ChildList() of FORM ?
a FORM have OnGotFocus() which i want to re-direct to set focus on 1st Child, how with HMG :?:
under Xbase++ i use
   aChild := oDialog:DrawingArea:ChildList()
   SetAppFocus( aChild[1] )
SALINETAS24
Re: ChildList() of FORM ?
Post by SALINETAS24 »
Hola, igual es esto lo que buscas
<WindowName>.FocusedControl
Sl2
SALINETAS24 wrote: Tue Dec 17, 2019 7:20 am Hola, igual es esto lo que buscas
thx for Tip
FocusedControl Property
Retrieves the focused control name of a Window
my Problem that i want to SET focus to a Child Control ... i exist
   nPosi := ASCAN(aChild, {|e| e = MySeekControl } )
   IF nPosi > 0
      SetAppFocus( aChild[nPosi] )
most it is the 1St Child but i need a "List" of all Child to work with
SALINETAS24
Hola.., siento no entender lo que buscas.
Creo entender que necesitas la lista de controles o de Child que tienes.., quizas esto te pueda poner sobre la pista...
viewtopic.php?f=24&t=5805&p=56314&hilit ... LES#p56314
Un saludo,
Maybe...
In each DEFINE...
	AADD( aChildForms, { nForm, cChildForm, cPanelForm, .T. } )
Validate...
	FOR i = 1 TO HMG_LEN( aChildForms )
		IF hb_AScan( aChildForms[i] , cNombChild2Focus, .T. ) > 0
			DoMethod( cNombChild2Focus, "SetFocus")
			EXIT
	NEXT i
YES :D
i found this
Function GetControls( cForm )
Local hWnd := GetFormHandle( cForm )
Local aControls := {}		//List of controls {ControlType, ControlName}
AEVAL( _HMG_SYSDATA[ 4 ], { | hCtrWnd, nPos | IF( hCtrWnd == hWnd, AADD( aControls , { _HMG_SYSDATA[ 1, nPos ], _HMG_SYSDATA[ 2, nPos ] }), Nil ) } )
MsgDebug( 'List of controls', aControls)
Return aControls
now i have to find out how to use it ...
thx all for help
andyglezl wrote: Wed Dec 18, 2019 1:45 am
In each DEFINE...
thx for help.
Question : is HMG_LEN() different to LEN() function :?:
HMG_LEN() = Unicode
LEN() = ANSI
edk
Post by edk »
andyglezl wrote: Wed Dec 18, 2019 1:45 am Maybe...
In each DEFINE...
Validate...
			EXIT
	NEXT i
@andyglezl It will not be correct, because you would have to handle the window closing event and remove it from the aChildForms array.
If you want to check for instances of a given window type, you can use this function:
Function GetWindowsByType( cType )
Local aForms := {}		//List of forms { WindowName, WindowType, WindowIsDeleted, WindowIsActive, WindowHandle, WindowParentHandle }
Default cType :=''
	empty - all types
	A - main
	S - standard
	C - child
	M - modal
	P - panel
	X - splitchild
IF Upper(Left(cType,1))$"ASCMPX" .OR. EMPTY( cType )
	AEVAL( _HMG_SYSDATA[ 69 ], { | cWndType, nPos | IF( Empty( cType ) .OR. cWndType==Upper(Left (cType, 1)) , ;
		AADD( aForms , ;
			{ _HMG_SYSDATA[ 66, nPos ], ;	//_HMG_aFormName
			  _HMG_SYSDATA[ 69, nPos ], ;	//_HMG_aFormType
			  _HMG_SYSDATA[ 65, nPos ], ;	//_HMG_aFormDeleted
			  _HMG_SYSDATA[ 68, nPos ], ;	//_HMG_aFormActive
			  _HMG_SYSDATA[ 67, nPos ], ;	//_HMG_aFormHandle
			  _HMG_SYSDATA[ 70, nPos ]}),;	//_HMG_aFormParentHandle
		Nil ) } )
	MsgStop('Function GetWindowsByType(): invalid window type "' + cType + '"' )
Return aForms
Sample:
GetWindowsByType.7z
(1.49 KiB) Downloaded 190 times
Edward.
Edward.
Hola EDK
(Lo siento, me enfoque en lo que yo estaba haciendo...)
Tienes razón, aunque si estoy controlando el cierre de las ventanas.
En mi caso, solo guardo algunos datos de las ventanas CHILD (no todas) que voy creando
en esa opción del programa para poderlos utilizar mas delante hasta el cierre de la misma.
(de hecho, lo estoy utilizando con tu ejemplo) https://www.hmgforum.com/viewtopic.php? ... 9&start=10
Hi EDK
(I'm sorry, I focus on what I was doing ...)
You are right, although I am controlling the closing of the windows.
In my case, only save some data from the CHILD windows (not all) that I am creating
in that option of the program to be able to use them more ahead until the closing of the same.
(in fact, I'm using it with your example) https://www.hmgforum.com/viewtopic.php? ... 9&start=10
Gracias por esta nueva herramienta que nos compartes !
Thank you for this new tool that you share with us!
