Everybody, hello,
more, english, know, . I apologize . Everything, ago,
Sqllite, very_beautifull, and fast, one, Veritabani Systems
Sqllite, command, more, simplify,
Like Minisql .
For instance ;
* SELECT
#command SELECT <arg1> FROM <*arg2*> ;
* DELETE
#command DELETE FROM <arg1> WHERE <*arg2*> ;
* INSERT
#command INSERT INTO <arg1> SET <*arg2*> ;
* UPDATE
#command UPDATE <arg1> SET <*arg2*> ;
#command LOCK TABLES <*arg*> ;
* UNLOCK
#command UNLOCK TABLES ;
#command CREATE DATABASE <arg1> ;
#command CREATE TABLE <tname> FIELDS <*afi*> OF <db> ;
#command DROP TABLE <*arg1*> OF <cdata> ;
Answer for thanks.
*Sqllite, subject,
Re: *Sqllite, subject,
Hello Kesisim,
Are you talking about embedded sql commands? Then following link may be helpful viewtopic.php?f=15&t=853&start=14
(BTW, you may write in language other than English also, if you like
With best regards.
With best regards.
