Attached a excel file that listed those keyword which I got from hmg\doc and two xml files from the notepad++ ...
prg code function documentor in HMG
- hmg_keyword.rar
- (63.53 KiB) Downloaded 415 times
- AUGE_OHR
thx for Keyword File that we can use.
Question : did got Click_3.01_HMG.rar running
i got it running until BO_INIT which have a lot of Parameter which crash
when look into OBUFWRIT.PRG you will find FUNCTION BO_INIT() with 4 Parameter
you also can see that Author have deactivate this line
i "think" my harbour FT_ORIGIN() have also Problem with Directory like c:\hmg.3.4.4\ with those "."
under Xbase++ this Code is working where CLICK.EXE / CLICK.INI is "in" Directory of PRG to analyze
local cFullPath := if( file( 'CLICK.INI' ), 'CLICK', RootName( ft_origin() ) ) + '.ini'i "think" my harbour FT_ORIGIN() have also Problem with Directory like c:\hmg.3.4.4\ with those "."
FUNCTION FT_ORIGIN()
return curdrive() + ":\" + curdir() + "\CLICK.EXE"have fun
Sorry, I try it long time ago but it just fail .... so I just use the indent program to format the code ...
- AUGE_OHR
got my Xbase++ CLICK Version running under harbour
here is the hole Source BUT ... it is extreme SLOW even used all 4 Core of my i5
good News : all seems to work correct "in 1st Generation"
what does it mean
when start with F5 in IDE it will start App.
1st it create \clickout Directory and than begin with work.
new Source in \clickout seems fine and i compile it with Xbase++
now i start that Xbase++ App and it give me Warnings about "this" Code ... hm
looking into \clickout\clickout (2nd Generation) it have begin to work wrong to "intend".
it is going to right but does not "come back" to left.
but you can compile 2nd Generation Code again it it still work ... only looking bad
i think i got a old Cl*pper Soure somewhere which was to "save Space" which align all Code to left side.
than i can run it with CLICK again ...
but it is so SLOW so what do i miss
it it (default) MT
what does it mean
- AUGE_OHR
do NOT click with Mouse into "CLICK" while it is a Console App and it might enable copy/paste
when switch to other App "CLICK" might "wait of End od mark" and it seem not to work any more
so press ENTER and see if work go on.
- AUGE_OHR
found out "2nd Generation" Problem ... it is "missing" CLICK.INI so it use "default" Value
as i say i recommend to use S87 Style so "indent" work correct.
my Version seem not to create CLICK.INI ... hm
so here is a CLICK.INI but it does not change SPEED Problem ... my Xbase++ Version use less 5 Seconds ...
>>>>>> Click! Run Start: 20191207 10:34:05
>>>>>> Click! Run End: 20191207 10:34:09
Anyway: it works well!
Thx ! Serge
Thx ! Serge
- AUGE_OHR
but why is it so SLOW
it is not not only a "bit slower" it is Factor 1000 ... instead of 4 Seconds it need 4000 Seconds.
but it is "only" Cl*pper Code no GUI so i must do something total wrong ... harbour can't be so slow
please help me to make it faster. which Compiler Option are used for "Cl*pper"
p.s. how to disable MT
- AUGE_OHR
i have use *.HBC with
and disable
so please tell me what is the Difference
why will it be so slow when include
p.s. when not "see" App you can't terminate it and it is still in Taskmanager.
GUI=NO
MT=NOit did not show any Windows ... BUT* REQUEST HB_GT_WIN_DEFAULT // Console
NOW it have the Speed using 2 Seconds for same Work>>>>>> Click! Run Start: 20191207 22:32:16
>>>>>> Click! Run End: 20191207 22:32:18
REQUEST HB_GT_WIN_DEFAULT have fun
- AUGE_OHR
hm ...
i just saw that my Xbase++ Version show "more" than harbour Version the lower Part is not visible under harbour ... can this made it so slow
