CreateEllipticRgn / CreateRectRgn
Re: CreateEllipticRgn / CreateRectRgn
AUGE_OHR wrote: Tue Nov 19, 2019 3:59 am hi,
cIdx := STRZERO(nIDig,2)
cForm := "Form_" + cIdx // Form_01
cImage := "Image_"+cIdx // Image_01
SetProperty( "Form_" + cIdx, "Image_" + cIdx, 'Picture', a_Digit[nNr+1] )
but it does not change PICTURE :(
who can help me please.
Try this
SetProperty( cForm, cImage, 'Picture', a_Digit[nNr+1] )
thx for Hint, i have now use other Way.
i do not "attach" Image to Form, i just "paint" it into Form :D
i found Solution in c:\hmg.3.4.4\SAMPLES\Events\ON_PAINT\WALLPAPER\demo.prg
there is a HB_FUNC(BMP_PAINT) which use StretchBlt()
but Parameter are "fix" on full Image Size
   0, 0, bm.bmWidth, bm.bmHeight
these lines i enhance for new Parameter
   if (nMode == BMP_COPY_SPLIT)
      rect.bottom = hb_parnl (6);
      rect.right  = hb_parnl (7);
      aSource.top    = hb_parnl (8);
      aSource.left   = hb_parnl (9);
      aSource.bottom = hb_parnl (10);
      aSource.right  = hb_parnl (11);
      StretchBlt(hDC, rect.left, rect.top, rect.right, rect.bottom, memDC, aSource.left, aSource.top, aSource.right, aSource.bottom, SRCCOPY);
so my Code look now
   hBitmap := BMP_LOAD_FILE("COLORS.BMP")
   wide    := BMP_GET_INFO (hBitmap, BMP_INFO_WIDTH)
   height  := BMP_GET_INFO (hBitmap, BMP_INFO_HEIGHT)
   FOR i = 1 TO iMax
      cForm  := "Form_"+strzero(i, 2)
      cOnPaintProc := "Paint_Background_Window( '" + cForm           + ;
                                                "', '" + str(i)      + ;
                                                "', '" + str(wide)   + ;
                                                "', '" + str(height) + ;
                                                "', '" + str(hBitmap)+ "'  )"
      DEFINE WINDOW &cForm ;
         ON PAINT &cOnPaintProc ;
and painting
FUNCTION Paint_Background_Window(cForm,cID,cwide,cheight,cBitmap)
LOCAL hWnd
LOCAL hBitmap
LOCAL nMode  := BMP_COPY_SPLIT
LOCAL Row    := 0
LOCAL Col    := 0
Local wide   := 32
Local height := 35
Local nPart  := 0
   nNo       := VAL(cID    )
   wide      := VAL(cwide  )
   height    := VAL(cheight)
   hBitmap   := VAL(cBitmap)
   nPart     := ROUND(wide/8,0)-1
   hWnd      := GetFormHandle(cForm)
   Row       := GetProperty(cForm ,"Height")
   Col       := GetProperty(cForm ,"Width" )
   BMP_PAINT (hWnd, hBitmap, nMode,0,0,Row,Col,;
                                   0,nPart*(nNo-1),height,nPart)
each Form now get "Part" of Bitmap paint into its Form so i do not need to "split" Bitmap any more
here new Version
HMG_UHR02.ZIP
(26.26 KiB) Downloaded 218 times
p.s. to close it look at TrayIcon lower right
There are times when there are no answers because nobody had the need for some features you are using.
Master Claudio Soto is also not here since Bostaurus one of the great features of HMG is not participating lately.
AUGE_OHR wrote: Tue Nov 26, 2019 7:43 am
here new Version
HMG_UHR02.ZIP
Thank you, surely our friend and collaborator in Grigory Filatov will ask you for permission to add it to HMG Extended
AUGE_OHR wrote: Tue Nov 26, 2019 7:43 am here new Version
HMG_UHR02.ZIP
Thank you for sharing, nice creation
Jimmy,
Where can I find DLL.ch?
serge_girard wrote: Tue Nov 26, 2019 12:18 pm Jimmy,
Visit
https://github.com/vszakats/hb/blob/mas ... xpp/dll.ch
danielmaximiliano wrote: Tue Nov 26, 2019 10:04 am There are times when there are no answers because nobody had the need for some features you are using.
it is true that my Question most are API Question but it is not the API itself it is how it work with HMG
even if i'm not a "C"-Guru i have less Problem to write a HB_FUNC than to understand how HMG / FMG work.
for my Demo i have use 8 x Form and ON PAINT. now i change to Label and wonder that it does not have ON PAINT :o
but every Control have WM_PAINT ... why under HMG only Form have that Event :?:
other are Syntax with "."
   BMP_BAND1.Label_1.value := "ABC"
list line work but
   hWnd  := GETHWNDFROM(BMP_BAND1.Label_1)
fail with Syntax Error :( ... so how is the right Syntax to Get Handle of Control (not a API Question) :idea:
i guess i have to use a Macro for those Situation and that is what i want to find out before try a Big Application.
AUGE_OHR wrote: Wed Nov 27, 2019 4:53 am
list line work but
Demo code for List of all defined controls in a form with Control handle
# include "minigui.ch"
function main
define window sample at 0,0 width 800 height 600 title "List of all defined controls in a form" main
   define label label1
      row 10
      col 10
      width 100
      value "Label 1"
   end  label
   define textbox text1
      row 10
      col 110
      width 120
      value "Sample Text Box 1"
   end textbox
   define label label2
      row 40
      col 10
      width 100
      value "Label 2"
   end  label
   define textbox text2
      row 40
      col 110
      width 120
      value "Sample Text Box 2"
   end textbox
   define label label3
      row 70
      col 10
      width 100
      value "Label 3"
   end  label
   define textbox text3
      row 70
      col 110
      width 120
      value "Sample Text Box 3"
   end textbox
   	@ 10,340 COMBOBOX Combo_1 ;
			ITEMS { 'A' , 'B' , 'C' } ;
			VALUE 1 ;
			DISPLAYEDIT ;
			ON DISPLAYCHANGE PlayBeep()
   DEFINE HYPERLINK H1
			ROW		40
			COL		340
			VALUE		'http://www.hmgforum.com/'
			FONTNAME	'Arial'
			FONTSIZE	9
			AUTOSIZE	.T.
			ADDRESS		'http://www.hmgforum.com/'
			HANDCURSOR	.T.
		END HYPERLINK
		@ 80,340 DATEPICKER Date_1 ;
		VALUE CTOD('  / /  ') ;
		TOOLTIP 'DatePicker Control'
   DEFINE STATUSBAR
			STATUSITEM "Item 1" 	ACTION MsgInfo('Click! 1') RAISED
			STATUSITEM "Item 2" 	WIDTH 100 ACTION MsgInfo('Click! 2')
		END STATUSBAR
   define button action1
      row 100
      col 10
      width 100
      caption "Press here"
      action dolisting()
   end button
   define listbox list1
      row 130
      col 10
      width 300
      height 200
   end listbox
end window
sample.center
sample.activate
return nil
function dolisting
local aControls := GetWindowControls("sample")
local i := 0
sample.list1.deleteallitems()
for i := 1 to len(aControls)
   sample.list1.additem(aControls[i])
next i
if sample.list1.itemcount > 0
   sample.list1.value := 1
return nil
//GETCONTROLTYPE( cFoco, cForm)
STATIC FUNCTION GetWindowControls(cForm)
local aControlList := {}, xx, yy
local i := 0
  aadd(aControlList,"MainFormName :" + hb_valtostr(GetMainFormName()))
  aadd(aControlList,"MainFormHandle :" + hb_valtostr(GetMainFormHandle()))
  aadd(aControlList,"Lis of Defined Control ")
  aadd(aControlList, "Cont.Type    Cont.Handle    Cont.Name" )
  aadd(aControlList, "----------------------------------------------")
for i := 1 to len(_HMG_SYSDATA[4])
   if _HMG_SYSDATA[4,i] == GetFormHandle(cForm)
      if len(alltrim(_HMG_SYSDATA [2] [i] )) > 0
      xx:= hb_Valtostr(GetControlHandle (_HMG_SYSDATA [2] [i],cForm))
      yy := GETCONTROLTYPE( _HMG_SYSDATA [2] [i], cForm)
         aadd(aControlList, yy +"  "+ xx + "  "+ HB_valtostr(_HMG_SYSDATA [2] [i] ))
next i
return (aControlList)
bpd2000 wrote: Wed Nov 27, 2019 10:05 am Demo code for List of all defined controls in a form with Control handle
THX for your Code, that look ggod :idea:
i saw _HMG_SYSDATA and found in c:\hmg.3.4.4\SOURCE\c_label.c / \hmg.3.4.4\SOURCE\h_label.prg
Controlhandle := InitLabel ( ParentForm, Caption, 0, x, y, w, h, '', 0, Nil , border , clientedge , HSCROLL , VSCROLL , TRANSPARENT , invisible , rightalign , centeralign, EndEllipses, NoPrefix )
later i will be store to
   _HMG_SYSDATA [1][k] := "LABEL"
   _HMG_SYSDATA [2][k] := ControlName
   _HMG_SYSDATA [3][k] := ControlHandle
so my Question is : can i "hack" _HMG_SYSDATA [3][k] to get ControlHandle :?:
   FOR n := 1 TO 8
      cLabel := "Label_"+LTRIM(STR(n))
      hWnd := GetControlHandle(cLabel)
Function GetControlHandle(cName)
LOCAL aName := ACLONE(_HMG_SYSDATA[2])
LOCAL nPosi := ASCAN(aName,{|e| e = cName } )
LOCAL nHwnd := 0
   IF nPosi > 0
      nHwnd := _HMG_SYSDATA [3][nPosi]
RETURN nHwnd
this Way i seems to get ControlHandle but i don't know if it is "safe" :?:
