prg code function documentor in HMG
Tiger
Post by Tiger »
Hi Jimmy,
Thanks for your effort to make the Click works with HMG. I am wonder if it can be enhanced to add the comment to those statements ( while ,if ...)
While aaa
  If bbb
    While ccc
    Enddo // While ccc
    If ddd
    Endif // If ddd
  Endif // If bbb
Enddo // While aaa
Tiger wrote: Sat Jan 04, 2020 2:45 pm I am wonder if it can be enhanced to add the comment to those statements ( while ,if ...)
nice Idea :idea: ... but that mean that CLICK "change Code" ... hm
now CLICK just write Header which does not touch Code so it is safe.
here now lastes Version 0.18
hb_click017.zip
(60.43 KiB) Downloaded 484 times
fixed : LFN (instead of 8.3) Support
change : now include path for DBF
add : Checkbox "Verbose" which can be used "on-fly" to speed up
if "underflow" or "overflow" now display YesNo Box.
it is recommend to BREAK loop with "Yes" ... but sometimes it still fail
i do my best but i can't "Guarantee" that it produce right Code with "your" Source :!:
so i include Source and everbody can look into it how it work.
please send me a (small) Sample if you found a Problem ( HMG Snytax still not include in this Version), thx
as i found out not all "underflow" or "overflow" are "urgent" to BREAK ...
i found out that
or
END TOOLBAR
are those Msg which i get when using HMG Syntax with CLICK
i will try to include those Syntax into CLICK.
i guess there are "more" with "END ..." so please help me and post other "END ..." when you have, thx
quartz565
Post by quartz565 »
hi Jimmy thank you for your fantastic work!
I'm sending you a file that causes a problem with "END BUTTON" on line 38
Mainok.zip
(1.81 KiB) Downloaded 456 times
Best Regards,
Nikos.
os: Windows Server 2019 - 64
quartz565 wrote: Fri Jan 10, 2020 11:31 am I'm sending you a file that causes a problem with "END BUTTON" on line 38
thx for Sample.
i have implement DEFINE with
 lAction := cLookFor $ 'WINDOW|TOOLBAR|GRID|BUTTON|MAINMENU|MAIN MENU|POPUP|TEXTBOX|RICHEDITBOX|STATUSBAR|CONTROL|NOTIFY'
i need "more" if "your" Source still fail with HMG Version of CLICK
it will FAIL on HB_FUNC Code ... :o
those Code will give Error when compile but i don't know why :?:
here you can see what Windiff.EXE give me.
in produced Code that "C" Part look Different while it is (wrong) Indent. so it look different to WinDiff.EXE ... hm ...
i think it need a HEX Editor to see what is going on ... :roll:
p.s. the HB_FUNC is very nice :!:
can you change Background Color of hdItem using FillRect( hDC, rect, ::BrushHiBack ) :?:
here CLICK.EXE, please test it and tell me "more" DEFINE to implement.
hb_CLICK_EXE20.zip
(1.33 MiB) Downloaded 521 times
p.s. do NOT skip when get a HMG Syntax Error. it will not display when i got "full" HMG Syntax
quartz565
Post by quartz565 »
Thank you very much. I'll try the new program and let you know.
Nikos
Best Regards,
Nikos.
RPC
Post by RPC »
edk wrote: Tue Dec 10, 2019 11:12 am Hi.
I changed the control type from EDITBOX to RICHEDITBOX and used the Addtext property.
Every 250 lines displayed, release memory and do event queue.
click_prg.7z
Check it now.
Hi edk
From where can I get DLL.CH used in your click program. Unable to compile without it.
thanks
RPC wrote: Sat Jan 11, 2020 9:01 pm From where can I get DLL.CH used in your click program. Unable to compile without it.
you fine it under c:\harbour\include\dll.ch but that CLICK is a old Version and obsolet.
try new Version with HMG include, Source will available soon (have to clean up Code)
RPC
Post by RPC »
AUGE_OHR wrote: Sat Jan 11, 2020 9:26 pm
Ok. Thanks AUGE_OHR
I have tried hb_click_exex20 and it is working well.
Many thanks for sharing.
