xlmwrtiter for create standalone XLSX files without Excel/Openoffice installed
Hello.
I would appreciate some help to use xmlwriter in HMG. The default demo included in HMG 3.4.4 cannot be compiled in my project... has some people a better .hbp project to see how ? Thanks.
- AUGE_OHR
Re: xlmwrtiter for create standalone XLSX files without Excel/Openoffice installed
can you please tell me which Sample you try ... i can't find "xlmwriter"
I think juanato means this library,
http://libxlsxwriter.github.io/
whose sample is in MiniGUI Extended
c:\MiniGUI\SAMPLES\Advanced\HbXlsxWriter\
Anand
Anand
Also visit for XLSXClass.prg
https://groups.google.com/forum/#!searc ... uaB7k2AwAJ
- AUGE_OHR
... seems i need to use Extendet Version to reach next level
ok, thxAlso visit for XLSXClass.prg
Here is the xlsxwriter wrapper for Harbour
https://github.com/riztan/hbxlsxwriter
Javier
Javier
About year ago I had a problem with this solution - excel files created with this library had caused excel crashes - I'm wondering if it works ok now, but, I don't have any excel installed in my machines.
Someone can test it?
Hi Marek,
Which of them?, there are two different libs,
hbxlsxml are wrappers of Fausto at https://github.com/FTrautwein/hbxlsxml
hbxlsxwriter are wrappers of Riztan at https://github.com/riztan/hbxlsxwriter
I can personally confirm that hbxlsxml works correctly (create xml files
fully compatible with Excel), I have been deeply this lib making reports.
On the other hand, I have not tested much hbxlsxwriter, but I also confirm that it works, in fact it creates real Excel xlsx files and the file sizes are much smaller compared to those created by hbxlsxml.
Javier
I use Fausto's library in Alaska xbase++ without problems since a couple years on excel, libeoffice, wps office
Not tested on HMG though.
Angel Pais
Hello everyone
Does anyone use XLSX Class - Harbor XLSX library by Srdjan Dragojlovic?
https://groups.google.com/g/harbour-users/c/OtxRtLzf_1E
I would need help setting the column width.
By default, all columns have the same width. Is it possible to change it?
Thanks for help.
Georg
Thanks for help.
Georg
