Xbase++ to harbour / HMG Question
apais
Re: Xbase++ to harbour / HMG Question
Post by apais »
You a wrongly asuming Harbour uses only 1 core on Mt.
Angel Pais
apais wrote: Sun Sep 01, 2019 10:19 pm You a wrongly asuming Harbour uses only 1 core on Mt.
i recognize it when work with harbour / HMG and mt=yes that not only 1 Core is work like in Xbase++ :o
is mt=yes "safe" ?
under Xbase++ every Thread use same CPU Core and have a own Workspace. how about harbour / HMG :?:
apais
Post by apais »
Harbour manages it by iself. It also has it's own workspace.
I myself helped Przemek ( harbour core developper ) to do cross tests against xbase++ and it also went fine.
Angel Pais
apais
Post by apais »
The only thing harbour doesn't have are sync methods (mutually exclusive among instances).
Angel Pais
apais wrote: Tue Sep 03, 2019 2:04 pm Harbour manages it by iself. It also has it's own workspace.
Ah ... thx for Information
apais wrote:I myself helped Przemek ( harbour core developper ) to do cross tests against xbase++ and it also went fine.
so you are Xbase++ User ?
apais
Post by apais »
Yes I was.
Angel Pais
CLASS Object as Parameter :?:
i use own CLASS Object as Parameter but under harbour in Function CreatePGTable( oServer, ... ) VALTYPE() is NIL :o
Function Main(...)
Local oServer
   oServer := PGSql():new()
   IF oServer:connect( cConnect )
      ? "Main ", VALTYPE(oServer)
      ? "connect to "+cServer+" Port: "+cPort+" DB: "+cDataBase+" User "+cUser
FUNCTION CreatePGTable( oServer, ... )
   ? "CreatePGTable ", VALTYPE(oServer) // -> NIL ?
Result Output
Main O
connect to 'localhost' Port: 5432 DB: mdidemo User postgres
CreatePGTable U
now have use PRIVATE and not as Parameter and it work :!:
is this "by harbour Design" with CLASS Object :?: ... or is it my Xbase++ CLASS Style ... :roll:
#include "hbclass.ch"
CLASS PGSql
EXPORTED:
   VAR connID READONLY
   METHOD init
   METHOD connect
ENDCLASS
METHOD PGSql:init()
   ::connID := 0
   ::lError := .F.
   ::cError := ""
   ::Schema := "public"
return self
METHOD PGSql:connect( cConnString )
   local lOk
   ::connID := PQconnectdb(cConnString)
   if !( lOk := (PQstatus(::connID) == 0) )
      ::connID := 0
return lOk
i'm search for a Function like PeekStr() by ot4xb***
***LIB for Xbase++ by Pablo Botella Navarro https://www.xbwin.com/
Retrieve one or more substrings from the memory buffer pointed by <pMem> starting at position <nShift>.
Syntax:
PeekStr(<pMem>,[[@]<nShift>],<nSize>) -> <cStr>
PeekStr(<pMem>,[[@]<nShift>],-1) -> <cStr>
PeekStr(<pMem>,[[@]<nShift>],@<cStr>) -> <nSize>
PeekStr(<pMem>,[[@]<nShift>],[@]<aSizes>) -> <aStr>
Parameters:
<pMem>
Base pointer to the memory buffer.
<nShift>
Zero based starting position within <pMem>. If this parameter is passed by reference will be increased with the number of bytes retrieved, to reuse it in subsequent calls of Peek...() functions.
<nSize>
Number of bytes to retrieve. If <nSize> == -1 a NULL terminated string is assumed and PeekStr() will retrieve the bytes up to the first NULL character.
Note: Using the -1 param with non NULL terminated string can result in a internal exception.
<cStr>
Character variable to fill with Len(<cStr>) bytes if provided by reference.
<aSizes>
Array with the number of bytes to retrieve per element. If an element of <aSizes> contains a character value will be take the size of the provided string element.
AUGE_OHR wrote: Sun Sep 01, 2019 4:45 am what is used in harbour / HMG for
PeekWord(<pMem>,[[@]<nShift>]) -> <nWord>
PeekWord(<pMem>,[[@]<nShift>], <nItems>) -> <aWords>
Retrieve the value of one or more WORDs from the memory buffer pointed by <pMem> starting at the position <nShift>.
here Solution
HB_DLL6432.ZIP
(747 Bytes) Downloaded 228 times
it detect if DLL / EXE is for 32 Bit or 64 Bit
