harbour does not have Constant as Parameter so i have to re-write that part.
THX that you found that Problem
Re: NC Clone
I had found information about OS () but did not find information about the content of os.ch
https://doc.alaska-software.com/content ... ef_os.html
without this file I can't compile the sources
TIP: when creating a new site it should contain an Anonimous checkbox or fill in the following fields
Checkbox Anonimous.png (12.17 KiB) Viewed 10197 times
   IF xParam = NIL
      newRecord := .f.
      sites->( DBGOTO( sitemanager.browse_1.value ) )
      editsitemanager.text_1.value  := sites->name
      editsitemanager.text_2.value  := sites->address
      editsitemanager.text_3.value  := sites->user
      editsitemanager.text_4.value  := desencri( sites->password )     // decript
      editsitemanager.text_5.value  := Sites->SPath
      editsitemanager.Check_2.value := Sites->Log
      newRecord := .t.
	  editsitemanager.text_3.value  := "anonimous"
      editsitemanager.text_4.value  := "anonimous"
Re: NC Clone
hi
i have not upload OS.CH while it make no Sense ... OS() give me a String under harbour
Windows NT 10.0.19041
but i can´t find out Rest how to identify OS() ... just want to know if it is > Windows XP
about FTP Port
oUrl := TUrl():New( Server + ":" + hb_ntos( Port ) )
is that right :?:
what is the default Port for FTP :idea:
Re: NC Clone
Hi Jimmy : from windows xp there is SystemInfo, its syntax is
systeminfo[.exe] [/s Computer [/u Domain\User [/p Password]]] [/fo {TABLE|LIST|CSV}] [/nh]
from CMD
systeminfo /fo list >SystemInfolist.log
You can also adapt to your convenience
https://github.com/breezechen/systeminf ... systeminfo
Note : ftp port is normally 21.
Re: NC Clone
I don't remember now the name, but hmg has a function to get the os version. Search in the c source files for "osversion" or "version"
Re: NC Clone
! WARNING !
when play with sites.dbf i found a BIG BUG using Modi Stru.
it will DELETE new DBF when Name was in lower Letter :!:
Re: NC Clone
danielmaximiliano wrote: Wed Sep 09, 2020 10:48 pm Note : ftp port is normally 21.
i´m not sure how Syntax with Port work.
i saw this in c:\harbour\contrib\hbtip\tests\email.prg
   CASE ":" $ cHost
      IF TUrl():New( cHost ):nPort != -1
         nPort := TUrl():New( cHost ):nPort
      lSTARTTLS := ( nPort == 587 )
      cHost := TUrl():New( cHost ):cServer
so i change HbFTP to
   cUrl := cProtocol + ALLTRIM( cUser ) + ":" + ALLTRIM( cPassWord ) + "@" + ALLTRIM( cServer )
   IF EMPTY(nPort)
      oUrl := tURL() :New( cUrl )
      oUrl := tURL() :New( cUrl )+":"+hb_NTOS(nPort)
my Problem : don´t know how to test Port ...
Re: NC Clone
srvet_claudio wrote: Wed Sep 09, 2020 11:09 pm I don't remember now the name, but hmg has a function to get the os version. Search in the c source files for "osversion" or "version"
THX, have found
HMG_IsWinVistaOrLater()
HB_FUNC( WINVERSION )
HB_FUNC( WINMAJORVERSIONNUMBER )
HB_FUNC( WINMINORVERSIONNUMBER )
now i use these define in EJECTDLL.CH
#define VERSION_XP                  5.0
#define VERSION_VISTA               6.0
#define VERSION_WIN7                6.01
#define VERSION_WIN8                6.02
#define VERSION_WIN81               6.03
#define VERSION_WIN10              10.0
#define VERSION_WIN10OLD            6.04
so i have to figure out how to re-write my Xbase++ Code.
