Image for Combobox from Resource
i try to use Resource file instead of "file-from-Disk"
it work when i use this Syntax
   AADD( acImage, "RES\IcoDriveUnknown16.ico" )
   AADD( acImage, "RES\IcoDrive16.ico" )
my *.RC look like this
A1MAIN ICON RES\NCC.ico
ICOUNKNOWN ICON RES\IcoDriveUnknown16.ICO
ICOFIXDRIVE ICON RES\IcoDrive16.ICO
so i try this
   AADD( acImage, "ICOUNKNOWN"   )
   AADD( acImage, "ICOFIXDRIVE"  )
or this
   AADD( acImage, LOADRESOURCE(GetInstance(),ICOUNKNOWN  ) )
   AADD( acImage, LOADRESOURCE(GetInstance(),ICOFIXDRIVE ) )
but both give "none" Result :(
who can tell me how to use Resource for Combobox :idea:
Re: Image for Combobox from Resource
i have try other Way : BMP instead of ICO
now i can use Resource "Name" and got my Image for Combobox :D
again i wonder ... i can use BMP or ICO but only BMP with Resource "Name" ... hm
Something must be wrong in your code.
I'm using icons from resource by name and it works.
mol wrote: Tue Mar 24, 2020 2:11 pm Something must be wrong in your code.
i also use Icon "by name" but ComboBox IMAGE does not accept ICOxxx.ICO only MYxxx.BMP (made from ICO)
hansmarc
Post by hansmarc »
i had the same problem in hmgextended.
Look here for more deails with tests we have done :
https://groups.google.com/forum/#!topic ... QV0dZYgL7I
It seemes to be a problem with the Borland 5.8 linker.
When you link with Winmg all is ok. See pictures.
The problem is still there. No time to investigate so i use bmp now.
Bye
Hans
