prg code function documentor in HMG
RPC
Post by RPC »
Hi AUGE_OHR
Your program works like a charm.
It does show click icon both in explorer and task bar :D
i have to run CLICK Source under MiniGUI.
it need some modification e.g. how to change Button ACTION after create.
_HMG_SYSDATA[ 6 ] [ nIndex ] := { || DoEsc() }
_HMG_SYSDATA[ 6 ] [ nIndex ] := { || DoExit() }
_HMG_SYSDATA[ 6 ] [ nIndex ] := { || StartClick() }
Question : is there a IFDEF Constante that i can use for HMG / MiniGUI to use different Code / Syntax :?:
never less i was able to Start and with CLICK.
it work and it is MUCH faster than HMG Version, 24 Sec. vs 40 Sec. :o
as we all know it have only to do with Grafik "OutPut" and MiniGUI seem to use GDIplus instead of GDI32
but i have a Problem when press "X" to close Apps ... it crash (when .Release :?: )
Called from GDIPLUSSHUTDOWN(0)
Called from RELEASEALLWINDOWS(2285) in h_windows.prg
Called from __QUIT(43) in C:\MINIGUI\SAMPLES\0\CLICK\XBASE.Prg
Called from RELEASEALLWINDOWS(2296) in h_windows.prg
Called from _RELEASEWINDOW(2334) in h_windows.prg
Called from DOMETHOD(5366) in h_controlmisc.prg
Called from (b)MAIN(555) in C:\MINIGUI\SAMPLES\0\CLICK\CLICK2.Prg
Called from _DOCONTROLEVENTPROCEDURE(1858) in h_windows.prg
Called from EVENTS(698) in h_events.prg
Called from DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(1493) in h_windows.prg
Called from MAIN(558) in C:\MINIGUI\SAMPLES\0\CLICK\CLICK2.Prg
555   ON KEY ESCAPE OF ClickForm ACTION ClickForm.Release
556   CENTER WINDOW ClickForm
557
558   Activate Window ClickForm               <- Crash here when close App
559
560 RETURN
please have a look at it when release Source
btw. have to rename CLICK.PRG into CLICK2.PRG when using MinGUI IDE while it create a *.INI from "Main" PRG :roll:
we NEED CLICK.INI but MiniGUI IDE "OVERRIDE" CLICK.INI ... after rename now MiniGUI IDE use CLICK2.INI
there is a BUG in v0.26 when have something like this
Start_xxx()
i had to check if "PRINTDOC" or "PRINTPAGE" is in same line as "START"
have fix it for Release
have made many Test with different Source and it seem to work fine :D
so i will freese this Version for Release.
add :
IF aFileNames[ x, F_NAME ] = "HB_FUNC.PRG"
   // use this Filename for C-Code
   AADD( aFileList, aFileNames[ x, F_NAME ] )
i recommend to use HB_FUNC.PRG for all C-Code and exclude it from Filelist so CLICK will not touch that Code.
so here is the Source Code for HMG CLICK v2.05.29
hb_CLICK_20529.ZIP
(67.37 KiB) Downloaded 466 times
i'm doing my best but i can't guarantee that produce Code is free of Error :!:
even when CLICK does not find a Error and it compile / link it is still possible that "something" have change.
so make BACKUP from *.PRG before you override it with Code produced by CLICK :!:
about ";"
it seem that "Keyword" like "End" or "Return" can be "lost" when have ";" before.
so write "End" or "Return" in next line so CLICK will be not confuse to "forget" it :o
it work without "+" when using
.AND. ;
.OR. ;
it work with long String and "+" in next line but more safe (for CLICK) when using "+ ;" at End of line
BEGIN xxx
i have only test BEGIN INI
hope other are used in *.RMG which CLICK do not touch
small BUG with STATUSITEM with are not Intend
      DEFINE STATUSBAR ..
   STATUSITEM ..
for MiniGUI User :
you have to delete some line where MiniGUI IDE found a Error.
also all HMG_* are not working when have "MINIGUI.CH" instead of "HMG.CH"
i do change Button ACTION after create.
if someone found a MiniGUI Solution please also post it here in "this" Forum.
! Note : MiniGUI IDE create a Name.INI where Name = 1st PRG -> CLICK.INI ... :roll:
so for MiniGUI so have to rename CLICK.PRG into CLICK2.PRG :!:
feel free to modify Source.
if you someone find a nice Solution please post it here in "this" Forum, thx
quartz565
Post by quartz565 »
Thank you again Jimmy!
I'll try the new version
Nikos
Best Regards,
Nikos.
os: Windows Server 2019 - 64
RPC
Post by RPC »
Hi AUGE_OHR
Thanks for v 2.05.29 and source code.
When I try to compile it I get error msg as per follo SS
Click20529 error msg.png (1.05 MiB) Viewed 43801 times
I am unable to tell what is the exact error.
Can you please look into it
Thanks
i can't see youe full Modul List but i guess CLICK.PRG is NOT declare as "Main"
in IDE "somewhere" i saw a Option ...
other Way was to delete CLICK.PRG from Modul List and Import it again.
my Way is to click on *.HBP.
1st time Windows will ask how to open file and i point to
c:\hmg.3.4.4\IDE\IDE.exe
and let Windows "remember"
next time when click on *.HBP it will open Project in IDE and i just press F5
RPC
Post by RPC »
Hi AUGE_OHR
Ok. Got it.
There is no \res sub dir and no clickBW32.ico file in it.
I put a dummy icon after creating \res directory and now it compiles !
Please upload clickBW32.ico file so that I can incorporate in the compiled program.
Secondly I am curious why the error mentions it as HMG 3.4.3 stable(32 bit) instead of HMG 3.4.4 which I am using to compile ?
RPC wrote: Tue Jan 21, 2020 10:56 am Hi AUGE_OHR
my Name is Jimmy
RPC wrote: Tue Jan 21, 2020 10:56 am Ok. Got it.
uuups ... forgot \RES
so delete Icon and use your own Icon but it must called
MYMAIN ICON YourResource.ICO
RPC wrote: Tue Jan 21, 2020 10:56 am Secondly I am curious why the error mentions it as HMG 3.4.3 stable(32 bit) instead of HMG 3.4.4 which I am using to compile ?
no Idea
