Harbour MiniGUI Extended Edition build 20.06 is published
jorge_riv
DBs Used: DBF, MySQL,SQL SERVER, Oracle.
Re: Harbour MiniGUI Extended Edition build 20.06 is published
Post by jorge_riv »
Hola
Me encanta Harbor MiniGUI Extended, desarrollo sistemas y es muy versatil su programacion, y muy limpia, me gusta mucho. Gracias por sus aportes a esta gran comunidad.
Gracias Totales
gfilatov
Post by gfilatov »
jorge_riv wrote: Wed Jul 01, 2020 4:37 pm Hola
Gracias Totales
Hola Jorge,
Thanks a lot for your kind words :)
gfilatov
Post by gfilatov »
I've uploaded the updated setup of the build 20.06 for Borland C++ 5.8.2 at
Whatsnew:
* Fixed: Program crash at receiving of a Transparent property of RadioGroup
control. Note that the above property will switched for a RadioGroup
which was placed on a colored form only.
Bug was reported by Ivanil Marcelino <ivanil/at/linkbr.com.br>.
Contributed by Grigory Filatov <gfilatov@inbox.ru>
* Fixed: The Transparent property of a Frame control into a colored TAB
was not changed. It was a postponed modification.
Problem was reported by Ivanil Marcelino <ivanil/at/linkbr.com.br>.
(see demo.prg in folder \samples\Basic\TAB)
* Updated: HbSQLite3 library:
- update for using SQLITE3 version 3.33.0dev (from 3.32.3).
Thanks for your attention and support.
Best Regards,
[MiniGUI Team]
vlademiro
Post by vlademiro »
Long live to HMG Family :!: :)
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
¡Muchas gracias! Grigory
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi Grigory,
Please, can you tell me if HMG Extended it is UNICODE ready ?
Bets regards,
Salamandra- Brazil
gfilatov
Post by gfilatov »
salamandra wrote: Fri Jul 03, 2020 3:38 pm Hi Grigory,
Hi Salamandra,
No, it is not. :shock:
But it may be in the future :o
salamandra
Ok, thank youvery much Grigory.
Salamandra, Brazil
gfilatov
Post by gfilatov »
I've uploaded the updated setup of the build 20.06 (Update 2) for Borland C++ 5.8.2 at
Whatsnew:
* Updated: Harbour Compiler 3.2.0dev (SVN 2020-06-30 18:01).
(look at ReadMe.txt in folder \harbour)
* Updated: HMGS-IDE v.1.4.4.1 Project Manager and Two-Way Visual Form Designer.
Contributed by Grigory Filatov <gfilatov@inbox.ru>.
- update for using SQLITE3 latest version 3.33.0dev.
* New: 'Tetris game' sample.
Contributed by Claudio Soto at the official HMG forum.
(see in folder \samples\Applications\HMG_Tetris)
* New: 'Launching a second copy of the program with a pending' sample.
Contributed by Verchenko Andrey <verchenkoag/at/gmail.com>
(see demos in folder \samples\Advanced\PendingLaunch)
* Updated: MPM utility:
- location of the config file mpm.ini was changed in an user Appdata
folder to prevent of a requirement for administrator rights.
Suggested by Ronald de Bruijn.
(see in folder \Utils\MPM)
The upgrade to this build is recommended. :arrow:
Best Regards,
[MiniGUI Team]
salamandra
:) Thank you Grigory
Salamandra, Brazil
