use FMG more than once
i have create my 1st FMG and it work. :D
now i think how does it work if i want to use same FMG twice (or more) at same time :?:
what i mean :
let say we have a GRID a select 1st Item. now you want "more" and press ENTER and FMG appear.
even if FMG is still open i like to change to GRID an choise other Item and "open" it -> FMG twice
so how to do it with harbour / HMG :?:
Re: use FMG more than once
As I understand well, you should open child window after ENTER is pressed
Yes Form open after ENTER or DblClick on GRID Item.
but what when have Form open, change to GRID and choise other ITEM and open 2nd FORM :idea:
Function Setup()
   DEFINE WINDOW Win_Setup ;
   @ 050,200+50 TEXTBOX TEXT_1 ;
                FIELD POP3->POP3     ;
in MAIN i do this
   nResult := Win_Setup.TEXT_1.Value
but which Result is it :?: from 1st Form or from 2nd Form :?:
this is my Problem with "multi" Form.
in Xbase++ i use OOP so Result is ok
I don't understand what you really need, the translation is not faithful when translating the page.
I think you should use the code provided by EDK.
Local aRows [20] [3]
_HMG_LastActiveGridIndex := 0
		WIDTH 800 ;
		HEIGHT 550 ;
		TITLE 'Hello World!' ;
		aRows [1]	:= {'Simpson','Homer','555-5555'}
		aRows [2]	:= {'Mulder','Fox','324-6432'}
		aRows [3]	:= {'Smart','Max','432-5892'}
		aRows [4]	:= {'Grillo','Pepe','894-2332'}
		aRows [5]	:= {'Kirk','James','346-9873'}
		aRows [6]	:= {'Barriga','Carlos','394-9654'}
		aRows [7]	:= {'Flanders','Ned','435-3211'}
		aRows [8]	:= {'Smith','John','123-1234'}
		aRows [9]	:= {'Pedemonti','Flavio','000-0000'}
		aRows [10]	:= {'Gomez','Juan','583-4832'}
		aRows [11]	:= {'Fernandez','Raul','321-4332'}
		aRows [12]	:= {'Borges','Javier','326-9430'}
		aRows [13]	:= {'Alvarez','Alberto','543-7898'}
		aRows [14]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [15]	:= {'Batistuta','Gol','485-2843'}
		aRows [16]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [17]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [18]	:= {'Samarbide','Armando','854-7873'}
		aRows [19]	:= {'Pradon','Alejandra','???-????'}
		aRows [20]	:= {'Reyes','Monica','432-5836'}
		DEFINE TOOLBAR ToolBar_1 BUTTONSIZE 30,30
			BUTTON B_FIND CAPTION "[F2] Find" ACTION ShowLastFocusedGrid()
		END TOOLBAR
		@ 50,10 GRID Grid_Master ;
			WIDTH 760 ;
			HEIGHT 180 ;
			HEADERS {'Last Name','First Name','Phone'} ;
			WIDTHS {140,140,140};
			ITEMS aRows ;
			VALUE {1,1} ;
			TOOLTIP 'Editable Grid Control' ;
			ON GOTFOCUS _HMG_LastActiveGridIndex := GetLastActiveControlIndex ();
			EDIT ;
			JUSTIFY { GRID_JTFY_CENTER,GRID_JTFY_RIGHT, GRID_JTFY_RIGHT } ;
			CELLNAVIGATION
		@ 240,10 GRID Grid_Detail ;
			WIDTH 760 ;
			HEIGHT 180 ;
			ITEMS aRows ;
			VALUE 1 ;
			EDIT ;
			ON HEADCLICK { {||MsgInfo('Click 1')} , {||MsgInfo('Click 2')} , {||MsgInfo('Click 3')} } ;
			JUSTIFY { GRID_JTFY_LEFT,GRID_JTFY_CENTER, GRID_JTFY_CENTER }
		@ 440, 10 BUTTON Button_1 CAPTION "Last GRID" ACTION ShowLastFocusedGrid()
		ON KEY F2 ACTION ShowLastFocusedGrid()
	CENTER WINDOW Form_1
Function ShowLastFocusedGrid()
Local i := _HMG_LastActiveGridIndex
Local aCtrlData
IF i > 0
	aCtrlData := GetControlDataByIndex (i)
	MsgInfo (e"Control name\t: " + aCtrlData [2] + CRLF +;
		    e"Control type\t: " + aCtrlData [1] + CRLF +;
		    e"Form name\t: " + aCtrlData [40] [40], "The last focused grid" )
martingz
Post by martingz »
AUGE
Something like this, the background screen is the grid, I double click and the window appears in the front with the information,
martingz wrote: Fri Nov 22, 2019 4:34 pm Something like this, the background screen is the grid, I double click and the window appears in the front with the information,
YES ... but now, leave Detail Form open, i want to go to GRID an take another Item and DblClick.
i'm now on a other Record an got Data from "this" Record, or :?:
i saw Sample with Macro as Form-Name
   DEFINE WINDOW &fMain ;
so when 1st Form is called by "Form_01" and 2nd Form is called "Form_02" that i can use
   nResult1 := Form_01.TEXT_1.Value
   nResult2 := Form_02.TEXT_1.Value
so how to get this construction. :idea:
edk
Post by edk »
AUGE_OHR wrote: Fri Nov 22, 2019 8:33 pm i saw Sample with Macro as Form-Name
nResult := GetProperty ( fMain, "TEXT_1", "Value")
No logro ver el panorama completo de lo que quieres hacer...
Si doy 20 veces "dobleclick" en uno o varios registros del grid,
voy a tener 20 ventanas abiertas en mi pantalla ???
I can't see the full picture of what you want to do ...
If I give doubleclick 20 times in one or more grid records,
Will I have 20 windows open on my screen ???
It is not understood what you really want to do
andyglezl wrote: Fri Nov 22, 2019 9:27 pm Si doy 20 veces "dobleclick" en uno o varios registros del grid,
YES ... not 20 but more than 1
guess you working on Client "A" and than Client "B" call on Phone.
i do not want to close "work of A", just open a new Form with Data of Client "B"
it is Windows not Cl*pper so User can have many if they need.
but i need to "control" them and i have to figure out how it work with FMG file
under Xbase++ i use OOP and i can
   AADD(aThread, oThread)
later i can ASCAN for Object
   nPosi := ASCAN(aThread, {|e| e = oThread } )
so i have full Control of every Object
