OT: API Google crear gráficas
Re: OT: API Google crear gráficas
mais ,c'est avec une base de données variable que je n'arrive pas a réaliser(le nombre de référence est variable).
traduction google:
but it is with a variable database that I can not seem to realize (the reference number is variable).
traduction google:
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Y.TABET
Edward's sample is working like a charm, but when i modified a combo chart, then does not appear the generated html.
GoogleChart.html file is ready and appears in browser.
What could be the problem?
https://developers.google.com/chart/
Function Main()
DEFINE WINDOW Win_1 AT 192 , 422 WIDTH 600 HEIGHT 500 TITLE "Google Chart Html Sample" MAIN
@ 60,390 TEXTBOX t_Width ;
WIDTH 50 ;
VALUE 480 ;
NUMERIC INPUTMASK "999"
@ 100,390 TEXTBOX t_Height ;
WIDTH 50 ;
VALUE 250 ;
@ 60,340 LABEL Label_2 ;
WIDTH 50 HEIGHT 20 ;
VALUE 'Width'
@ 100,340 LABEL Label_3 ;
VALUE 'Height'
@ 100, 460 BUTTON Button_1 ;
CAPTION "Generate" ;
ACTION GoogleChartApi_() ;
WIDTH 70 HEIGHT 28
DEFINE ACTIVEX Activex_1
ROW 150
COL 20
WIDTH 540
HEIGHT 200
PROGID "shell.explorer.2"
END ACTIVEX
HMG_ChangeWindowStyle(GetControlHandle("Activex_1","Win_1"), WS_EX_CLIENTEDGE, NIL, .T.)
oActiveX:= GetProperty('Win_1','Activex_1','Object')
oActiveX:Silent := 1
CENTER WINDOW Win_1
ACTIVATE WINDOW Win_1
Function GoogleChartApi_()
Local cApiUrl := "https://chart.googleapis.com/chart"
Local cPOSTdata := ""
LOCAL oGoogle, cGoogleResp
Local cChartType := "ColumnChart"
Local cChartWidth := Alltrim(STR( Win_1.t_Width.Value ) )
Local cChartHeight := Alltrim(STR( Win_1.t_Height.Value ) )
Local i, cChartData := "", cChartLabel := ""
Local cHeaders := "User-Agent: Mozilla/5.0 (compatible; MSIE 9.0; Windows Phone OS 7.5; Trident/5.0; IEMobile/9.0)"
Local cHtmlFile := "GoogleChart.html"
Local cLocalUrl := "file:///" + GetCurrentFolder() + "/" + cHtmlFile
Local cHtmlString := "" //"<!-- saved from url=(0017)" + "http://localhost/" /* cLocalUrl */ + " -->" + CRLF
cHtmlString += "<html>" + CRLF
cHtmlString += "<head>" + CRLF
cHtmlString += '<script type="text/javascript" src="https://www.gstatic.com/charts/loader.js"></script>' + CRLF
cHtmlString += '<script type="text/javascript">' + CRLF
cHtmlString += "google.charts.load('current', {'packages':['corechart']});" + CRLF
cHtmlString += "google.charts.setOnLoadCallback(drawVisualization);" + CRLF
cHtmlString += "function drawVisualization() {" + CRLF
cHtmlString += "var data = google.visualization.arrayToDataTable([" + CRLF
cHtmlString += "['Month', 'Bolivia', 'Ecuador', 'Madagascar', 'Papua New Guinea', 'Rwanda', 'Average']," + CRLF
cHtmlString += "['2004/05', 165, 938, 522, 998, 450, 614.6]," + CRLF
cHtmlString += "['2005/06', 135, 1120, 599, 1268, 288, 682]," + CRLF
cHtmlString += "['2006/07', 157, 1167, 587, 807, 397, 623]," + CRLF
cHtmlString += "['2007/08', 139, 1110, 615, 968, 215, 609.4]," + CRLF
cHtmlString += "['2008/09', 136, 691, 629, 1026, 366, 569.6]" + CRLF
cHtmlString += "]);" + CRLF
cHtmlString += "var options = {" + CRLF
cHtmlString += "title : 'Monthly Coffee Production by Country'," + CRLF
cHtmlString += "vAxis: {title: 'Cups'}," + CRLF
cHtmlString += "hAxis: {title: 'Month'}," + CRLF
cHtmlString += "seriesType: 'bars'," + CRLF
cHtmlString += "series: {5: {type: 'line'}}" + CRLF
cHtmlString += "};" + CRLF
cHtmlString += "var chart = new google.visualization.ComboChart(document.getElementById('chart_div'));" + CRLF
cHtmlString += "chart.draw(data, options);" + CRLF
cHtmlString += "}" + CRLF
cHtmlString += "</script>" + CRLF
cHtmlString += "</head>" + CRLF
cHtmlString += "<body>" + CRLF
cHtmlString += '<div id="chart_div" style="width: '+cChartWidth+'px; height: '+cChartHeight+'px;"></div>' + CRLF
cHtmlString += "</body>" + CRLF
cHtmlString += "</html>" + CRLF
STRFILE( cHtmlString , cHtmlFile)
Win_1.Activex_1.Width := Win_1.t_Width.Value + 70
Win_1.Activex_1.Height := Win_1.t_Height.Value + 50
oActiveX:Navigate( cLocalUrl , , , , cHeaders)
RETURN - Attachments
- GoogleChart.png (19.49 KiB) Viewed 7654 times
- mustafa
Hi friend minr
replace these lines
for this line of code
This is working well
View
viewtopic.php?f=24&t=5718&start=10
"API de Google crea gráficas3.zip"
replace these lines
* cHtmlString += "<html>" + CRLF
* cHtmlString += "<head>" + CRLF
cHtmlString += '<html> <head> <meta http-equiv="X-UA-Compatible" content="IE=edge" /> <meta charset="utf-8">' + CRLF + '<!--Load the AJAX API-->' + CRLF
View
Hello Mustafa,
Great!
It really works, thank you so much.
Great!
This version works with WebBrowse with a specified version of IE (tested on Win 10 64 bit). Just added this meta tag: <meta http-equiv="X-UA-Compatible" content="IE=edge" />
Greetings goes to: https://weblog.west-wind.com/posts/2011 ... ie-version
Works also with:
<meta http-equiv="X-UA-Compatible" content="IE=9" />
<meta http-equiv="X-UA-Compatible" content="IE=10" />
<meta http-equiv="X-UA-Compatible" content="IE=11" />
Function Main()
Local aRows[6], aCombo:={}
aRows [1] := {'Simpson',5}
aRows [2] := {'Mulder',30}
aRows [3] := {'Smart',50}
aRows [4] := {'Grillo',120}
aRows [5] := {'Kirk',90}
aRows [6] := {'Barriga',200}
PRIVATE aTypes [5]
aTypes [1] := {"Pie","PieChart"}
aTypes [2] := {"Pie 3D", "PieChart3D"}
aTypes [3] := {"Line", "LineChart"}
aTypes [4] := {"Bar", "BarChart"}
aTypes [5] := {"Column", "ColumnChart"}
AEVAL(aTypes, { |x| AADD( aCombo, x[1]) } )
@ 20,20 GRID Grid_1 ;
WIDTH 300 ;
HEIGHT 110 ;
HEADERS {'Label','Data'} ;
WIDTHS {100,100};
ITEMS aRows ;
VALUE {1,1} ;
EDIT ;
CELLNAVIGATION
@ 20, 390 COMBOBOX Combo_1 ;
WIDTH 135 ;
HEIGHT 94 ;
ITEMS aCombo ;
VALUE 1
WIDTH 50 ;
VALUE 480 ;
WIDTH 50 ;
VALUE 250 ;
@ 20,340 LABEL Label_1 ;
VALUE 'Type'
VALUE 'Width'
VALUE 'Height'
WIDTH 70 HEIGHT 28
ROW 150
COL 20
WIDTH 540
HEIGHT 200
END ACTIVEX
CENTER WINDOW Win_1
Local cChartType := aTypes [Win_1.Combo_1.Value] [2]
cHtmlString += '// Load the Visualization API and the corechart package.' + CRLF
cHtmlString += '// Set a callback to run when the Google Visualization API is loaded.' + CRLF
cHtmlString += 'google.charts.setOnLoadCallback(drawChart);' + CRLF
cHtmlString += '// Callback that creates and populates a data table, instantiates the pie chart, passes in the data and draws it.' + CRLF
cHtmlString += 'function drawChart() {' + CRLF
cHtmlString += '// Create the data table.' + CRLF
cHtmlString += 'var data = new google.visualization.DataTable();' + CRLF
cHtmlString += "data.addColumn('string', 'Topping');" + CRLF
cHtmlString += "data.addColumn('number', 'Slices');" + CRLF
cHtmlString += "data.addRows([" +CRLF
FOR i=1 TO Win_1.Grid_1.ItemCount
cHtmlString += "['" + hb_StrToUTF8( Alltrim(hb_valToStr(Win_1.Grid_1.CellEx( i , 1 ))) ) + "', " + Alltrim(hb_valToStr(Win_1.Grid_1.CellEx( i , 2 ))) + "]"
IF i < Win_1.Grid_1.ItemCount
cHtmlString += ","
cHtmlString += CRLF
NEXT i
cHtmlString += '// Set chart options' + CRLF
cHtmlString += "var options = {'title':'Sample Google Chart'," + CRLF
IF cChartType == 'PieChart3D'
cHtmlString += " 'is3D': true,"
cChartType := 'PieChart'
cHtmlString += " 'width':" + cChartWidth + "," + CRLF
cHtmlString += " 'height':" + cChartHeight + "};" + CRLF
cHtmlString += '// Instantiate and draw our chart, passing in some options.' + CRLF
cHtmlString += "var chart = new google.visualization." + cChartType + "(document.getElementById('chart_div'));" + CRLF
cHtmlString += '</script> </head>' + CRLF
cHtmlString += '<body>' + CRLF
cHtmlString += '<!--Div that will hold the pie chart-->' + CRLF
cHtmlString += '<div id="chart_div" style="width: ' + cChartWidth + 'px; height: ' + cChartHeight + 'px"></div>' + CRLF
cHtmlString += '</body> </html>'
RETURN The samples doesn't work now. Even though it worked. Do you have any idea?
Maybe try this. It's works for me.
Function Main()
PRIVATE aTypes [5]
WIDTH 300 ;
HEIGHT 110 ;
WIDTHS {100,100};
ITEMS aRows ;
VALUE {1,1} ;
EDIT ;
CELLNAVIGATION
WIDTH 135 ;
HEIGHT 94 ;
ITEMS aCombo ;
VALUE 1
WIDTH 50 ;
VALUE 480 ;
WIDTH 50 ;
VALUE 250 ;
VALUE 'Type'
VALUE 'Width'
VALUE 'Height'
WIDTH 70 HEIGHT 28
ROW 150
COL 20
WIDTH 540
HEIGHT 200
END ACTIVEX
//oActiveX:Silent := 1
CENTER WINDOW Win_1
Local cHtmlString := "<!-- saved from url=(0014)about:internet -->" + CRLF + "<!DOCTYPE html>" + CRLF //"<!-- saved from url=(0017)" + "http://localhost/" /* cLocalUrl */ + " -->" + CRLF
cHtmlString += '<html> <head> <meta http-equiv="X-UA-Compatible" content="IE=edge"/> <meta charset="utf-8">' + CRLF + '<!--Load the AJAX API-->' + CRLF
cHtmlString += ","
cHtmlString += CRLF
NEXT i
Thank you Edward.
It now works, which didn't work a few days ago. I tried on 3 different PC's with same result. Stange.
But now everything is ok.
Hi Gabor.
It seems to me that the problem was on Google side and associated with loader.js. There was a function in it that IE does not support - at least I received the results of script debugging.
Oh, ok that's clear.
Thank you.
Thank you.
bonsoir a toute l'equipe ,mustafa wrote: ↑Tue Nov 27, 2018 7:48 pm Hola amigos
Felicidades por la aplicación "edk"
He modificado el Sample de "edk" con la opción de Base de datos de "Tonton2"
Haber que os parece ?
*---------------------------------------------- Google -------------------------------------*
Hello friends
Congratulations on the "edk" application
I modified the "edk" Sample with the "Tonton2" database option
What do you think?
Mustafa![]()
sur un de mes PC(Windows 64) ,l'image du graphe n'apparait pas .c'est possible que ca vient de la configuration de Windows 64 comment
merci de votre aide
Y.TABET
Y.TABET
