formater za hmg programs
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
Harbour is good but is more evolved and now the HMG
Unfortunately HMG does not follow everything that was going along the harbour
One of those things is a formatter code, useful thing that I miss
With clipper I used SNAP application for arranging and documentation purposes of the program
Later I was make something like it, a common mistake is to forget to close the loop so I detected
Then came the HMG and many commands DEFINE ... with which I am not spectacular but now I do not have time to fix
Are someone made a program as HBFormat for HMG programs?
Re: formater za hmg programs
Hi Dragan,
I do it manually.... it takes some discipline!
S
chrisjx2002
Post by chrisjx2002 »
Years ago I improved a program from Joe Fannucchi that makes indentation of prg programs.
You wil find attached the source and two language files : english and french.
IndentV19.zip
IndentV19
(15.64 KiB) Downloaded 731 times
Merci Chrisjx2002 !
ça marche,
chrisjx2002
De rien...
serge_girard wrote:Merci Chrisjx2002 !
ça marche,
dragancesu
Thank you Chrisjx2002 !
it's very usefull
Dragan
Look at Click! in the Oasis : legendary utility by sainted Harbour guru and former Harbour manager Phil Barnet (RIP).
Click! is a CA-Clipper and Xbase++ source code reformatter. This is much more than a simple reindenter, but actually reestablishes spacing between elements in the lines of code and creates function cross reference charts.
Fully documented and configurable.
Viva Clipper, viva Harbour, viva HMG :D
Tiger
Post by Tiger »
I just do some more changes on this program:
1. Add option to indent " With Object / End With " structure
2. Add the comments to IF /FOR /WHILE / WITH
IF AAA
IF BBB
IF CCC
ENDIF //CCC
ENDIF //BBB
ENDIF //AAA
It seems work :roll: ... please do a backup 1ST ... if you want to try it ....
indent_20.rar
(14.44 KiB) Downloaded 623 times
dragancesu
This is very good
