PostgreSql Libs not ready yet ?
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hello everybody,
I would like to know if there is ( or anybody have ) a really working sample of PostgreSql.
I tried to compile the PosgrSql_1 sample from HMG 3.4.4. and got some errors that I Can´t solve because there are some functions that does not exists in Libhmg nor Libhmgpgsql.
Salamandra, Brazil
Re: PostgreSql Libs not ready yet ?
as i can say HMG Sample is incomplet
here missing PgRDD.PRG
PGRDD.ZIP
(3.49 KiB) Downloaded 197 times
add PgRDD.PRG to demo.hbp
add : libs=hbpgsql.hbc
now when start it need LibPQ.DLL > v7.x and some other DLL here from v8.x
comerr32.dll
gssapi32.dll
k5sprt32.dll
krb5_32.dll
libeay32.dll
libiconv-2.dll
libintl-8.dll
libpq.dll
msvcr71.dll
ssleay32.dll
! Note : that is for 32 Bit OS
for 64 Bit Apps we need new LIBs ...
salamandra
Hi Jimmy,
AUGE_OHR wrote: Wed Jul 15, 2020 5:32 am hi,
PGRDD.ZIP
comerr32.dll
gssapi32.dll
k5sprt32.dll
krb5_32.dll
libeay32.dll
libiconv-2.dll
libintl-8.dll
libpq.dll
msvcr71.dll
ssleay32.dll
Thank you very much for your help. PGRDD.prg it´s already missing.
I´d put ít in the PostgrSql´s sample folder and recompile. And... more errors.
Also needded to add libhbpgsql.a and libhbpgsql_dll.a, recompile and.... more errors....
and after add...
It seems the endless story...
Did you try the HMG extended sample ? It compiles without any error but does not run because of libpq.dll (I don´t know wich is the right version).
I´ll try again in a few days.
Salamandra, Brazil
i have build Demo.EXE as i show above.
libpq.dll and other DLL are from PostgreSQL v8.x. i will try v9.5x
Demo.EXE start and create Table but i have Problem to use "PGRDD" to "open" it ... hm ... :(
i have to look into PgRDD.PRG what it is doing.
using SQL the Problem is "missing ISAM" so you can´t "navigate" like in DBF
Alaska have a PG-ISAM "Emulation" but it have a lot of overhead and is slow.
the Idea is to use old Code (fo DBF) and "just" change DBE (RDD) to use PostgreSQL
Question : how does harbour work with SQL ? does MySQL / MariaDB "Wrapper" have some "ISAM-Emulation" :idea:
salamandra
Hi Jimmy,
AUGE_OHR wrote: Wed Jul 15, 2020 9:58 pm hi,
Well, finally I got to compile without errors the demo program using all DLLs from Postgre Sql v8.
It compiled without errors, but does not open the main window, does not connect to database neither shows any error messages.
( I´ve tested the database engine and works properly ).
I think PostgreSql it´s not ready to use at this moment (at minimum level) and it´s not worth to continue spending time (mine), there are too many other flavors of SQL to choose.
Thank you for your help.
Salamandra, Brazil
i "think" COLUMNCONTROLS() are not need but COLUMNFIELDS() are missing in Demo.PRG
COLUMNFIELDS { 'cCode' , 'Name' , 'Salary' , 'Creation' , 'Description' }
! Note : have rename "code" to "cCode"
now it got GRID ... but it is empty :o
when look in Debugger it have open Workarea
so what do i miss :idea:
please help
p.s. have also try BROWSE but same empty
salamandra
Hi Jimmy,
As I said, I got compile but exe crashes just after try to connect to server.
I used DLLs from version 8.3 and run Server version 9.4 (version 8.3 installs but does not run)
What DLLs version have you used to compile ? and what server version are you running?
I think I´ll do a new test in the next week with a brand new demo prg
best regards,
Salamandra, Brazil
edk
Post by edk »
AUGE_OHR wrote: Thu Jul 16, 2020 1:49 am hi,
please help
Note the type of fields, they are all "U". This is probably the reason why the data is not shown in Grid and Browse.
have found PgRDD.PRG in old harbour Version. like SQLMIX it use USRRDD code.
but under harbour v3.x there is no Sample any more so i´m not sure if PgRDD.PRG is still valid :?:
have test this
  FOR EACH aFieldStruct IN aStruct
       aField := ARRAY( UR_FI_SIZE )
       aField[ UR_FI_NAME ]    := aFieldStruct[ DBS_NAME ]
       IF VALTYPE(aFieldStruct[ DBS_TYPE ]) = "U"
         aField[ UR_FI_TYPE ]  := "C"
         aField[ UR_FI_TYPE ]  := aFieldStruct[ DBS_TYPE ]
but aFieldStruct[ DBS_TYPE ] is valid
i guess "PGRDD" does not work as expect ...
how does USRRDD work ... any Information about it :idea:
jairpinho
Post by jairpinho »
salamandra wrote: Tue Jul 14, 2020 11:42 pm Hello everybody,
Salamandra, Brazil
ola segue um exemplo funcional testado com versão postgresql-9.1.1-1-windows, instalar e colocar a senha 123456
English:
hello follows a functional example tested with postgresql-9.1.1-1-windows version, install and set password 123456
POSTGRESQL.1A.zip
(3.24 MiB) Downloaded 197 times
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
