path to iPhone DCIM Directory
- AUGE_OHR
Re: path to iPhone DCIM Directory
those virtual Folder are like ZIP Folder. you need to un-zip to compare what is "inside".
also, when using DragAcceptFiles() ( WS_EX_ACCEPTFILES ) , you are not able to DragDrop them from Explorer "Virtual Folder" into your HMG App.
i´m not sure why i get Size 0 and funny Date as Result. have to make more test.
Así es como viene de fábrica, tal vez haya opción para poder crear nuevas carpetas. (pienso yo)p.s. i just saw you have DCIM -> 2 x Sub-Folder ... "last" Code will only work with 1st Folder ...
ok have to made some Video to simulate it ... are there "more" Folder![]()
This is how it comes from the factory, maybe there is an option to create new folders. (I think)
One possibility is to create a database like Thumbs.db where the contents of the virtual folder of the mobile device are.AUGE_OHR wrote: ↑Thu Apr 02, 2020 3:58 pm hi,
This will be created in the destination folder, many applications like EveryThing, the famous search engine saves all the scanned files in the units that are connected to the PC, in this way it is efficient to search for a file in it.
selecting a checkbox it creates a new list of files that have not been copied to the new drive
I want to share my working sample based on Jimmy work and Claudio Soto tree sample.
It copies files from phone, but doesn't copy from network drives which are present in My Computer folder.
In CopyFiles function I left comment how to copy from local or network drives.
It should be the way to recognize if source is phone or local or network drive...
- CopyFromPhone.zip
- (5.86 KiB) Downloaded 145 times
Search Google
https://devblogs.microsoft.com/scriptin ... owershell/
https://docs.microsoft.com/en-us/window ... dfrom=MSDN
Hi Marek:
I am testing your development and I found a Tole error that I attached in the image, the second is that by default the checkbox (Recursive Sub-folder) would not have to be checked since it will search for all the content of the cell phone,
deactivating the option hidden files my cell phone 10 minutes ago that is looking for the 20 main folders that the cell phone has
Hi Jimmy : I compile the application, it recognizes my MotoG8plus, but when I do it again nothing happens, but if I click on motoG8plus and I click on "Searcho for device again, the error occurs
- AUGE_OHR
hi marek,
thx for your Sample, i will study it.
i try Sample but got no result in last Step ... nothing arrive
i just have a quick look into Source and might have found a Problem
you have 2 x Instance of oShell so i´m not sure it Object from 1 Instance will work in 2nd Instance
Question : can i hole Object in Array ... and how to "Destroy" it under HMG
about Network : you can reach it with Drive-Letter or UNC-Path while they have "real" Folder.
i´m not sure but IMHO "Shell.Application" is for Local Access
when "Stream" with CopyHere() over Network it is like "ZIP" and much slower than copy with SHfile Function like Explorer.
FUNCTION GetDeviceList()
oShell := CreateObject( "shell.application" )
function CopyFiles
oShell := CreateObject( "Shell.Application" )
- AUGE_OHR
not sure if your MotoG8plus use "virtual" Folder.danielmaximiliano wrote: ↑Fri Apr 03, 2020 1:56 pm I compile the application, it recognizes my MotoG8plus, but when I do it again nothing happens, but if I click on motoG8plus and I click on "Searcho for device again, the error occurs
my OLD Motorola "Razr" (not new "Razr" ... 1500 $
open Explorer "this PC". on left site you will find your Handy.
try to open it and look what is inside.
if it is a Folder remember that Name and change "into" Folder.
this can happen recursive until you see some Image file or else (Musik ?)
the code need the Object which Name you have remember to "stream" files from virtual Folder to your Destination.
i have start this Thread to get Image from my iPhone.
now we know that also other Smartphone can use this Way
when you can see a DCIM Folder than you have good chance to get Code working.
Marek have "visualize" it using a TREE, GREAT
i have to study his Code to learn how TREE Work under HMG as i have Problem with ACTION "on Node" ...
