Harbour MiniGUI Extended Edition build 20.01 is published
gfilatov
Post by gfilatov »
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
It is a regularly scheduled maintenance release.
Here's a breakdown of some of the modifications in the build 20.01.
For the full list, please see the changelog.
* Added the new C-function C_SaveHIconToFile( cIconName, { hIcon1, ... } )
for saving a multipages icon to a disk file.
* Added the new useful C-functions
- ShowBalloonTip ( hWnd, cText [ , cTitle ] [ , nTypeIcon ] )
- HideBalloonTip ( hWnd )
for displaying a balloon tip associated with an edit control.
* Added the useful C-function aHWnds := EnumWindows()
for retrieving of an array of the external windows handles.
* Added the optional ON INIT <bBlock> clause to a TextBox control.
It was a postponed modification.
* Synchronized Extended HMG for compatibility with Official HMG:
- New: Added a readonly property 'ColumnCount' for Browse/Grid;
- New: Added a read/write property 'ColumnDisplayPosition' for
Browse and Grid controls.
Based upon a C-code contributed by Petr Chornyj which
fixes GPF in the official version (hb_xfree must be used
for hb_xgrab memory).
- New: Added the following properties for Forms:
- ThisWindow | <FormName>.AlphaBlendTransparent := nAlphaBlend
(0 to 255, Completely Transparent = 0, Opaque = 255);
- ThisWindow | <FormName>.BackColorTransparent := aRGBColor.
* Updated Harbour Compiler 3.2.0dev to a recent Git-version:
- New: Added the Harbour HbMxml contrib library is based upon
the Mini-XML library 2.7 by Michael R Sweet.
* Updated HMGS-IDE v.1.4.3.9, RDDLeto and Sqlite3 libraries.
* Added the new interesting samples and updated some Basic and
Advanced samples.
A setup of the build 20.01 for Borland C++ 5.8.2 is published at
the following URL:
There is also an extra Minigui Ex build for the Embarcadero C++ 10.1
Berlin compiler at
http://hmgextended.com/files/CONTRIB/hmg2001_bcc101.exe
Best Regards,
[MiniGUI Team]
Anand
Re: Harbour MiniGUI Extended Edition build 20.01 is published
Post by Anand »
Thank you Grigory and MiniGUI Team.
Anand
Anand
Thank you Grigory
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
Thanks Grigory!
thx for new Version.
p.s. have Problem to download with Firefox 72.02 and Avira Antivirus
Perfect download with firefox 72.0.2 64bit and Avast internet security.
Anand
Post by Anand »
Download no problem with latest FF but Win Defender prompted 'unrecognised app' on installer run.
As usual I selected 'more info' and 'run anyway'.
Anand
Anand
quartz565
Post by quartz565 »
Thank you Grigory !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Ismach
Post by Ismach »
Que grande este Grigory !!!!
Gracias Grigory Gracias MiniGUI Team
gfilatov
Post by gfilatov »
I've uploaded the updated setup of the build 20.01 for Borland C++ 5.8.2 at
Whatsnew:
* Fixed: Program crash at a creation of a ComboBox[Ex] with no character
'ItemSource' property and SQLMIX RDD usage.
Problem was reported by Jayadev <jayadev65/at/yahoo.com>.
Contributed by Grigory Filatov <gfilatov@inbox.ru>
(see demo in folder \samples\Advanced\OdbcDD)
* Updated: HbSQLite3 library:
- update for using SQLITE3 version 3.31.1 (from 3.31.0).
* New: 'Circle Magic' sample.
Based upon a contribution of S.Rathinagiri <srgiri@dataone.in>
Adapted for Minigui Extended by Grigory Filatov <gfilatov@inbox.ru>
(see in folder \samples\Advanced\Circle_Magic)
* Updated: 'MessageBox Button Hook Usage' sample:
Syntax: MsgBtnEx( cMsg, cTitle, nStyle [, cBtnCaption] ) --> nReturn
(see in folder \samples\Advanced\MsgBtnEx)
Please note that there are also the private MiniGUI builds for the following
free C-compilers:
- MinGW GNU C 9.2.1 (32-bit);
- MinGW GNU C 9.2.0 (64-bit);
- MS Visual C++ 2019 (32-bit);
- MS Visual C++ 2019 (64-bit).
Thanks for your attention.
Best Regards,
[MiniGUI Team]
