Drop files from Explorer to HMG Control
i have made a Sample to Drop Files from Explorer to HMG Control.
HB_FUNC are from MiniGUI but work under HMG
i use CREATE EVENT PROCNAME to get WM_DROPFILES Message.
 CASE nMsg == WM_DROPFILES
Sample is just 1st Step and give you a Array with List of files which have "drop"
i have reduce Code to 32 Bit Version and to figure out how it "should work"
Dropfile01.zip
(1.26 MiB) Downloaded 824 times
fouednoomen
Re: Drop files from Explorer to HMG Control
Post by fouednoomen »
Many thanks
Hi Jimmy!
Maybe no one had the courage to tell you - this forum was created to share our solutions in source code.
We help one to another not by .exe files - by concrete knowledge.
mol wrote: Sun Mar 22, 2020 3:33 pm Maybe no one had the courage to tell you - this forum was created to share our solutions in source code.
i do have upload lot of "ready" Source Code but this was just the 1s Step of Sample.
so please give me time to finish it before i upload some Code.
to drag from Explorer to a Control need 3 Steps
1.) DragAcceptFiles function
https://docs.microsoft.com/en-us/window ... ceptfiles
2.) DragQueryFileA function
https://docs.microsoft.com/en-us/window ... queryfilea
3.) DragFinish function
https://docs.microsoft.com/en-us/window ... dragfinish
and when moving
4.) DragQueryPoint function
https://docs.microsoft.com/en-us/window ... querypoint
in Harbour MiniGUI 1.4 Extended (Build 47) added by Grigory Filatov
you will find Source in c:\MiniGUI\SOURCE\c_winapimisc.c
the Source i saw was c:\MiniGUI\SAMPLES\Applications\RunCmd\RunCmd.prg
how it work :
1.) you need a Handle for DragAcceptFiles
this Sample is for Form
   DragAcceptFiles( GetFormHandle('Form_1'), .T. )
to get Handle of Control is
   hWnd := GetControlHandle( cObj, cForm )
2.) you need to get into Windows Message loop
this normal is handle by HMG in c:\hmg.3.4.4\SOURCE\h_windows.prg.
i have used modify Code from USB_Detect Sample
CREATE EVENT PROCNAME Drop_Detect() HWND DropDemo.HANDLE STOREINDEX nIndex
MiniGUI Sample use
SET EVENTS FUNCTION TO MYEVENTS
3.) get WM_DROPFILES Message
FUNCTION Drop_Detect()
LOCAL nHWnd   := EventHWND()
LOCAL nMsg    := EventMSG()
LOCAL nWParam := EventWPARAM()
LOCAL nLParam := EventLPARAM()
      aFiles := DragQueryFileS( nWParam )
MiniGUI have
Function MyEvents ( hWnd, nMsg, wParam, lParam )
   case nMsg == WM_DROPFILES
      cCmd := DragQueryFile( wParam )
"My Problem"
when using CREATE EVENT PROCNAME Drop_Detect() Syntax it only work with Form.Handle NOT with Control.Handle
so i have to try MiniGUI Style with HMG ... this need some more time to figure out how it work.
when search for "Drop" i found these HMG Files
C:\hmg.3.4.4\SOURCE\c_browse.c
C:\hmg.3.4.4\SOURCE\c_dialogs.c
C:\hmg.3.4.4\SOURCE\c_InitCom.c
C:\hmg.3.4.4\SOURCE\c_listbox.c
C:\hmg.3.4.4\SOURCE\c_windows.c
C:\hmg.3.4.4\SOURCE\h_dialogs.prg
C:\hmg.3.4.4\SOURCE\h_init.prg
C:\hmg.3.4.4\SOURCE\h_listbox.prg
C:\hmg.3.4.4\SOURCE\h_windows.prg
there seems to be a DragDrop Sample for ListBox but it seems me "internal" not from "outside"
btw. it is NOT Ole-DragDrop :!:
DragQueryFile() will only give you a File-list with Name
Demo Code work but i have to find out how Demo Code work in hole HMG App or if Problem ...
so let me some Time to make it "safe" before i release Source Code
MiniGUI Sample use
i have try MiniGUI Syntax with HMG and got
C:\hmg.3.4.4\0\DragAccept\dropfile.PRG(84) Error E0030 Syntax error "syntax error at 'EVENTS'"
in c:\MiniGUI\Include\i_controlmisc.ch
#command SET EVENTS FUNCTION TO <fname> [ RESULT TO <lSuccess> ] ;
[ <lSuccess> := ] SetGlobalListener( <"fname"> )
so it is not "easy" to implement it to HMG ...
Hi Jimmy
You can see this from EDK...
https://www.hmgforum.com/viewtopic.php? ... fix#p57451
andyglezl wrote: Mon Mar 23, 2020 2:03 am You can see this from EDK...
thx for Tip, GREAT Sample
but it use DragDrop "inside" App while i try to get DragDrop from "outside".
most i use DragDrop for new Media-Files to drop them into Playlist.
it is a single Control in a Window so it is easy to find Control where i drop.
the Demo Sample just do that ...
! Note : this DragDrop Style only have a File-List of Media-Files NOT Media itself
but i think about next Step when have many Controls in a Window ...
under HMG i´m not able to restrict it on Control i want ( Xbase++ -> o:DropZone := .T. )
here Source Code i use
DROPFILE_Source.ZIP
(6.55 KiB) Downloaded 800 times
Que hace la diferencia / ventaja al utilizar Drag&Drop en vez de
GetFile ( { {"Archivos RTF", "*.rtf"} }, NIL, GetCurrentFolder() ) :?: :roll:
What makes the difference / advantage when using Drag & Drop instead of
GetFile ({{"RTF Files", "* .rtf"}}, NIL, GetCurrentFolder ()) :?: :roll:
chrisjx2002
Post by chrisjx2002 »
Great job!
fouednoomen
Great job!
