FUNCTION OnMouseHover( hWnd, cFormName )
Re: FUNCTION OnMouseHover( hWnd, cFormName )
the Code "just" disable visual Style of Control with GetControlHandle(), not hole App or OS
so when have 10 Button you have to use it 10 x times while default all Controls, using Manifest, have visual Style.
under Xbase++ we have Property "UseVisualStyle" for each Control.
when set to .F. it just do Code which i have shown
Tienes algún ejemplo que nos pudieras compartir para poderlo probar ?
Do you have an example that you could share with us to try it out?
AUGE_OHR wrote: Tue Mar 31, 2020 4:41 am hi
andyglezl wrote: Mon Mar 30, 2020 8:58 pm In BUTTONS you cannot change the colors ...
this is true when have visual Style on (default)
you can disable Visual Style with
   hwnd:= GetControlHandle( "Button_1", cForm)
   SetWindowTheme( hwnd, 0, 0 )
now you can use Color for Button
I've tried, not working...
mol wrote: Tue Mar 31, 2020 6:22 am I've tried, not working...
it "just" disable visual Style so how do you "Paint" Color :?:
it work that Way with Label as it have BACKCOLOR but using "CREATE EVENT" seem me "limited"
we have
  ON LOSTFOCUS	-> WM_KILLFOCUS
  ON GOTFOCUS 	-> WM_SETFOCUS
but it is not the same like
  WM_MOUSELEAVE
  WM_MOUSEMOVE
  WM_MOUSEHOVER
those Windows Message are not used in h_windows.prg of HMG LIB.
when next Release of HMG include the Event and we must not work with a Workaround.
next Step would be to include WM_MEASUREITEM and WM_DRAWITEM with MEASUREITEM- and DRAWITEM-Structure and a "DrawItem" Codeblock Slot so User can "paint" what he want.
this is a Xbase++ Sample ( have no HMG Sample yet)
p.s. also WS_EX_ACCEPTFILES -> "DropZone" for each Control would be fine so we need no DragAcceptFiles()
gfilatov
Post by gfilatov »
AUGE_OHR wrote: Tue Mar 31, 2020 7:52 am ...
Please be so kind to review the following Minigui sample also:
The source code is attached here (along with the compiled application) :arrow:
HTH 8-)
ButtonHover.zip
(744.68 KiB) Downloaded 203 times
YES, MiniGUI use much more Events than HMG :!:
ONMOUSEHOVER
ONMOUSELEAVE
i´m still a harbour Newbie and have made my 1st Step with HMG.
now i can "walk" with HMG but to "run" with MiniGUI i still need time. ;)
AUGE_OHR wrote: Tue Mar 31, 2020 6:50 am hi,
I'm trying for one button in this way:
SetWindowTheme( OknoPartieProd.P_RozliczeniePartii.Handle, 0, 0 )
SetProperty("OknoPartieProd","P_RozliczeniePartii","FontColor", {255,0,0}) // colorize to red
mol wrote: Tue Mar 31, 2020 9:08 am SetProperty("OknoPartieProd","P_RozliczeniePartii","FontColor", {255,0,0}) // colorize to red
we talk about Button :?:
i don´t "see" in Help that Button have any Color Option so i ask for it.
HMG Syntax only work if API is behind.
under Xbase++ i use DLLCALL under harbour HB_FUNC()
this Sample i use to "paint" Darkmode (some Control have no Color Option)
CONTROLBACKGROUND( OknoPartieProd.P_RozliczeniePartii.Handle, {255,0,0} )
HB_FUNC(CONTROLBACKGROUND)
   HWND hWnd;
   HDC  hDC;
   RECT rect;
   HBRUSH hbrush;
   PAINTSTRUCT ps;
   hWnd   = (HWND)    hb_parnl (1);
   GetClientRect(hWnd, &rect);
   hbrush = CreateSolidBrush( (COLORREF) RGB(hb_parvni(2, 1),
                                             hb_parvni(2, 2),
                                             hb_parvni(2, 3)) );
   hDC = BeginPaint (hWnd, &ps);
   FillRect(hDC,&rect,(HBRUSH) hbrush );
   ReleaseDC(hWnd, hDC);
jairpinho
Post by jairpinho »
gfilatov wrote: Tue Mar 31, 2020 8:34 am
HTH 8-)
helo this is perfect!! but how to make it work in hmg without using buttonex? would have how to create a buttonex function in hmg to use
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
